Escort S2 RWD Mid Engine rebuild (Pic update 23-6-07) Page6
#42
Small update..
Front suspension in..
Front rack..
Also cleaned the engine up a bit...
Should be in by next week
Day light at last..
More soon..
Front rack..
Day light at last..
More soon..
#44
I'd never seen this thread before, how cool is this?! Great work going on here, can't wait to see the finished article. That must be great fun!!
#52
Originally Posted by FordKid
i'm not :blonde: but is propley a silly question, but how u gonna change though the gears?
#54
Haven't had much time to work on it over the last week, should be a update at the weekend..
Been waiting for some bits to turn up
I will post some more pic's at the weekend.
#57
Took some pictures of some bits ive got over the last week or so.
New brake lines
Fuel pipe.
ACT in blue. (Thanks Mike R)
Battery cut-off switch and pull cable.
Push button starter.
Bonnet/boot pins and some polyrace bushes.
New Cosworth rear calipers.
New(ish) rear lights.
Thats about it for now, should do some more over the weekend.
Watch this space................. [/img]
New brake lines
Fuel pipe.
#62
Nath fook me mate you aint hanging around now .Will pop round when i get back of me holidays, you can takem e for a spin .
Top job and its gonna be fun when its done, i might even need to do one
#63
tremendous effort mate, looks great so far but will be awesome once finished
who done the cage? it looks top notch
you should put another engine in the front tho
#64
Originally Posted by andyescos
Looking good, but a query, why cossie rear calipers? Couldn't you run front set up on it? or is it to keep a handbrake?
Andy
Andy
#69
Originally Posted by WutangRS
what did you use to cut the roll cage pipes to the right shape (ie the notches for joining tube against tube)
looking awesome though
Cheers for the kind comments guys
#72
looks good just a quick question,on 1 of the pics of the engine,the turbo has a pipe on it going from the actuator 2 the compressor housing,in the pipe its got a t piece with another pipe coming off it,where would that other pipe go to,any help with this would be great
#74
nice work mate!!!
c for cuttin the cage material at correct angles for buttin edges to weld, did u use somethin called a..... bollocks cant member its name
wat u use??
wat u use??
#76
hope this helps you
#77
Fantastic work ! If you carried out conversions for people I'm sure you'd have a regular flow of business!
Very ambitious project - liking it alot.
Question - what do you think it will handle like and how are you getting the rear suspension sorted?
#78
Another question - crappy MkIV brakes on RHD models are cos of the LHD location of the master cylinder so why havent you moved it to the other side now you have the space?
#79
Im just trying to put everything back together so i cant get out and have some fun!!!!
#80
Got a chance to do some bits over the last week or so....
Some home made brackets for the radiator's.
Both radiators using the brackets. (The front one is for the charge cooler)
Fitted to the motor.
Just testing to see if the fans fit ok.
Fitted the fuel pump and lines.
Fitted the pedals and the clutch cable.
Been putting some bits back on the engine too.
And the doors and bonnet....
Dont know which seats to use?????
Or
I think i will use the black one as they are FIA approved.
Gonna do the loom next......
Or
