throllte body set up
Old Jan 17, 2011 | 05:47 PM
jeff griffin's Avatar
jeff griffin
Default throllte body set up
Does anyone have any instructions on how do the base set up on a fuel injection throttle body SOHC engine?
mine need to be reset from scratch, internet isnt proving much use
Old Jan 21, 2011 | 07:48 PM
jeff griffin
I take it as the lack of replies, no one this forum has a clue, do you only bolt on shiny bits cos someone else has them ?, do you realey know what the shiny bits do ? this seems typical of all forums i look on, even been to shows where they boast about what they have had do by other people, saw one post on here "How do i remove the radiator" its simple, get a haynes manuel and learn to read.
Old Jan 21, 2011 | 08:03 PM
Red16's Avatar
Red16
Nice way to introduce yourself and ask for advice!
It's Friday night, maybe the people with the answers are out somewhere and not on the internet!
You've also posted it in the wrong section... try general car discussion.
Old Jan 21, 2011 | 08:17 PM
Jimmyc's Avatar
Jimmyc
Personally i think the Ford scene is one of the biggest where people DO actually do most of the work on their own cars, it's just most of us aren't stupid enough to risk our engines (that have more than likely cost alot to build) going bang by trying to set up and dick about with fuelling & tuning when were not the experts and would rather pay a pro to do a "propa job!"
Plus if you had waited a bit until a tuner sees this or bumped the thread back up to the top (without acting a bit of a cock because you didn't get a response within 24 hours) for the night time crew one of the tuners may have actually responded! I know Jano from OKC is always very helpful in pointing people in the right direction for one, as is Stu. People on forums aren't here to just answer randomers off the street questions, it's a community too, you get back what you put in
Nice way to introduce yourself and get a descent response
Old Jan 21, 2011 | 08:33 PM
Chaz888's Avatar
Chaz888
OK heres what I did I have a dianostics hand unit when pluged in to my std car setup the base line tps is 16.5 so when I fitted the ST200 body its base line is 18 .0 I could of turned the throttle stop screw back to get 16.5 but had no need to as my idel is controled by the throttle bypass valve and ECU and ran fine as is ,ho and a lot of the peps on here have good knowlege give respect gain respect.
155lee
Sep 6, 2016 11:10 AM
dombanks
Sep 21, 2015 08:38 PM
jamie956
21
Sep 16, 2015 06:24 PM
3doorcozmess
Sep 7, 2015 01:32 PM
turbowag
Sep 3, 2015 08:07 AM
