J18 COS Cosworth rebuild and restoration
Old 08-06-2015, 04:37 PM
  #441
Received 1,044 Likes on 998 Posts
Nice to speak to you and Jeff yesterday matey.
Well done for coming first. You and the car deserve it.
Cossy Mike (08-06-2015)
Old 08-06-2015, 05:06 PM
  #442
Cossy Mike
Cossy Mike's Avatar
Aye mate was good to see you, thanks!
Old 08-06-2015, 05:18 PM
  #443
Paul_RS
Paul_RS's Avatar
Cars looking awesome Mike!
I'm going to say it now - RIP 3rd gear
Also why do you need an external swirl pot? Unless you are tracking the car I was under the impression the standard intank pot was fine? I've certainly had no issues all the years my car has been running the same power as yours?
Old 08-06-2015, 05:36 PM
  #444
Mark RS
Mark RS's Avatar
Originally Posted by saphcosmike
I'm looking to make or buy one of these to weld onto the clutch arm, does anyone have an idea on what to get and use.
I was thinking along the lines of a steel bar cut down and partially drilled?
I just used a nut for mine and got that welded on.
Old 08-06-2015, 09:24 PM
  #445
Cossy Mike
Cossy Mike's Avatar
Thanks!
I have been warned about the box though I am going to fit an AP 6 paddle and hydro conversion and drop the AB07 cam in and go back to Karl for a map tweak, 400 and a broken box here we come
The tank is aftermarket with metal swirl pot, I've read lots about them surging so was going to play it safe a fit a swirl pot.
Also if I simply replace the std pump ill have to cut the original connectors off and fit ring terminals
Old 08-06-2015, 09:29 PM
  #446
Cossy Mike
Cossy Mike's Avatar
Would the nut once welded on the arm screw into the slave rod to connect?
Old 08-06-2015, 10:26 PM
  #447
Mark RS
Mark RS's Avatar
It dosent screw in its just to secure the rod in place.
Old 08-06-2015, 11:21 PM
  #448
Paul_RS
Paul_RS's Avatar
Thanks!
Karl modded Marks tank and fitted a swirl pot of his own design inside it. really neat job! Probably more expensive than putting one under the car though.
Cossy Mike (09-06-2015)
Old 09-06-2015, 06:06 AM
  #449
BRAMMER
BRAMMER's Avatar
The slave rod locator can be something simple like the head off a M10, 12 cap bolt
Old 09-06-2015, 12:35 PM
  #450
Cossy Mike
Cossy Mike's Avatar
Thanks Chris, think I've sussed it now
Old 09-06-2015, 12:36 PM
  #451
Cossy Mike
Cossy Mike's Avatar
Yeah probably.....think I'll run it for now as it's never surged yet. No point in fixing something that's not broke.
I'm thinking that the problems lie with the aftermarket pattern tanks with no swirl pot inside at all
Old 09-06-2015, 04:43 PM
  #452
fezzajsy
fezzajsy's Avatar
Well done mate
Old 09-06-2015, 05:22 PM
  #453
timotei1980
timotei1980's Avatar
Mine surged when on track with a pattern part tank so it depends what your going to use it for. Was annoying because I could of probably got the original repaired but a couple of tank refurbers asked at the time said it would be more cost effective to but a new one.
Old 09-06-2015, 05:31 PM
  #454
Paul_RS
Paul_RS's Avatar
I binned my original Ford one a couple of winters ago from and aftermarket one with a metal swirl pot. It's been absolutely fine, no different at all from the Ford tank.
Cossy Mike (25-06-2015)
Old 09-06-2015, 05:32 PM
  #455
Cossy Mike
Cossy Mike's Avatar
Originally Posted by fezzajsy
Well done mate
Thanks mate
Ah ok, I'll have to wait and see what happens then, I'd like to fit one anyway as I'll be going 044 pump
Old 13-10-2015, 10:45 AM
  #456
Cossy Mike
Cossy Mike's Avatar
Well that's it for another year, all tucked up this morning, winter wheels on and fuel drained.
Plans for next year, AP's are going on with a Reyland kit, new branded tyres, wheel refurb and maybe a SECS monitor, roll on the summer !
Old 13-10-2015, 11:56 AM
  #457
Staffi
Staffi's Avatar
Best driving weather's coming up for them now Mike, cold = dense air, Cossies love it
Cossy Mike (13-10-2015)
Old 13-10-2015, 12:07 PM
  #458
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I swapped my original ford tank with the large plastic surge tank and fitted a newer aftermarket one with a metal surge tank. My car was running 500bhp and the tank fed a 044. Never ever had surge with the genuine tank. I only changed it as I aero quipped the new one. First drive from work to home it surged like fuck. Had to fit a swirl pot in the system to cure it
Old 13-10-2015, 01:01 PM
  #459
carl/saff
SIERRA RS 4X4 COSWORTH
carl/saff's Avatar
Love the look of the toyos on standard rims
Old 13-10-2015, 06:29 PM
  #460
Looking well Mike. Im still using mine. Like Staffi/Pete said these cold days are mint for cossies.
Old 13-10-2015, 07:13 PM
  #461
costina
Live long and prosper!!
costina's Avatar
mike you need to pm me about something i wanted off ya
looking good mate wish my std alloys looked like that.
Paul
Old 13-10-2015, 07:35 PM
  #462
Matty_C
Matty_C's Avatar
have you drained your petrol tank before storing away? I thought it was advisable to fill it right up which is what I have done in order to prevent condensation causing rust to the tank.
Old 13-10-2015, 08:36 PM
  #463
Cossy Mike
Cossy Mike's Avatar
I've left about a litre in it as it'll go off.
If it was in a sealed Jerry can fuel can last forever. So I'll brim it with fresh Vpower in April.
Not heard of the tank corroding before though there are a million theory's on the best way to store a car, suppose it's just what your comfortable with or what works for you
Old 13-10-2015, 08:41 PM
  #464
Cossy Mike
Cossy Mike's Avatar
Paul
Remind me on mate? Was it the billet spacer?
Old 13-10-2015, 08:42 PM
  #465
Cossy Mike
Cossy Mike's Avatar
I'll take your word for it
Old 14-10-2015, 04:30 PM
  #466
Comic.
I read an article in fast ford mag and it said high octane fuels go off after 2 weeks???
Old 14-10-2015, 05:10 PM
  #467
Cossy Mike
Cossy Mike's Avatar
Comic.
If exposed to atmosphere I would agree. I know it definitely smells different after a few month
If it's in a metal jerry can, it should be safe for at least a year
Old 14-10-2015, 05:29 PM
  #468
costina
costina's Avatar
Front ambers
Paul
Old 14-10-2015, 07:55 PM
  #469
Cossy Mike
Cossy Mike's Avatar
Front ambers
Paul
Ah, I didn't think you wanted them, I gave them away :/
Old 14-10-2015, 08:34 PM
  #470
costina
costina's Avatar
No worries Mike thanks anyway.
Can i have your wheels instead?
Cossy Mike (11-12-2015)
Old 11-12-2015, 07:05 PM
  #471
Cossy Mike
Cossy Mike's Avatar
took me ages to find them
Old 11-12-2015, 07:17 PM
  #472
Cossy Mike
Cossy Mike's Avatar
Car hasn't moves since September so I've started stocking up on bits for next year
I ordered the bit's off Martin at Reyland on Wednesday lunchtime and received today, first class service, thank you
and I've decided to get the wheels done in anthracite for next year, new look
Old 11-12-2015, 07:25 PM
  #473
I still prefer the silver wheels. I think you should give them brakes to me to test out lol.
Old 11-12-2015, 07:31 PM
  #474
cozzy jeff
cozzy jeff's Avatar
love them brakes,make mine look tiny.
anthracite all the way for the wheels,Glenn doesn't know what he's talking about
Old 11-12-2015, 07:48 PM
  #475
Anthracite was so last year lol.
Old 11-12-2015, 07:54 PM
  #476
The Youth.
The Youth.'s Avatar
Nice brake kit, are those 5570 calipers?
steve
Old 11-12-2015, 08:01 PM
  #477
Cossy Mike
Cossy Mike's Avatar
Old 11-12-2015, 08:02 PM
  #478
Cossy Mike
Cossy Mike's Avatar
steve
No Steve they are CP7040 for 362x32 discs
http://www.reyland.co.uk/calipers/
Old 11-12-2015, 08:12 PM
  #479
cozzy jeff
cozzy jeff's Avatar
silver alloys have been forever
Old 11-12-2015, 08:22 PM
  #480
The Youth.
The Youth.'s Avatar
right your wheels must be 18th then didn't realise
steve
Quick Reply: J18 COS Cosworth rebuild and restoration
