Moonstone Blue Mk2 Ford Orion Zetec Turbo - 313.5bhp/ 321.7trq
Old 12-10-2018, 12:12 PM
  #121
slammedorion
slammedorion's Avatar
Originally Posted by cossirob
The reason i asked is beacuse i fitted a mtx75 box in my mk3 zt escort with a silvertop without a problem it was a pretty easy to be hones. iv had no ground clearance issues and im lowered 30mm with 15" wheels, also all i done to sort the speedo issue was to swap the bell housing from the electric speedo type to the mechanical type then the original escort speedo cable fits onto the box.
Can you post some pics of your conversion
Is yours the Focus RS Mtx75?
Old 12-10-2018, 05:31 PM
  #122
cossirob
cossirob's Avatar
I
slammedorion (12-10-2018)
Old 12-10-2018, 05:37 PM
  #123
cossirob
cossirob's Avatar
Sorry not the best of pictures but that's all I have. I was told by the person I bought the gearbox off that it is a focus rs box but iv got a feeling it isn't! I think it's a standard mtx75 (can't say what car it's from) with a frs diff but I can't say for sure.
At first I was using the standard focus rear lower mount but I ripped it out the bulkhead so i welded thicker plate along the bottom of the bulkhead and had a custom mount made
Old 12-10-2018, 07:36 PM
  #124
studabear
studabear's Avatar
CossiRob what clutch do you use with that bell housing?
Old 12-10-2018, 08:30 PM
  #125
cossirob
cossirob's Avatar
Focus rs ap 6 paddle mate had to give the bell housing a trim on the inside to make it fit. It also positions the starter at the front
Old 12-10-2018, 08:35 PM
  #126
cossirob
cossirob's Avatar
Old 12-10-2018, 08:36 PM
  #127
cossirob
cossirob's Avatar
Old 12-10-2018, 08:38 PM
  #128
little bram
little bram's Avatar
Alright slammedorion
just something to let you know about when I done mine I had to move my engine forward a fair bit to clear the inner cv joints because they hit the chassis where your bottom bolt too. so my advice would be is to put the shafts in before you weld the mountain on and you may have problems with they exhaust manifold when you move it forward.
Old 12-10-2018, 08:41 PM
  #129
little bram
sorry rob but it doesn’t look like a rs box however it does look like it has a rs diff in it witch is good.
Old 12-02-2019, 08:27 PM
  #130
slammedorion
Still waiting to make a start on this...
Old 06-03-2019, 03:56 PM
  #131
slammedorion
Old 06-03-2019, 03:59 PM
  #132
slammedorion
Old 06-03-2019, 04:01 PM
  #133
slammedorion
Old 13-04-2019, 08:55 PM
  #134
slammedorion
Only test fitted dry...
I’ve ordered some 5mm wheel spacers so the wheels clear the callipers
Need some more washers/ spacers to go between the calliper/ adapter bracket
Also need to sort hoses for them...
Once I’m happy I’ve got everything and it’ll all fit I’ll repaint them
Old 13-04-2019, 08:59 PM
  #135
james kiely
james kiely's Avatar
looking good mate
slammedorion (13-04-2019)
Old 13-04-2019, 09:06 PM
  #136
slammedorion
looking good mate
Old 13-04-2019, 09:09 PM
  #137
Rsmat
300+
Rsmat's Avatar
looking good mate .
Old 13-04-2019, 09:19 PM
  #138
slammedorion
Originally Posted by Rsmat
looking good mate .
Thanks
Engine & gearbox out this week to do the cambelt/ water pump change
Old 13-04-2019, 09:30 PM
  #139
studabear
studabear's Avatar
Can it not be done in situ? I know the bottom pulley will need the engine dropping a fair amount.
Old 14-04-2019, 04:56 PM
  #140
slammedorion
Not enough room...
Was tried last year
Old 14-04-2019, 06:43 PM
  #141
studabear
studabear's Avatar
Originally Posted by slammedorion
Not enough room...
Was tried last year
Is this the start of the mtx conversion then?
Old 14-04-2019, 06:47 PM
  #142
slammedorion
I’ve gotta run all the shafts over to Gary and leave them with him...
Need him to make a rear mount up aswell
Old 14-04-2019, 08:44 PM
  #143
studabear
studabear's Avatar
That's my new one.
slammedorion (14-04-2019)
Old 19-04-2019, 09:13 PM
  #144
slammedorion
A few hours work this morning stripping everything off ready to pull the engine & box out for cambelt & water pump change
Old 19-04-2019, 09:16 PM
  #145
slammedorion
Old 19-04-2019, 09:17 PM
  #146
slammedorion
Old 19-04-2019, 09:19 PM
  #147
slammedorion
Old 24-04-2019, 07:14 PM
  #148
Rsmat
300+
Rsmat's Avatar
Looking good mate ..keep up the good work.
slammedorion (24-04-2019)
Old 24-04-2019, 08:56 PM
  #149
slammedorion
Cheers Mat
Just the engine/ gearbox & anti-roll bar bolts to undo and it should be good to drop
Will clean a few bits up while everything is out, won’t go too mad as I’d like to send bits for powder coating soon
Old 24-04-2019, 08:59 PM
  #150
slammedorion
Old 24-04-2019, 09:01 PM
  #151
slammedorion
Old 24-04-2019, 09:20 PM
  #152
slammedorion
Finally decided to upgrade from the Aldi 24l compressor... has done me proud over the last 10 years with zero maintenance bar draining the tank
Bought a SGS 100ll compressor... will come in handy
Old 25-04-2019, 12:17 PM
  #153
Rsmat
300+
Rsmat's Avatar
Good bit of of kit I've got the 150L one in the back and it's way plenty enough for a one ban band ..the 100L is bang on mate
Old 25-04-2019, 09:28 PM
  #154
slammedorion
Phew
Its out
Old 30-04-2019, 09:39 PM
  #155
slammedorion
Genuine 1800 zetec waterpump collected this morning from my local Ford Dealer
Old 30-04-2019, 09:43 PM
  #156
slammedorion
De wrapped the exhaust manifold... sh!t job to do
Old 30-04-2019, 09:44 PM
  #157
slammedorion
Was going via DHL to Zircotec for Ceramic Coating but after DHL wasting my time collecting and Zircotec keep plucking figures out of the sky for doing the job, insuring it through transit!!! They’ve lost my Ł305 plus insurance!!!
Im dropping it off in the morning to a local firm in Warrington
https://m.facebook.com/camcoatperformancecoatings/
http://www.camcoat.com/main/coatings2.html
Cheaper and I can drop it off and collect...
Old 01-05-2019, 06:12 AM
  #158
studabear
studabear's Avatar
I would like to get mine done and the front pipe.
slammedorion (01-05-2019)
Old 04-05-2019, 07:49 PM
  #159
slammedorion
I had Andy @ Overboost visit quickly yesterday to replace cambelt & waterpump ( he wanted to do it due the adjustable pulleys )
Today after work I’ve managed to get alittle cleaning, painting done... nearly ready to bolt back in...
Old 04-05-2019, 08:31 PM
  #160
slammedorion
Quick Reply: Moonstone Blue Mk2 Ford Orion Zetec Turbo - 313.5bhp/ 321.7trq
