Tim's Performance Blue S1600 *2.0 ECOBOOST ENGINE SWAP, 370lbft 270whp*
Old 17-11-2013, 05:58 PM
  #161
TimWeeble
S1600 Owner
TimWeeble's Avatar
Got one of these coming this week =]
http://www.ebay.co.uk/itm/Fiesta-mk7...item27da3a4980
Old 17-11-2013, 06:53 PM
  #162
RoscoST
RoscoST's Avatar
It's coming on mate - little beast !
Old 20-11-2013, 06:18 PM
  #163
TimWeeble
S1600 Owner
TimWeeble's Avatar
Bonnet strut arrived today and had a shoulder bolt turned in work for the torque link mount. Spacers that are required for the torque link are being done in the morning.
However going to look at clearances with the engine hanging just on the gearbox/engine mounts and see if a frankentorquelink is possible using the back end of the fiesta torque link from vibratechnics and the front end of the focus torque link from them.
More updates to come friday when i head back over to the unit.
Old 21-11-2013, 08:54 AM
  #164
XRT_si
XRT_si's Avatar
Such an awesome car this!
Old 21-11-2013, 05:09 PM
  #165
TimWeeble
S1600 Owner
TimWeeble's Avatar
Cheers Si =]
exhaust bushings turned up today with some nice keyrings as a surprise!
and the torque link spacer bushings were finished in work and they're a lovely snug fit on the shoulder bolt that was made up =]
Old 21-11-2013, 06:08 PM
  #166
Ive got one of those key rings too.
Old 23-11-2013, 10:59 AM
  #167
TimWeeble
S1600 Owner
TimWeeble's Avatar
The plumbing came together quicker than expected. Will managed to reuse a lot of the OEM hosing which is a bonus for timescale and my wallet and it looks spot on!
Coolant to heater matrix
coolant to header tank
vac pump
Fuel pump (awaiting some more 7mm rubber fuel line to connect to the standard piping from the tank, same goes for the charcoal canister breather pipe)
Vac line to be clipped down near the gearbox mount and clutch was a straight connection between the fiesta line and the slave cylinder pipe.
Also had chance to bleed the clutch through and it really does have a nice firm feel. Much heavier than the fiesta one that's for sure!
Had chance to fit the bonnet lifter as well. Really nice bit of kit, easy to fit and works well!
and here's a quick video of it working....excuse the phone-cameraman-ship.
http://i157.photobucket.com/albums/t...psde8238b7.mp4
It took us a good few hours to fit the torque link bolt and spacers just because everything is so tight and also because the bolt i had made was just too tightly toleranced for the job. We didn't have enough wiggle room. So to get it on we ended up using the spacers with a bolt that we had ordered from RS, taking the mount off the gearbox and putting that into the sub frame first then swinging it back onto the box.
a small job that took way too long and may be addressed in the future depending upon how everything works!
Managed to get the focus gaiter off and fit the fiesta gaiter so it looks spot on =]
To fit the shifter in the car we have took the top half of the focus shifter off the raiser plate that it comes with and Will is going to make a new raiser plate from plate steel and box section. This way we can get the shifter to fit on the OEM tabs and at the exact height we need.
This was after the colossal ball ache that was removing the fiesta shifter cables. Nearly lost the will to live but with a bit of brute force they came out and we could get the focus cables in.
Bulkhead through connection is totally different but for ease of service in the future we are running the bulkhead seal on the outside of the car and Will is going to make a seal around it. Saves us having to remove the dash anyway!
here's a closer look at the gearbox mount with the battery tray mount welded to it and coated in Dinitrol. Notice the gearbox vibro mount is on washers at the moment... a properly machined spacer is on order to support it correctly but for now washers will do =]
Now we didn't really want to go final fit yet but with how tight everything is we decided to start heading for it so the drive shafts went in.
Still pretty close to the sub Frame but it is clear and the engine isn't going to twist much after giving it a push.
we then installed all of the new exhaust bushings and it is definitely better. For anyone with the milltek exhaust on the fiesta get yourself some EXH015's from powerflex. I dont have to wrap jubilees around them anymore either.
we forgot to reinstall the heat shielding around the tank so when the centre section is removed to sort out the joint seals this will be going back in.
Feel like we got a lot done yesterday and we're sort of back on track. This week the last items should be on order and Will can start the wiring. Big bonus is that most of the plumbing is done (bar the AC for which we still need to find a mobile guy who can crimp us some lines) along with a lot of the ball aches that were found.
looking a little neater anyway now that the coolant hoses are in position and most of the loom is on.
ONWARD!!!!
Old 23-11-2013, 12:39 PM
  #168
Touring Car Spares
Touring Car Spares's Avatar
Cracking project, well done to all ,looks amazing .
Old 23-11-2013, 03:41 PM
  #169
TimWeeble
S1600 Owner
TimWeeble's Avatar
Cheers! its really starting to come together now
Old 23-11-2013, 08:32 PM
  #170
RichieST
RichieST's Avatar
Such an amazing project, great update the end of the road is in sight!
Old 27-11-2013, 06:59 PM
  #171
TimWeeble
S1600 Owner
TimWeeble's Avatar
Quick update...
I won't be going to the unit this week as everything I can do is now pretty much done. Will is cracking on with the last bits, most importantly the wiring and with any luck we'll be able to do the first crank over early next week. I'll keep you posted.
/tim
Old 27-11-2013, 07:13 PM
  #172
7sean7m7
7sean7m7's Avatar
Should all be done and on the road by Christmas then with some vids, yes?
Old 27-11-2013, 07:27 PM
  #173
TimWeeble
S1600 Owner
TimWeeble's Avatar
Indeed, indeed.....thats the plan anyway
Old 29-11-2013, 05:38 AM
  #174
TimWeeble
S1600 Owner
TimWeeble's Avatar
Will has been busy mounting my shifter.
And a video to prove I have gears!
Getting there.
/tim
Old 29-11-2013, 10:16 PM
  #175
macca33
macca33's Avatar
Thats a cool project, nice one....
Old 29-11-2013, 10:24 PM
  #176
TimWeeble
S1600 Owner
TimWeeble's Avatar
Cheers mate, hoping for the first crank over of the engine sometime next week =]
Old 30-11-2013, 07:04 AM
  #177
Wow amamzing progress matey. Will is the man.
Old 30-11-2013, 11:20 AM
  #178
Mk4 Rick
Mk4 Rick's Avatar
That's how ford should have made it lol well done.Brilliant work and looks factory finish
Old 05-12-2013, 10:26 AM
  #179
Fanis The Greek
Fanis The Greek's Avatar
Default brackets
Originally Posted by TimWeeble
rear brake brackets measured up, just need to get them made now and test them :P
could've designed it like the puma greed bracket but i want to keep it behind the hub so the only new hardware needed is for the caliper carrier. Time will tell anyway...i have another design as a backup.
do you have the exact measurements of the brackets?how much do they cost?do they ship
Old 06-12-2013, 09:02 PM
  #180
headlesssteve
whats the worst that can
headlesssteve's Avatar
hi there,just read this thread, loving it.I used to have an 09 fester ZS and loved it, like a go kart but not enough power. Now got a 13 plate focus ST, its got a cracking engine,little or no lag,almost like a supercharged motor.With the TC off it wil easily spin the wheels into third gear.Combining the two should make for the fiesta Ford should have made.The focus has plenty of torque steer but your diff should tame that.Looking forward to seeing your project complete
Old 06-12-2013, 09:08 PM
  #181
TimWeeble
S1600 Owner
TimWeeble's Avatar
me and you both mate i need it back before christmas =]
Old 06-12-2013, 09:27 PM
  #182
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
i think yourself and Mr.Pedley will have a LOT of work off the back of this from future custom ideas, pipework solutions and if thaught about, conversion parts off the shelf
Old 06-12-2013, 09:35 PM
  #183
TimWeeble
S1600 Owner
TimWeeble's Avatar
i think Will is going to be glad when its done......become such a saga!
but i would consider measuring all the parts and getting quotes for off the shelf parts....broke now though so no capital to do it yet =]
Old 07-12-2013, 07:56 AM
  #184
This project must be costing you a fortune matey.
Old 07-12-2013, 08:14 AM
  #185
TimWeeble
S1600 Owner
TimWeeble's Avatar
Over budget and over run timescale......usual story
Old 07-12-2013, 09:03 AM
  #186
B19 JUB
B19 JUB's Avatar
wow.it looks so oem i bet people look an unaware what engine it is.well done
Old 08-12-2013, 04:49 PM
  #187
TimWeeble
S1600 Owner
TimWeeble's Avatar
just waiting for the brackets to turn up mate and if they work fine will be aiming to sell them.....keep watching and i'll be in touch.
there is a lot of fab work but hopefully we could offer mounts, source ecu's and drive shafts, fuel pumps and the like and the knowledge to get the other parts done.
Thats the plan :P Troll!
Old 08-12-2013, 06:07 PM
  #188
IanC
IanC's Avatar
Looking good pal soon be finished there can't be much left to do now be interesting to see how it drives with more power there such a good handling car just needed the kick up the arse like your giving yours
Old 08-12-2013, 06:14 PM
  #189
TimWeeble
S1600 Owner
TimWeeble's Avatar
come have a look around it when its back mate i'm only up the road =]
Old 09-12-2013, 08:04 AM
  #190
IanC
IanC's Avatar
Yeah mate would be good to have a good look round it
Old 11-12-2013, 07:02 PM
  #191
TimWeeble
S1600 Owner
TimWeeble's Avatar
boxessss!!!!
To be fitted this weekend =]
Old 11-12-2013, 08:35 PM
  #192
Them brakes are massive.
Old 11-12-2013, 09:24 PM
  #193
TimWeeble
S1600 Owner
TimWeeble's Avatar
318mm so just about right for the car.
I did think the calipers where huge when i lifted them out but its probably because its not next to the car :P
Will just sent me a pic of the TMAP welded to the boost pipe so getting very close now.
'HAS' to be on a trailer sunday/monday down to have the CANbus programmed and put on the ecu so ploughing on !
Old 12-12-2013, 05:53 PM
  #194
TimWeeble
S1600 Owner
TimWeeble's Avatar
Fun for will today.
Not envious of having to sort out the wiring.
Old 12-12-2013, 09:51 PM
  #195
TimWeeble
S1600 Owner
TimWeeble's Avatar
Wiring mostly done and nice and neat. Red wire to run back to the dash.
ECU and IDU nicely mounted.
Old 13-12-2013, 08:59 AM
  #196
IanC
IanC's Avatar
Love the brakes I've got the same calipers to go on the back of mine can't beat a set of alcons
Old 13-12-2013, 05:31 PM
  #197
TimWeeble
S1600 Owner
TimWeeble's Avatar
Where did you get all your alcon stuff from mate? youve got 6 pots on the front right?
also whats the spec of your car?
Old 13-12-2013, 06:05 PM
  #198
IanC
IanC's Avatar
Yeah mate I've got the alcon 6pots on the front of mine with 362 ap discs and 310s on the rear spec wise it's quite tame it's making 360 ATM soon to break the 400 mark it's got a pro alloy charge rad John frs prototype hybrid and Ggr cais and a full miltek soon to be changed to a 3" BCs tho and dpc stage3+ fancy a live map next and big injectors what power you hoping to get from yours pal? I'm just looking at getting some kw v3s too I got the front alcons off a mate who was breaking his focus and got the rears off eBay
Old 13-12-2013, 06:17 PM
  #199
TimWeeble
S1600 Owner
TimWeeble's Avatar
Very nice indeed...... hoping for around 280 with 300+ lbft torque although radical with the same engine in there production car are claiming just shy of 300bhp. tbh having a bit over the engine quoted 250bhp will be good enough as it's only done 68 miles apparently so it needs a good run in and the torque curve will be awesome regardless =]
Old 13-12-2013, 08:41 PM
  #200
Fook me look at all them wires.
Quick Reply: Tim's Performance Blue S1600 *2.0 ECOBOOST ENGINE SWAP, 370lbft 270whp*
