ABS xr4x4 2.9i
Old 29-11-2016, 10:09 AM
DaxRiders
DaxRiders's Avatar
Exclamation ABS xr4x4 2.9i
Hi, i've got a problem with my brakes.
The defaut ABS light is always on.
The brake pedal is hard. No brakes.
The fluid level is good.
Fuses good.
Relays good.
The pump ? i don't know. 12V 's ok. But no noise.
An idea ? Thx for your help.
( sorry for my english )
Old 29-11-2016, 12:31 PM
martysmartie
martysmartie's Avatar
There is a pressure switch on the master cylinder, it's worth checking that this is closing, alternatively bridge the connector briefly, to see if the pump runs.
Martin
Old 29-11-2016, 12:38 PM
james kiely
james kiely's Avatar
or maybe a sensor is broken
Old 29-11-2016, 01:31 PM
grcossie
grcossie's Avatar
Have fixed this on some Cosworth`s, pressure switch on abs Block as a common fail, have also seen some broken wires from battery + to abs
