Aubergine Series 2 Resto/Project
#81
Known VW hater
That front arches have studs but good luck finding a kit with them all still there (luckily this kit did, someone drove in the side of my mates minter so i took the kit)
The rear arches will be bonded on once painted.
yeaa mate soo happy it now looks like a car again been a while
i spose i should get arond to starting a thread on here haha
#82
yea do it ill keep an eye out
#86
noooo im not a fan of matte black...but its does actually look quite cool
hopefully if the colour goes well it should be slightly different
#87
So since the last post the car has had its final coating of primer and now back in the booth stripped back down to be painted in the morning!
#89
Thanks for the comments guys!
Whilst the rack and column were out for the spray I gave everything a lil clean up and chucked a new bush kit in with it
#97
Cheers for the comments guys, will try get some decent pics of the car when its out the oven to really show off the colour, Really impressed with it
#101
Your right there Lee, throwing it away did cross my mind one too many times
Here's a pic that shows off the colour pretty well, will upload more as and when I can get her in good light
...Aubergine
...Aubergine
#105
CheeRS, have been up the workshop tonight clearing everything ready to start the rebuild, getting a good pic of the colour in that light os proving difficult so when I go up during the day ill drag it right out in the daylight n see what I can do
Umm good question mate?! My work was priced as a job lot so wouldn't know off by heart. ..cheap job from 600-700 anywhere up to and beyond 2k
#108
Cheers mate, iv always loved the cossie's in that colour so thought if give it ago on this
thanks yeaa she's slowly getting there just cant wait for it to hit the road now
#110
Small update today
Had a nice surprise in the post eArlier...300mm setup
First things first, the strip down ready for a good clean-up
The carriers have to sent to the acid bath (saves time) n wil give them a quick lick of paint
The discs will be lathed on the car just to remove the surface crap and also sets everything true to the hub runout
Few other odds on order which should be coming next week
#111
Once the cars roadworthy and I scrape back some money ill be building my other RST engine to around 300 (is the plan)
Cheers, wanted something slightly different so cossie aubergine it went
#116
Progress on the brakes -
This weekend was spent finishing off the brakes, awaiting on the stud and nut conversion to turn up which should be here Monday so will be cracking on with that this week.
couple pics of the brakes going on
Bolted everything up and refitted wheel just to double check
...then once everything was cleaned up and had a lick of paint
The discs are soon to be lathed once everything else is done and i can get here to work to use the procut
Have also had the rear brake valves turn up so they've been stripped cleaned up and the bracket and valves have been painted up
Hopefully i can get the valves and new M/C fitted up this week and make a start on re-brake lining the car
Last small update
Had a few bits turn up from 'car parts express' so went about fitting up the wipers with new bits and got those fitted up
Last small update
#120
Alright mate, hows tricks its been a while?! Still got your saph?
Im hoping it'l be ready to take to RS Central, but being realistic im kinda questioning that...if not hopefully she'l manage classic ford all money dependant of course
