teamSPB's New Project...Mercedes CLS...iPad mini, hydraulics, 20's!
Old 03-04-2013, 06:47 PM
  #41
RichieST
RichieST's Avatar
Loads better!
Old 03-04-2013, 07:28 PM
  #42
boost monster
boost monster's Avatar
Great work with the lights. Did you melt the glue with a heat gun/oven to seperate the lense? I'd like the change the marker lights on my 5 series from orange to white but not brave enough yet.
Piano black dash will be a massive improvment to the hidious wood. Looking forward to more pictures.
Old 03-04-2013, 09:39 PM
  #43
v man
Zee Germans are coming
v man's Avatar
The front looks bang on
I think the chrome piece on the boot need the same treatment as the grill
Old 03-04-2013, 09:40 PM
  #44
v man
v man's Avatar
Oh and did you see my post regarding the 6 pot Amg calipers.
Would like a set for my golf
Old 03-04-2013, 09:47 PM
  #45
bassboy
bassboy's Avatar
Yeah I used a heat gun to warm up the glue...then slowly start to split the lights with a screwdriver, knife etc...I would have used the oven but the lights were too big lol
Then when you seal them back up, make sure you use fresh sealant or it wont seal again
Old 03-04-2013, 09:49 PM
  #46
bassboy
bassboy's Avatar
Yeah I am having a look...best bet is german ebay or the american guys...
I have dropped the guy who sourced my calipers an email to see if he has more in stock, still awaiting a reply...
If its of any help, you can try my 8pots when they arrive?
Old 03-04-2013, 10:02 PM
  #47
v man
v man's Avatar
Ah cool nice one bud
Old 03-04-2013, 10:24 PM
  #48
Mr Crayford
Mr Crayford's Avatar
Love the mirror finish on the other car
I like the professional work on the cls looks very nice
Old 04-04-2013, 07:26 AM
  #49
Them head lights like miles bettrr.
Old 04-04-2013, 07:27 AM
  #50
Them head lights like miles better.
Old 04-04-2013, 04:04 PM
  #51
SAV191x
mk4 escort sport
SAV191x's Avatar
looks awsome
Old 07-04-2013, 06:56 PM
  #52
bassboy
bassboy's Avatar
Considering the console was being changed, I stripped out the back of the car completely...this was for two reasons;
- To clean the seats and carpet thoroughly
- To sound deaden the rear bulk head properly as I will be installed subwoofers which will be mounted to it and ran as infinite baffle. This means they will not technically have a box and will use the boot space as the enclosure...however, I will try something a little different to see if it works
Stock boot
Checking the battery/spare wheel area
Rear panel about to be sound deadened and insulated
Stock rear shelf area
Im guessing the big foam bit is where the OEM subwoofer would have gone if it was specced from factory...neat idea!
All big holes covered in Gladen Audio Aero Extreme - this is a VERY stiff sheet with an adhesive backing to cover big holes and give NO flex!
Stripping and deadening in Silent Coat 2mm and 4mm deadener
Old 15-04-2013, 10:04 PM
  #53
bassboy
bassboy's Avatar
Gladen Audio Neoprene 6mm closed cell foam to help stop airborne noise
iPad mini build
Gladen Audio Zero Pro 165 DC components
Sneaky centre channel
Old 19-04-2013, 09:24 PM
  #54
bassboy
bassboy's Avatar
This is what the panels were like before hand
18" subs are a TIGHT fit!!
teamSPB
Old 20-04-2013, 10:39 PM
  #55
bassboy
bassboy's Avatar
I have been asked a good few times now how I am getting the audio to the speakers...I am using the iPad's built in speaker...sounds great!! LOL...im doing it as below;
iPad mini bluetooth streaming audio at full resolution
Mosconi 6to8 DSP processor with SP-DIF multi and AMAS modules added on to allow for bluetooth streaming
Mosconi amps
Gladen audio speakers
So the iPad mini sends through all audio signals via bluetooth to the Mosconi 6to8 DSP. The DSP then processes the sounds, splits up the signals and sends them to the amps via RCA's as per normal.
The amps then send signals as per normal into the speakers via speaker cables.
The Mosconi 6to8 had to be opened up to accept the extra modules
Hope this helps
Old 21-04-2013, 11:02 AM
  #56
fezzajsy
fezzajsy's Avatar
amazing stuff
Old 21-04-2013, 07:45 PM
  #57
Zetecfiesta
Zetecfiesta's Avatar
Very very cool mate
Old 21-04-2013, 08:01 PM
  #58
RichieST
RichieST's Avatar
Like the ipad in the dash. What wheels did you go for?
Old 21-04-2013, 08:26 PM
  #59
AJC
AJC's Avatar
The work you do is phenomenol. Very professional, great attention to detail and very clever stuff.
Old 22-04-2013, 08:58 PM
  #60
bassboy
bassboy's Avatar
Some more pics for you;
My RCD controller for my Mosconi DSP is also here now...this will control the volume, presets, subwoofer level etc...It will be fitted into my ash tray area with some modifications...
Ash tray cover still closes fine (ignore the cable, its just to test fit the RCD)
Also changed my orange front indicator bulbs
Old 23-04-2013, 11:34 AM
  #61
dojj
Resident Wrestling Legend
dojj's Avatar
at least you know what you are doing
very very nice, and it's very subtle as well
any engine mods on the horizon or are things staying at they are?
Old 23-04-2013, 08:22 PM
  #62
bassboy
bassboy's Avatar
The audio is currently on hold until I sort a few bits out...but it is working
- not sure if the link will work as YouTube are moaning about copyright!
Next up I wanted to freshen up the bodywork a bit...a friend of mine wanted to use my car as his wedding car, and I HATED the amount of swirls all over the car etc...so I decided to wet sand the car
Unfortunately I didnt get too many pics of the paintwork before hand...but below are the ones I did get
You will have to tune in tomorrow to see the results
Old 23-04-2013, 08:26 PM
  #63
bassboy
bassboy's Avatar
We are playing around with the map at the moment to delete the DPF and cats etc...we have tried a few different maps but as we are trying the DPF delete for the first time, it keeps going into limp mode...no biggy just got to keep trying until we stop it from limping...
However, for the short time it does work before going into limp mode, its an ANIMAL! fish tails in second and third gear LOL!
More of that later though lol
Old 23-04-2013, 08:34 PM
  #64
dojj
dojj's Avatar
you are one brave man to do that
Old 24-04-2013, 10:34 AM
  #65
bassboy
bassboy's Avatar
haha
its all part of the job mate!
Old 24-04-2013, 02:49 PM
  #66
COSSIEGAZ
COSSIEGAZ's Avatar
Cars coming along nice, like the iPad install, we're you not tempted to use a Headunit in the glove box to run the iPad and signal to the amps? What's the likely hood of signal interference using the Bluetooth? Shouldn't get any as its like pairing the phone.
What did you use to secure the iPad in place? I've seen a company in America that inserted little magnets into the facia and seemed to work really well and also meant you didn't need to do the cut out like you did for the button.
What amps are you using?
Old 24-04-2013, 02:58 PM
  #67
smitsturbo
smitsturbo's Avatar
ive always like the shape of these
Old 24-04-2013, 08:12 PM
  #68
bassboy
bassboy's Avatar
I only managed to get the bonnet and the roof done as I ran out of time...but heres the results
As said, before it was like this all over
Wing shot - Before
During
After
And ready for the wedding
Randoms
Old 24-04-2013, 08:14 PM
  #69
Kam B
Kam B's Avatar
Oh man do my car Please! !
Old 24-04-2013, 08:39 PM
  #70
Carlos-Titx
Carlos-Titx's Avatar
That is amazing!
Old 24-04-2013, 09:37 PM
  #71
Fudgey
Baby Cheesus
Fudgey's Avatar
fucking hell!!
great job there mate!!
can i ask tho, did you just literally sand the car paint that was it?? or did you mop/polish it etc after??
the paint on my scoob is swirled like a cunt, but i think id be a bit scared going near it with the 80 grit
although im sure you used something like a 2000 grit lol
Old 25-04-2013, 04:53 PM
  #72
mikej857
mikej857's Avatar
2000 grit, then would have been compounded/polished and waxed to get rid of all the swirls and marks, on most cars this would be the last resort as a routine cut and polish with a rotary buffer would get rid of most marks
Old 25-04-2013, 04:55 PM
  #73
bassboy
bassboy's Avatar
Originally Posted by Fudgey
fucking hell!!
No no, the process was - 2000, 2500, then 3000 grit sand paper, then machine it with a rotary, wool pad, and cutting compound (Megs ultra cut in this case), then medium polish pad and Megs finishing polish, then Gtechniq P1 polish on a finishing pad...then stand back and admire!
Its a VERY time consuming process though - the bonnet took 5-6hours, the roof took 4 hours!
Old 25-04-2013, 04:56 PM
  #74
bassboy
bassboy's Avatar
Yes but machining doesnt really get rid of orange peel, which is what I wanted to get rid off more than the swirls...it just so happens that I get rid of swirls and orange peel in the same process lol
Old 25-04-2013, 05:23 PM
  #75
dojj
dojj's Avatar
that is very awesome
Old 25-04-2013, 07:02 PM
  #76
Fudgey
Baby Cheesus
Fudgey's Avatar
Fair play mate i thought there would be a lot more to it lol
So if you just had a shit load of swirls you wanted rid of, would you just machine polish it?
Later in the year i might get a rotary and give it a go lol
Old 25-04-2013, 07:56 PM
  #77
NEIL A
NEIL A's Avatar
Stunning work and very brave to set in about a car like this with wet and dry
As your probably the best person on here to ask , what sound deadning would you recommend to cut down on tyre drone on my focus RS. I'm running 888's and the noise from the rear is really bad at motorway speeds.
Old 26-04-2013, 03:04 PM
  #78
McGoo 69
McGoo 69's Avatar
youve done some awesome work here mate, i love the ipad conversion
if anyone see's this merc coming upto them at the lights blasting the bass they will think there gonna get a drive by haha
Old 27-04-2013, 08:07 PM
  #79
bassboy
bassboy's Avatar
yes pal, just machine polish if its just swirls, im only wet sanding is as I want to get of the orange peel
Old 27-04-2013, 08:13 PM
  #80
bassboy
bassboy's Avatar
Cheers mate, for deadening, the ideal way to go round it is;
Sound deadening - 2mm Silent Coat is the best VFM product
Gladen Audio Neoprene - This will decouple the metal of the body and act as a noise barrier and help absorb noise. Its light and weighs nothing. Its a closed cell foam.
Mass loaded vinyl - This absorbs noise the most but is not effect ontop of the sound deadening alone, it has to be on a foam.
You can start one thing at a time, try the deadening first then work from there...mine was relatively quiet at speeds
Quick Reply: teamSPB's New Project...Mercedes CLS...iPad mini, hydraulics, 20's!
