What roll bar mounts have you used on the rear roll bar as see you have fitted a Escort/saff one with some alloy blocks..
Are the spacer blocks 100% needed? Could you get away without them? I understand on the saffs/Escos' that they have a raised part on the rear cross member but was hoping I could bolt straight to my cross member.
i've used a escort arb.
i think you need the blocks because the 3dr/saph and escort all have a raised fixing point for the arb.
when i place mine up without any blocks the full arb was sat flat against the cross member and i think it would bang like hell or not be able to move properly.
there must have been a reason why ford raised the fixing points and did'nt leave it flat?
i have the measurements if you do decide to do it the same as me
Cheers bud
I may take you up on that, not sure what im doing yet as I was tempted to swap the cross member but the underside is all painted now so don't want to do anymore cutting/welding etc unless I have to
Cheers bud
no problem mate, just let me know.
Originally Posted by mulla
seen you car mate was looking good never seen you about tho so many people there
i'll have been over at burger king, feeding my face
Originally Posted by rog24
This looks stunning. Will you be taking it too any shows this year?
hope so mate, would like it ready for croft, may be see a bit of track action if there's any track time available
I had a wiring fault with my sm4 Ecu and loom so mark has it.
Mark said it should be ready for monday, so should be running by the weekend. Fingers crossed.
as soon as its mapped mate you can have a run out
might see you up gaz's tomorrow, he's doing a bumper on our bmw.
i was unsure which turbo to buy, i've had the normal t4 then a rb t4 and now the gt30.
its not even mapped for my car or the correct cam in and i can feel the spool much better already.
i can't wait to get it mapped now
