Mk4 Escort Pop Project
#41
Ford Nut
That does't fill me with excitment knowing this car is until I had it 100% unmolested & original. Lets hope the srpings are an easy thing to do next week - Yep I'm doing them next week!
Meanwhile back at the ranch;
Got the rear Recaro's from a mate last night so hoovered them off and whacked them in, now all I need are the door cards to complete the inside.
![](https://i819.photobucket.com/albums/zz113/Dylans_ZZR600/My%20Mk2%20XR2/My%20Mk4%20Escort%20Pop/SDC14829.jpg)
I put a Cd player with a USB slot in it a while back so I can charge me sat nav & stuff without having to put in a cig lighter. Got a matching rear set of mudflaps too which I'll put on soon, not purely for show but to serve the purpose of not having a build up of mud causing rust in time...
Decided not to replace the engine as it's too echonomical and reliable.
...that's it in the form of mods for my beloved Pop
#45
Ford Nut
Did you find any smoked rear lights...?
I found one, I only needed one because I reveresed into a big lapmpost smashing the light and bumper.. So I found a rear light of the smoked variety on eBay, I don't think it exists because it's been two weeks now and the seller is vague... I got some clear side repeaters and clear front indicator lenses while I was at it, and a new rear bumper which is like the front one; not gen Ford so doesn't fit proper, what a complete ASShole!
The side repeaters don't fit right either but look good. And I can't figure out how to get the front lenses off to replace them with the clears, which I think will clean it up a treat....
![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/wall.gif)
#47
Ford Nut
Cheers mate and yeah I was going to keep them amber untill I seen one with clears next to mine, it totally cleans it up. The o/s one is broken so needs replacing anyway
#51
Hiya mate, just got round this weekend to putting my lowering springs on went for 40mm drop. Everything was going fine until we tried to remove the damper but it was just rust welded in. Wondered if you had a similar problem with yours or if you might have any advice for getting the damper out, I was thinking about getting some rust eater see how that goes.
