mk2 escort estate RWD turbo,
#125
when i bought it it had no engine or box but i fitted it with a type 9 when i mocked up the engine in the bay so i made the sierra mount fit it, but decided to try and mod the mount again because i didnt want it bolting through the floor, so it now fits to the original body mount
#128
the other thing i did which i forgot to picture was on the t5 box the alloy mount that is bolted on it can be moved back slightly and new holes drilled, to make it a bit closer to where the type 9 sits, i still had to reweld the mount and i put a 1" box section to strengthen it up again
#129
few pics of the sump taking shape with an oil return and a return for the breather system
oil return
a picture of the crank blank for the front of the block, i will be welding a pipe on the front so i can use it as a breather again but will also put a semi circle of steel on the back to act as a baffle
then i decided the garage wasnt big enough so went about extending it, will put some pics up soon
oil return
#139
starting to get there again
porch nearly finished so i set about making my front breather
pipe is on the plate but i dont want the crank pushing oil up the breather so i made a baffle on the back
what do you think? it should work ok i think
#145
i have started work on fitting a swirl pot out of my rs turbo fuel tank to my mk2 estate tank, started by cuttin the swirl pot out
cut a hole in my tank
swirl pot out
bracket welded in
swirl pot test fitted
return pipe fitted
rite thats the swirl pot in and fitted, just needs the plate welding on to the top of the tank again, or shall i bolt it????
coments welcome
swirl pot out
bracket welded in
return pipe fitted
coments welcome
#152
tanks welded up and painted, just waiting on a seal for the sender unit then i can get it fitted,
got the breather fitted to the block
sump fitted on
crossmember on
forgot to say its an rs crossmember, thats why there are extra welds
this is how much space is between the unmodified sierra sump and the crossmember, i slightly modified the crossmember but didnt really need it
turbo on and made a start at the wiring
tomorrow i should have the starter fitted and may get some hoses tried out for size,
sump fitted on
crossmember on
#154
i wish it was i sight, still need all the steering for the front and to paint the whole car, doors, bonnet and boot are getting blasted soon then im off work in july so hope to have it painted,
is yours nearly ready to run then? i cant wait to get this started, iv a feeling im going to have problems though
#156
iv started work on the pipework now, and made the main water rail, just need to sort a thermostat for it now
clips fitted onto the innerwing
i should get it painted and the alternater fitted back in tomorrow,
then i will start with the bottom rad hose and i need to make new holes for the heater matrix flow and return
what do you guys think so far?
#159
i been fitting in the heater matrix properly today and trying to finish off all the water pipe runs, im hard piping most of it in 35mm copper where i can, its a pain because the matrix is moved and the turbo is where it now comes through, iv taken some pics and will put them on when i get some more done,
im also having a bit of trouble sorting out the wiring, i think i need to get a remote iscv, but will look into it further
