Thanks to my mate dropping this off last night got this piper 285t2 fitted it today just gotta time it up on monday seen as I left the cambelt at home :-( :-( :-(
looks loads better with the new on in, when will you be fitting your new intercooler?
Originally Posted by AJC
nice one mate
thanks peeps!!!
hope to have a play in my lunch times as the cars in work,still need to get a few bits throttle body gasket an throttle cable bracket an engine mount out will be sortin over the box exhaust manifold now aswell
will look good with the new cooler fitted g do you have to chop any of the bumper out to get it to fit?, posted the sensor out on thursday so you should get it soon
will have to cut a lil bit out but not as much as i thought i would have to nice one on the sensor!!!!!!!
Originally Posted by CrOwSoN15
Cracking little motor, top work mate!
I must say, I really like the wheels, makes a nice change! What are they?
seen as there wasnt much work in today i cracked on the last few hours of work tidying wireing an just aRSein with the car got the front mount fitted with out cutting the bumper so made up there just moved the rad back a bit
now the question is what to do with the front bumper to aid the airflow to the cooler?????
am leaning towards cutting holes along the center bar
seen as the bumper was blockin alot of the cooler i wasnt happy with is so set about cuttin holes in it with hole cutter 73mm an this is how it ended up ,hope to be fittin the oil cooler tomorrow all going well
few more bits turned up today two boost pipes an one hose just waitin on other silicone hoses, an with a bit of luck the lad is poppin in tomorrow to look at sortin the over box manifold
good work mate , you should of said you were in the market for a proper manifold!
thanks mate, didnt plan on going over the box but you know how thinks are an gettin carried away , so much for it been quick engine change an stayin every day car lol
paul turned up with the manifold he fabed up its just tacked up for now to make sure it all fits where it needs to so tomorrow job is battery tray out an sor the tail part of the manifold
