BIG TURBO'd focus 'RS' is now back home!! :D
#41
not revving mine that high, no need to, making the power nice where it is lol
looking at your sig.. are you now on a GT30?? and still runing an actuator?
#43
ill be happy enough once it sorted and running 2.0bar all the way with this turbo. should still do near 500hp anyway
#47
YES I KNOW I CANT SPELL
he was running an underdrive pully kit that was put down to the problem. after rebuild/fitting standard pully it ran fine up to 430hp with a 7200 rev limit
#49
Whats your spec bigad??
Mine in bits again at the min, just ordered a billet pump as i want to rev it to 8k now,
And when we uped the boost, we got to 1.7 bar-586bhp/520lbs and we were getting really bad valve float so having it modded by ian howel now to use double valve spring, then take it up to 2-2.5 bar and rev it out to 8k and see what happens
#52
Its always going to be a worry yes, but i run an inline turbo filter, so if it does go lets just hope its a case off a good clean and new bearings and new pump then at least its not going to be that expensive hopfully it obviously is a blacktop based oil pump so just cross fingers,
After speakng to ian howel he said the ones hes known to break up have always been one where they havnt balanced the bottom end or changed pullys..
Just have to wait and see,
Also tempted to fit a accusump... But! Dont want the engine pump to fail and just be relying on the accusump while unknowing, if that makes sense?
#55
1 Post
Its a shame what happened to him and his car a while back or he'd be well on the front of top powered Focus'
#56
i run a blitz id3 boost controler, i could wire somthing into that so that it would CUT BOOST if pressure failed
it says he is from doncaster, only silver focus i can remember use to be around bolton/goldthorpe area (rotherham near donny), and it use to boogie!! at the time i had a s2 zetec turbo,
#58
Bodger of Blackburn
it wouldn't take long for that to build up pressure really.
along those lines, best to fit a relay to cut out the power to ecu if pressure is too low. have an override from ignition feed so when you're cranking it powers the relay, until you let off the starter and the feed would come through the pressure switch to relay.
easy to make something like that work.
#61
some oil pumps are lazy so would be cranking for a wile befor it starts lol. my kms ecu has an oil presure input so i can set parameters
like any think over 800rpm and under 12psi presure will cut coil ect
i can also run a cool display like this one
http://www.youtube.com/watch?v=MpXp2657kYM
#62
Ian built mine, but I had an accident in it at 170+mph and broke my back
Im near you, so give me a shout if you want a pint and a chat one day
My engine still lives and is sat in Ian's garage, It will give you a run for your money when its finished and back in a car lol
The reg of the car its going in is T800 BHP
#63
Also this would be good incase of any oil surge,
I also have a boost cut set in my blitz if my water temps exceed 108 degs (i run a 72 deg stat on mine now)
#64
have a look on Ians Website mine is still on there.
Glad your still alive after what happened!
I rekon i should pull maybe 620-650 somwhere in mine,
And maybe towards 700 when i use vp import
#65
Now then pal coming round on the 7th will be fine and our billet pumps are on the way from the states.
#66
My dta has oil pressure input too and i also have a stack dash, but ratyer than cut the coil and loose all power, i think id sooner let the blitz just cut all boost so if im "on it" and suddenly loose boost i know about it,
#68
Mine's in front of me and beeps and flashes when it drops. I still don't think that's enough!
External oil pump is next...or a Blacktop!
#70
Not sure if I'd want just the boost to cut out, engine revs alone will kill an engine with no oil circulating!
I'd love to see a Zetec push that. I know of a 2.3 stroker crank, Nikisil linered, big spec GT35 turbo Zetec being built that's aiming for that kind of power.
545@1.5 bar
586@1.7 bar with valve float...
So carry on to 2.5 bar and add some vp import fuel so i can still get a bit of advance timing in on top end then...... Thats if the engine will hold 2.5 bar!
Knowing my luck the crank will drop straight thru the sump
#72
Bodger of Blackburn
at least i have a blacktop to begin with, settles me a little.
some big figures around for power on here, i'd love to have something to handle it all.
#74
Lucifer II - 666
Very impressive car and engine performance
#77
I saw the car the other day whilst up at the garage. The spec has been changed slightly, he's got a billet oil pump now, he bought my GGR ported head and has had some work done it it. There is a rumour of a turbo change too. I'm sure he will post soon on any updates. I will text him soon and get him to update.
#79
little update,
as jon said, i bought his GGR head off him (well... bought when i pay him lol )
and sent to ian howel for double valve spring conversion,
still waiting for that to come back,
billet oil pump to go in it,
and sold my GT35 turbo in favour of a GTX30 turbo, and changing injectors for some injector dynamics 1200 cc
hopefully next dyno session will break 600
