Help fiesta puma conversion!
Old Jul 20, 2011 | 11:56 AM
Cj fiesta's Avatar
Cj fiesta
Default Help fiesta puma conversion!
Was just wondering if i need the transponder ring with the key and ecu ? and also is it possible to wire digi dials into a analogue (muff) ecu ?
Thanks Cj
Old Jul 20, 2011 | 12:22 PM
Cj fiesta's Avatar
Cj fiesta
please guys i need help
Old Jul 20, 2011 | 01:07 PM
lacey's Avatar
lacey
I done the conversion and ended up gutting the puma for bit and ended up with the hole car loom put in to a fiesta zt s , wouldn't have even bothered if I didn't have a donar car , that was over a year ago and it's been prob free ( touch wood) I am now considering selling the car now.
Old Jul 20, 2011 | 01:21 PM
Cj fiesta's Avatar
Cj fiesta
ive got the full loom but just wondering whether or not i need the transponder ring or if i could leave my fiesta one on. im doing the conversion it the fiesta 1.3 finesse mk5 has been the most stressful few days of my life. anyone know if its possible to put digi dials on a analogue ecu ?
Thanks
Connor
Old Jul 20, 2011 | 01:36 PM
LukeDaisley's Avatar
LukeDaisley
you will need to change the yellow ring. as it is coded to the puma ecu.
Old Jul 20, 2011 | 02:01 PM
Cj fiesta's Avatar
Cj fiesta
i dont have the yellow ring as i bought the ecu seperate any advice ? :/
Old Jul 20, 2011 | 02:52 PM
LukeDaisley
im pretty sure it will need coding then.
Old Jul 20, 2011 | 02:56 PM
Cj fiesta's Avatar
Cj fiesta
looks like an auto electrician jobby then :/ cheers for the help mate
Old Jul 20, 2011 | 03:41 PM
LukeDaisley
its an easy conversion if you have the same year puma and a zetec fiesta. there was a step by step guide in fast ford not too long ago.
Old Jul 20, 2011 | 09:14 PM
stoke7up's Avatar
stoke7up
pretty sure from past pumas the ring is not coded to anything its just a sensor, as long as the loom is right for the ecu and chip then it will work.
Old Jul 20, 2011 | 10:01 PM
Churtz's Avatar
Churtz
+1. Done this conversion a couple of times. The ring isn't coded, that's just the sensor for the transponder. All you will need is the key chip to match the ecu.
As for the mix/match loom it really is more hassle than it's worth. You could buy the correct ecu and engine loom for your vehicle for about £100.
I've heard if someone getting a conversion running in the same position as u, but the digi dash never worked as the ecu couldn't control it.
Think....buy the right bit and it's plug and play
Matt
Old Jul 21, 2011 | 02:42 AM
Cj fiesta's Avatar
Cj fiesta
good advice ill run it on analogue clocks for a bit then get the digi dash ecu and just splice plugs in the plug into the clocks thanks for the help everyone
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Steve Escos
Oct 1, 2015 06:57 AM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
