Series 2 project (with pics)
Old Mar 27, 2004 | 06:13 PM
o n i o n's Avatar
o n i o n
Default Series 2 project (with pics)
Here are some pics of my series 2, which is now about half way through being finished. More pics to follow as the beasts nears comppletion.
She has a rebored bottom end with mahle forged pistons and ground crank, fully ported big valve head, 285t cam and vernier, stage 2 hybrid, front mount large pace I/C, motorsport developments ECU, mongoose 3" stainless, baily oil seperator.
Suspension is koni on front with system2 Kybs on the back with powerflex bushes all round.
Brakes are cossie front and rear disc conversion with braided hoses.
I was gutted when my orion turbo was written off but maybe it was a blessing in disguise
This is me in our disused bodyshop at work.
A few parts waiting to be fitted once I find the time.
Just a bit of wiring to do, she used to run cossy management so I need to wire in all the KE-Jet stuff. Bring on the Haynes manual.
A bit more wiring.
A month with a wire brush and nearly a full tin of seam sealer to make sure all joints and egges are brotected from the dreaded rot before I use eleventy million coats of red hamerite.
Ain't no rust getting in this baby.
I will keep you posted with more info and pics.
Hope you like it so far.
Old Mar 27, 2004 | 06:42 PM
looks mint!!
Old Mar 27, 2004 | 07:21 PM
SAFFYCOSSIE's Avatar
SAFFYCOSSIE
Very nice
Old Mar 27, 2004 | 08:15 PM
wicked mate . have work got any more old workshops they dont want ,i will have one lol ,,,,, wish i had a place like that to work in ,id love to do that to mine ,
Old Mar 27, 2004 | 08:43 PM
is that a RS1600i front ARB I spoted????
Very rare.
Looking good though mate. Power to the RS rebuilders.
Old Mar 27, 2004 | 09:48 PM
o n i o n's Avatar
o n i o n
Cheers chaps.
Deerhunter, better still, It is a ford maindealer.
And yes, well done it is a 1600i set up but unfortunatley I don't have the correct (early) gearbox casing to mount my engine in, so I will settle for the normal 24mm S2 set up.
Just out of curiosity, how much are the ARB's worth, because I have promised it to a mate.
She should be reet nice when finished, but I woll never be able to compete with you ZVH and Zetec boys. It's all getting a bit too expensive and far too tricky.
1600 will have to do i'm afraid. once m developments finish with it, like they did with my orion, she should be enough for most. (I hope).
Old Mar 29, 2004 | 08:37 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Looks stunning mate - keep up the hard work!
Old Mar 29, 2004 | 08:50 AM
Around the £100 mark I think, very rare indeed now adays.
You can fit the MK5 gearbox housing to your box (if that makes sence ) as it uses the same mounting as the MK3.
Someone like www.gearboxman.co.uk will be able to change it all over fairly cheaply.
It was only the MK4 escorts that used the cross member type of support.
Old Mar 29, 2004 | 04:25 PM
o n i o n's Avatar
o n i o n
Doh, Working for ford I should have known you can use the mkv box casing.
I have just rebuilt her aswell because I needed to put some new bearings in and my imput shaft oil seal was leaking.
I also splashed out on some vibra tech engine mounts to stop my exhaust ripping out my turbo bolts. So it probably ain't woth doing now. (bugger).
Cheers for the advice though mate.
Old Mar 29, 2004 | 09:40 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Looks really good mate, and I can't see any rot.
Well Done
Old Mar 29, 2004 | 10:08 PM
Grahamxx's Avatar
Grahamxx
Looks good
Old Mar 30, 2004 | 06:24 AM
BODGE's Avatar
BODGE
why have you ripped out the cozzy management ??? and going KE-jet
mark
Old Mar 30, 2004 | 08:23 AM
looks tidy bruv
Old Mar 30, 2004 | 06:45 PM
o n i o n's Avatar
o n i o n
Thanks for the comments guys it's good to hear.
mark
The car used to run cossy management before I got my dirty hands on it.
I bought it with no engine and no engine wiring.
Which was a good find as I had just smashed up my orion turbo (courtesy of a blind OAP) and was left with a well sorted engine and wiring loom with no home to go to.
Old Mar 31, 2004 | 09:09 AM
John Laverick's Avatar
John Laverick
jessie_rs
Jan 5, 2016 01:16 PM
Bransby
Sep 14, 2015 08:54 PM
Bransby
Sep 11, 2015 09:12 PM
Bransby
Sep 11, 2015 01:09 AM
jessie_rs
Sep 7, 2015 01:27 PM
