p100 wiring looms and E/W
Hi all
I am considering putting in electric windows in to my p100. I dont want to run a live of the battery etc unless i really have to. I wondered if anyone knew if i could simply get the door looms and plug in to the already existing p100 loom somewhere. I figured ford would have used the same loom as was in the td sierra only never plugged/put in the window looms when the looms went in to the td p100. But.. i could be wrong and end up ripping the dash out for nothing. Can anyone shed any light on this?
Pick-up P100 Power!
Hi all
I used a 4x4 saph cos loom. I have a mk1 ghia loom in the shed for sale you could cut the interior loom off of.
Good luck mate
Nightmare
I hate wiring just spent a lot of hours rewiring the rear lights I notice a crap job done before and battery died in the process I stuck it on charge and left it to return to another trying to move it and tried starting it.now the batt was very dead still ,it wouldnt start but I did notice the fuse blown in the charger. I replaced it but didn't have time to check if it screwed the wiring in the car or blew any fuses though I am thinking with the luck I am having it has done something.as I did notice tail lights not working,though I thought it maybe just cause the battery is really low. So can anyone shed any light on this will trying to start it with a charger on it blow the ecu,fuses,relays etc
Hi Guys
I want to fit Electric front windows , Electric door mirrors , Central lock , Fog lights and Head light wipers to my P100. Would I need a complete Sierra Cosworth wiring loom and fuse box ? I`m not decided on ABS yet but might consider it too.
Mark RS
12-10-2015 06:01 AM
muz
30-09-2015 08:29 AM
