Aubergine Series 2 Resto/Project
So early last year I went to look at buying an engine for my sport (was a freshly built cvh with a few bits n bobs with it), in the corner sat his black series 2 looking rather sorry for itself.
The engine was built to go back in the guys s2 but he said he lost interest after the rust started hitting hard n he was going to scrap the shell as it was too far gone for him
After a good look over it the deal was done....(nice little project...I thought)
The day I was picking it up was the day a decided I would try and chop my fingers off and cut through 90% of my nerves/tendons in my fingers
So a couple weeks on (i got it)
Here's where the stripping started to see exactly what it was going to need, so out came the interior
We moved on from there to have a look at the front end.
Then the decision was made, wings, cross member front panel etc so went onto removing everything
...how many of you have ever found this in your sills??
Yup expanding foam
Yup expanding foam
Finally it was time a look at the roof
After another weekend went by the boys were back around to help strip out the roof and laugh at my misfortune
As expected, totally bolloxed
also looked like the sunroof had had it aswell so out that came aswell
I dont exactly want a sunroof anyway (as its another place which will leak lol) so now im in two minds whether to have a carbon roof fitted or have it plated strengthened and skimmed
As the cars currently stripped im just going through tidying bits up starting with the loom, running new wires where needed n removing where not!
The car was running MFI but i plan on eventually converting it over to EFI so iv decided to make the MFI loom completely separate to the rest of the loom
This is the MFI side of the loom, it now has about 8-9 connectors so its plug and play to remove from the rest of the car loom.
Will add the pics of it all re-wrapped and looking a lot neater later
90% finished
Going to be changing the relay holder, wiring and using a better relay! O and still need to put the earth points in
Last edited by Jamie_EscortSport; 07-01-2013 at 09:17 PM. Reason: needed to add more
Here are some of the shots from when the car got picked back up after being stripped (mainly to get it out of the great weather we had an put it inside) also gave us a chance to have a decent look underneath
and a couple of the rear arches
also had the sunroof tray removed as it was massively foooked
Hopefully work starts properly on it in a couple of weeks so will have all up to date pics
have loads of other bits still to do to the rest of the bits though
Done a bit of 'tarting' on the fuel tank
Gave it a good look over before and seemed all good
once it was cleaned down to remove the crud etc, gave it a coat of 'red oxide'
And finished it off with a coat of black 'Hammerite'
Spent some time today cleaning up and spraying some odds n sods
Quick dusting of silver paint
And done seat runners
And lastly gave the seat belt bits a clean up aswell
'89 Series 2 Resto - More parts arrived
Had a couple of other bits and bobs turn up ready for when the shell is done...
Also the cage ready to go in
And the strutt braces which just need powder coating to match the cage (mags in place so mate could get an idea of size , no tape measure to hand)
So spent some time cleaning the brakes up today
Also picked up a Innovate LC-1 Wideband Controller
Also had update on the shell, work has started...will add pics up soon
Heres a few pics i was sent from the bodyshop.
And the structural brace supports going in ready for the rest of the ROT to be cut out
Will have some more pictures through the week!
Will try and get all the suspension off whilst its up to get that all powder coated and give the shocks a nice lick of paint.
Sy you have no idea mate lol, least ill know everything will be cut out and rust free once its finished (fingers crossed)
Jeez that is proper fooked. Going to look good once its done. Think a carbon roof should deffo be put on order.
What make is the cage(looks like safetly devices) and did you pay the Ł630ish they are asking for it?
safety devices, nah I dint mate LUCKILY
Yea from everything I heard/been told about them, they are the ones to get!
No mate sunroof has gone! It'l just be another place for the rust to come through lol
CheeRS for the comment Smiler haha I must be well established in the rust club with this car
Good luck with the project m8
I remember my brother doing alot of welding work on a lads s2 back in the late 90's the sunroof was falling out after the drain tubes got blocked.
Thanks pal!
Yeaa tell me about it, Rot for a past time...looks like its getting to a point where everyone wants to get rid of their sunroofs
Just a small update
Had the rear light seals turn up yesterday and the calipers all dried and ready to go back together.
The update on the actual shell - the inner sills have been cut out n being prepped for the new ones to go on, will post pics hopefully in the week
Bit more progress on the car - inner sills are off out and now back in
Also started on the small section on the passenger floor
We are getting there
So the inner sills are on and the n/s outer sill is done
The passengers floor section is also finished
The passengers rear inner and outer arch has now been cut ready to fit the new ones
measuring up ready to cut
Also the innrr arch cut out
Cheers for the comments! ....definitely got loads to keep me busy lol still got bits I need to clean up n paint etc but atleast the shells getting there
