Tim's Performance Blue S1600 *2.0 ECOBOOST ENGINE SWAP, 370lbft 270whp*
#207
S1600 Owner
So today Royal Fail came through...
New 90 degree crimp for the starter motor live
Silicones
Gearbox Mount Spacer
Rear Brake Brackets
ST170 rear disc setup here spins nice and freely and is solid. Lines and handbrake cables yet to be fitted as a sidetrack occurred....
LIFE!!
Now to carefully package everything else and final fit everything properly.... so no rushing!
But I now want it back badly :P
Silicones
Rear Brake Brackets
LIFE!!
#212
S1600 Owner
Not at the moment. To be honest we've talked about it and as the ecoboost is an alloy block vs the steel block on the sigma the weight difference is less than 100kg. I'm 130+ so i have more of an effect on it and when I've got another passenger in the car it doesn't make a great deal of difference. Obviously it's not exactly the same but I'm not banking on it having too detrimental an impact. I'll know more when I eventually drive it and then get it corner weighted
#213
S1600 Owner
S1600 Owner
Cheers Fellas.
And its that Prestone Stuff. Makes your windows bead great.....looks like piss :P
Brakes
Front end nearly all back together looking stealthy
Brakes
#219
S1600 Owner
it was 5 quid for 5 litres in Tesco a few weeks ago.
Your meant to dilute it most of the year but i just leave it in neat.
http://www.tesco.com/groceries/Produ.../?id=265419036
#224
Saw that front end on Will's FB, and immediately said "It's done!"....but obviously, a car like this is never totally done
Are you sure about the Sigma engine being iron? Somehow, i had on my mind that all Sigmas where alloy...
#226
willpedleyracing.co.uk
Sigma engine is indeed an alloy block - not iron as I first suggested to Tim.
Yes, the shiny pipe is going to get powder coated black. We left it uncoated to avoid any scuffing / scratching during the installation.
MOT is booked for first thing monday morning and having seen it idling at lambda 1.00 earlier, i'm confident it'll pass
#230
S1600 Owner
As Will said above and the map is pretty much finalised through Will's technical partner although after the initial 500 to 1000 mile break in period at Rev limited 4000RPM we will sort out the air filter most likely, remove the limiter and dyno it and Will can tweak it to the specific mods that are fitted =]
#234
S1600 Owner
Unfortunately due to a fuel pump issue missed the MOT today so gonna have to wait a week for that....but the issue is resolved and i'm told that up until it occurred the car behaved itself very well.
Anyway this video lifted my spirits after hearing we had missed our MOT.
For your viewing pleasure
Sounds Awesome!!
Sounds Awesome!!
#236
What a project top work on that! Looks like will has done a mega job on it. Bet your itching to get it back now! Will keep a look out for it once you get it back.
#237
S1600 Owner
Cheers!
annoying that we missed the MOT yesterday.....especially at this time of year, meaning we have to wait till the 2nd for an MOT... but a blessing in disguise it has highlighted something we need to modify in the fuel module and then it should all be absolutely fine.
#239
S1600 Owner
