mk2 escort estate RWD turbo,
#242
few pics of the wiring progress,
started with the 415 amp cable i got along with the 250 amp fuse i need to mount
this one shows the size of he new wire compared to the sierra standard part
all soldered up
then heat shrink added
i then startd on the rear fuse box and the fuel pump and injector relay for the rear next to the battery
few more bits to do but the wiring is not far off now, next time i start it, it will be on the key
i need to make some mounting plates to put them on now and put a new relay and fusebox up front for the rad fans
all soldered up
#249
Just read through it all nice idea for the water rail is your thermerstat housing a std rst one or i have heard people use the 1400 cvh ones on cvh turbos??Good to see the turbo cooler on too was considering one on mine but it would have to be s/h .Steelies banded i think for wheels.
#255
done a bit more over the last week, got the starter fitted again, just need to fit the cable to the alternater
got the extra fuse box fitted in the front for the radio, ecu, and rad fan, next to it is the relay for the fan that will be controlled by a neg switch on the ecu
all ready for the battery at the back, i just need to make some earth straps for the engine and maybe another from the battery to the body to be sure
#259
small update, been working on the water system
moved the turbo cooler to the top of the rad because it didnt quite fit with the antidive kit fitted
where the pipework goes through the inner wing
need to paint up the pipes or may swap to silicone
rs steering wheel and clocks fitted
#264
well iv actually done a bit on it today, i fitted a battery and got it started on all the new wiring so i can start sorting all the charge pipework, and hopefully get my ms on it soon,
only problem i have is it started first time after a few turns and after that it started everytime untill it was cold and now it wont start, im still pretty sure its gown to the injectors being to big so will have to sort some more for when the new ecu comes
#270
few pics of the inlet, not finished as yet
will need to wrap the turbo i think
still have to make some sort of bracket to hold it in position, cable tie foe no tho
iv also done the bottom pipe but its very very close to the alternator so need to decide what to do about it
i have put a takeoff for the iscv just before the throttle body aswell now but im not sure if i should put one in for a dump valve, not sure if i should have one or not? what do you think??
#272
looking extremely good read your write up in the ford magazine ages ago youve come a long way
im having alot of trouble with my pinto turbo build and wondering could you help?
if you look up E648YTT pinto turbo
btw my dad has a few mark 2s with alot of rare parts maybe he would have something you might be interested in
#276
iv now got round to doing a bit more on it, iv tacked up the new 2.5" exhaust from the turbo over the axle to the back, just need to sort a backbox for it, fitted a lambda boss in the new downpipe for the ms ecu, and am just waiting for some exhaust mounts,
i will get some pics up asap
my ecu should be with me soon from http://www.boostmonkeys.co.uk/products.html
its a direct swap for my ofac ecu and am looking forward to getting stuck in with it, i will post pics up when it arrives
next on the list is a wide band kit, does anyone have one they would advise me to get?
#278
i now have my new ofam ecu ready to fit, i will add some pics when i have taken some, just need to figure out how to set up megasquirt now, big thanks to http://www.boostmonkeys.co.uk/products.html for sorting it out for me
#280
to be honest mate i doubt it will be, there isnt to much work left to do now but with the paint, interior and front running gear i doubt i will have enough spare cash to finish it by then, i had thought about re using the old rack and bits but i no i would regret it,
also need to find some where to band my wheels, was going to go for mexico steels but iv decided to keep it on the originals
