Escort van conversion
Old Jan 30, 2013 | 02:36 PM
paulw8495's Avatar
paulw8495
Default Escort van conversion
I'm thinking of doing a conversion and would like some advice if at all possible. Would a ford escort rs 2000 4x4 running gear swap over onto a escort van and helpful advice would be great many thanks paul
Old Feb 6, 2013 | 07:02 PM
phil barnes's Avatar
phil barnes
love to see it done cant help you out sorry
Old Feb 6, 2013 | 07:04 PM
maxwax's Avatar
maxwax
you will prob need a tunnel mate for 4x4 gear it can be done.
Old Feb 6, 2013 | 07:11 PM
STeve's Avatar
Super Moderator
unless your sh*t hot at fabrication stick to 2wd
Old Feb 6, 2013 | 08:10 PM
gavrwdfiesta's Avatar
gavrwdfiesta
i disagree with you there, a pal of mine is doin this atm using a
capri rear axle and standard tunnel,
not sure what diff ratio hes goin for tho, it can be done simply
ive not seen it done with the 4x4 beam tho???
Old Feb 6, 2013 | 08:14 PM
Smudge374's Avatar
Smudge374
I think the 4x4 would be problematic, however the 2wd system should work and has worked in the past, it all depends on what depth you want to go from, eg fabricating certain aspects etc.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
3dr cossie
Sep 2, 2015 08:58 PM
Bighandsuk
Sep 2, 2015 05:23 PM
