Its up to you . If you want in your face (not that you need to advertise them )
go gold (scooby gold) or red
If you want them to blend in a little keep them black or go silver
Modded down pipe to accept v band . Added lambda boss and wrapped down pope but run out.
Andy getting more sent down
Down pipe back exhaust system all done just needs wrapping
And started on turbo damper
Hyd clutch mod/pipework soon
Superb work but what the hell is that in the above pic I'm seeing with a plate of food on the trailer.
Its the stainless steel turbo damper that my best friend has tig welded
As he fabricates stainless steel commercial kitchens he has a team of fabricators
Lol there angled supports either side of all three doors
He's a lucky lad having a three car garage
Its a very quirky house with flowing sloped roofs looks oriental ish
well what an eventfull day
Coley and i have been trying to get the focus running all afternoon and hit a few problems along the way
but we kept swapping bits out onto coley's car to eliminate them and started looking at the engine loom we found one of the relays wired differently in the plug,the inlet cam trigger was 30 degrees out and one of the pins in the crank sensor plug had pushed inside the plug not making a connection
but we perserviered and here was the moment of truth
we had a few little issues with fuel pressures and spark plugs but got it idling and sounding great
massive thanks to coley and rex for there help today
It has been a good day Dave I still cannot beleve we were in the tat yard for 3 hours lol
Still it was good to get andys motor running today there is now light at the end of the tunnel again
Getting there now just a few sensors to get and fit. Re bleed brakes.few hoses fill with anti freeze . Quick check over and it'll be off back up to you m8
