Lotus Exige from page 5
Old 09-06-2010, 12:50 PM
  #41
NEIL A
NEIL A's Avatar
Ive done some data logs before i removed the old parts so once its back up and running i will do the same tests on the same bit of road. This should let me know if the coolers are holding down the IAT's and recovering quicker and also should be able to see if boost is coming in quicker and if the MAF is flowing more air.
Old 09-06-2010, 02:52 PM
  #42
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Lets hope you see some good improvments
Steve
Old 09-06-2010, 03:31 PM
  #43
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Amazing car and some great mods performed, I am watching this topic with interest.
Old 09-06-2010, 04:21 PM
  #44
Porkie
Porkie's Avatar
Originally Posted by NEIL A
Lee are you keeping your one now or still thinking of getting rid ?
I was going to phone wayne at Pro but these coolers came up for a good price with Bell cores and they were fitted and worked well on a tracked car.
Dout i will see much gains with these mods , mibi a bit of an improvement in spool up and low down torque but they will help alot later.
Gettting rid mate. Lent it to Renton for a month. After that, I will get rid of it.
AWESOME cars. I just don't ever drive it any more.
I got it out to take to go to the Ring the other day... thought that would be fun. Battery was dead.. needed replacing... then I thought I will get the tyres balanced for journey over. Turns out all 4 were through to Canvas on inner edge! wounder! so 4 new tyres needed.... didnt have a chance to get em in time. Pissed me off and took Boxster in the end.
So that made my mind up!
Old 09-06-2010, 05:17 PM
  #45
fezzajsy
fezzajsy's Avatar
very nice mate
Old 09-06-2010, 10:35 PM
  #46
NEIL A
NEIL A's Avatar
I did a pressure test from the maf hose through the turbos and coolers up to the TB tonight and got a steady 1.2 bar, so all fittings look good as thats more than i managed on the original set up. I know the inlet to the turbos will never see that pressure but decided to test it just to be sure that all the new pipework is air tight. I haven’t road tested yet as it was late by the time I finished, it is all built back up and is on 4 wheels and has been started and given a rev without any problems.
Lee you have PM
Old 10-06-2010, 10:17 PM
  #47
NEIL A
NEIL A's Avatar
This is a copy of a post on pistonheads by the guy that checked over my data logs and put them into a easy to read table.
Okay so now for the interesting stuff. Neil sent me before and after runs, same conditions (IATs), same stretch of road. The only difference was that he had more weight in the second run, which is a shame because that affects performance, but you can see for yourself that the car is quicker. If we look at the figures below I will explain more [The left side is PRECONVERSION so the right side is POSTCONVERSION. Neil done several runs, so I have checked each to compare, but they are consistent.
1) Each entry is a timestamp in durametrics.
2) Neil was at full throttle on each - I could see this from the throttle position parameter.
3) He was in the same gear
4) He was on no boost at 2100 revs for each of the above, and then floored the throttle, which was shown by the increase in TPS.
Results
1. He is spooling quicker - the boost comes in quicker
2. The boost is higher - in some places by around 0.86 psi - okay that doesn't seem like a lot, but bear in mine the change that has been done her - the pipe and intercoolers.
3. He was quicker through the same gear
4. His AFRs are better. He is running less rich in places. It seems that the DME has adapted, and recognising the greater airflow. This would make sense.
5. His IAT at WOT (7200 rpm) is 6 degress less. His starting position is less by 3 degrees, same AT.
6. Difficult to judge the IATs, because until you go over 150, you really cannot see if they help to stop timing being pulled.
Old 10-06-2010, 10:30 PM
  #48
boothy
boothy's Avatar
Nice work mate,What power ?
Old 10-06-2010, 11:11 PM
  #49
NEIL A
NEIL A's Avatar
Not got a clue on the power over 500 i would think.
Old 15-06-2010, 04:11 AM
  #50
NEIL A
NEIL A's Avatar
Well after doing as couple of hundred miles in the car since fitting the pipework and coolers it seems to have made a change to the way the car drive , in that the power seems smoother and it revs quicker.
Im going to look into fitting some 1bar wastegates to see if i can get the boost to come in a bit earlyer , but thats it fo now untill i go for hybrid turbos and 600+ BHP
Old 18-07-2010, 09:45 PM
  #51
dave cos4x4
dave cos4x4's Avatar
nice mods done to it Neil.
very nice cars.
Old 19-07-2010, 03:02 PM
  #52
NEIL A
NEIL A's Avatar
Thanks Dave I was ment to be at Brunters with it on Saturday but the day got cancelled at the last minute
Old 19-07-2010, 03:40 PM
  #53
KSA-Cossie
KSA-Cossie's Avatar
Nice one neil.
Old 24-07-2010, 10:34 PM
  #54
NEIL A
NEIL A's Avatar
Suspension update....
The suspension fitted justnow is $2500 worth of JIC coilovers and rated realy highly in America for Porsches but just doesnt realy cope aswell with our poor roads. One of my mates who has a serious track 996 has just upgraded his set up so , ive just agreed to take his old Moton Clubsports
Features:
*Seperate Bump (7) and rebound (7) control
*Ride height adjustable
*Unique blow off valve system in remote reservoirs
*Large piston rod diameter for more fluid displacement
*Adjustable gas pressure for added lifting force
*Large main piston for quick response
*No preloaded valve stacks needed for low speed damping control
*Swivel banjo hoses for easy installation of remote reservoirs
And the car they came off
This is why i shouldnt be aloud near a computer or paypal while bored at work, so much for not spending on cars anymore
Old 27-07-2010, 07:21 AM
  #55
NEIL A
NEIL A's Avatar
Any sugestions on where is the cheapest place to get eibach 2 1/4" springs from, think im going to have to change them as the shocks are coming with 680lb front and 910lb rear springs
Old 27-07-2010, 11:39 AM
  #56
Minirotty
Lucifer II - 666
Minirotty's Avatar
http://www.merlinmotorsport.co.uk/CO...221/index.html
Old 11-08-2010, 02:36 PM
  #57
NEIL A
NEIL A's Avatar
I have just got the car up on axle stands to change the suspension over. While the car was in the air ive decided to get a couple of other jobs done at the same time , the wheels are away to be split, repolished and the center colour change , and ive also gave the calipers a bit of a refurb.
Before
After
Old 11-08-2010, 02:55 PM
  #58
carlo
carlo's Avatar
Calipers look much better mate
Old 11-08-2010, 03:02 PM
  #59
Porkie
Porkie's Avatar
Brakes look MUCH better!
I am putting mine back on std wheels Neil. Getting rid of the pig iron boat anchor Techarts!
Off to the Ring in it this weekend as it goes. Will be first time I have driven it in 3 months!
Old 11-08-2010, 03:03 PM
  #60
NEIL A
NEIL A's Avatar
The calipers work realy well as well as the AP's and Brembos i had on the escort, I realy just changed them for badge snobbery . Porkie will be pleased ..
Old 11-08-2010, 03:21 PM
  #61
NEIL A
NEIL A's Avatar
I wish i could have tried mine on standard wheels Lee but they wont clear the brakes and dont fancy spending 3K on a set of 18" CCW'slthat will clear.
Old 11-08-2010, 04:27 PM
  #62
baba
baba's Avatar
stunning car wasnt really into them until a few years ago now crave one in a sense.
where did you get the wheels redone?did they re-polish the lip?
Old 11-08-2010, 04:37 PM
  #63
NEIL A
NEIL A's Avatar
The wheels are getting done by Mike the polisher. www.the-polisher.com
I was going to go for a body coloured center but the closest powder they had was slightly dark, i have decided on gloss black centers and black bolt heads to add a bit of detail.
Old 11-08-2010, 04:45 PM
  #64
fezzajsy
fezzajsy's Avatar
nice
Old 11-08-2010, 05:27 PM
  #65
volcomstone411
volcomstone411's Avatar
loverly....i love suspension...truly anal
Old 11-08-2010, 10:07 PM
  #66
NEIL A
NEIL A's Avatar
I cant wait to get the new suspension on should pick it up on friday so will more than likely get it fitted this weekend, only problem is my wheels wont be ready untill next week and im away to London for on a training course for work..
Old 12-08-2010, 01:10 PM
  #67
cossiedevil
cossiedevil's Avatar
Top work there Neil a nice set of coilovers be savage on the bends when fitted i would say
Old 12-08-2010, 09:29 PM
  #68
Brian
Brian's Avatar
Looking good
Brian
Old 12-08-2010, 09:58 PM
  #69
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Calipers look so much better
Old 24-08-2010, 09:29 PM
  #70
NEIL A
NEIL A's Avatar
Got the wheels back today and to say im happy with the finnish is a understatment . Just need to adjust the ride height down a bit more on the new suspension and get it in for a geo setup and corner weight.
Old 24-08-2010, 09:37 PM
  #71
carlo
carlo's Avatar
Stunning mate would love one 1 day
Old 25-08-2010, 09:34 AM
  #72
Munch
Mr. Sparkle!
Munch's Avatar
very nice!
Old 25-08-2010, 09:44 AM
  #73
Porkie
Porkie's Avatar
looking good dude.
is the ride better on the new shocks?
The ride is a little too firm on my KW's now for me. Another reason why I am selling!
Old 25-08-2010, 10:29 AM
  #74
Richie.
aka Turbosailorboy
Richie.'s Avatar
Very very nice Neil
I want one
Old 25-08-2010, 01:41 PM
  #75
NEIL A
NEIL A's Avatar
Lee ive only had the car out for 5 min last night to check for any knocks or rubbing with the way ive ran the hoses, so far it seems a smoother ride and thats with the dampning half way and slightly heavyer springs than on the old stuff.
Going to drop it another inch all round today to get it back to the same height as before then will give it a better test , and hopefully get it booked in asap for a proper set up again. Back end should be the same if i get the height back to what it was but the front nolonger has adjustable camber plates so it will need adjusted.
Old 25-08-2010, 09:21 PM
  #76
NEIL A
NEIL A's Avatar
Go the car sitting how i want it now and took a little camber off the front so just need to get it to Sitec or AG for a proper set up now.
Old 30-08-2010, 12:05 AM
  #77
NEIL A
NEIL A's Avatar
Originally Posted by Porkie
looking good dude.
Lee after doing 4 hours of B road blasting today, I would say the new suspension has transformed the car and thats before it has even been set up. I would say the ride quality is no worse than my standard Clio 182 cup , it realy has shocked me and after a set up it can only get better
Old 30-08-2010, 06:06 PM
  #78
krypton
krypton's Avatar
Wheels look stunning now
Old 30-08-2010, 08:49 PM
  #79
stu21t
stu21t's Avatar
that looks the nuts,
but you need to get some tyre shine lol
Old 31-08-2010, 09:15 AM
  #80
fezzajsy
fezzajsy's Avatar
looks awesome mate
Quick Reply: Lotus Exige from page 5
