chop top mk2
#81
tried the rear wheels in the frame today, all seems to fit ok.
i want to run a 12" or 13" wide rear wheel down the line some where so as you can see i have plenty of room. would like to run a 305 or 335x25x22" rear tyre.there will also be a prop shaft loop back and front . ( you never know ).frame will be at garage next friday
#82
bit more done.
engine and gearbox mounts arrived this week, range rover engine mounts and r380 gearbox mounts there a bit bigger than rover sdi mounts.
more soon,
tony.
more soon,
tony.
#83
Lucifer II - 666
This is looking like it'll be brilliant car when done.
#84
gearbox mount done.
got frame sat on jig tonight, got to get rear axle set in place so i can get rear diff mounting plates designed so they can be cut next week.
more over the weekend.
#86
cheers mark, few more pics.
set the diff in place so i could sort the mounting plates, came up with these
more at the weekend.
#90
#91
yeah cheers, was always going to be tight for space, not so bad at the rear but the front is going to be a nightmare.
long day today but got the rear axle in place, heres how i did it.
and with the wishbones and hubs all in place. still got to tighten all the nuts and bolts but at least its one step closer.
#93
bit more done today.engine, gearbox and front crossmember set in position today
more tomorrow.
more tomorrow.
#96
big update today. got the front chassis rails tacked in place, put front suspension on and bolted the wheel
we even have more than enough lock to lock when the wheels are turned.got 1 more full day to attack it tomorrow, so more tomorrow.
#100
got rear wheels on today, few more pics.
got to take engine and box out tonight to fully weld the frame and sort all the mounts out.more later.
#102
engine and box is now all mounted , started to make a support frame for the turbo as i dont want any issues with the manifolds cracking due to the weight of the turbo.
#103
now got the rack mounted with just a couple of mounting bolts to add.
just ordered 2 flexi joints so i can carry on with exhaust , loads to do, more soon.
#119
