ford sierra trailing arms
looking for some help to identify the proper ford sierra trailing arms
the one i have taken of has a bracket for the shocky
the bit where the wheel bearing bolts onto isn't as thick on broken one as on the complete one also note no shocky bracket
Attachment 7646
whole one
fatter bit where wheel bearing bolts on
broken one
main photo in reply below
Attachment 7646
whole one
broken one
Sierra estate rear arms. not the one you have
Looks like someone may have cut off the shocker bracket on the one you have. Guess it was on a kit car?
There are a few rear arms for the sierra if yours is a disc braked type. one for none cosworth i.e xr4x4, gls4x4, ghia4x4,dohc 4x4.
You can tell by the shocker mount is this shape
The cosworth ones are like this
Just be aware that there are different toe and camber setting between the arms. If you dont have a match pair you will find the car driving very odd.
Jackingleby
47
16-09-2016 09:26 AM
28-04-2016 11:18 AM
