US spec 1982 Escort
I have posted this here before, but the car has come quite a ways from then. I started out buying this car as my first car for $600, and then going through and slowly making the car drivable. I got in on the road in January and I have been using it as my daily driver since then. In August, I picked up a 1.9 litre engine from a '90 Escort and rebuilt it with the hemispherical head and carbed intake from the 1.6 that previously resided under the hood. Unfortunatly, at the rebuild time, I lacked the funding to install high compression pistons, so my my compression ratio is somewhere around 8:1. Even so, the car pulled of a 10.8 at 63 mph in the 1/8th mile on old P165/80 R13 tires and a worn out clutch.
Anyway, here are some pics.
When I got my hands on her:
After paint:
The old 1.6:
The new 1.9 junkyard fresh:
And after rebuild.
The strip:
Anyway, that's my baby.
-Walt
After paint:
The old 1.6:
And after rebuild.
The strip:
-Walt
Yeah, the only difference between that and a 1.6 is the 1.9 has a higher deck height that allows for more stroke, and a larger bore. Apparently, the block is beefier also, but I didn't compare the blocks that much when I swapped them. The 1.9 is also a lot more popular over here. The cam bearings are different between the 1.6 and 1.9 heads, and we also have a few non hemi heads over here that I don't know if y'all got over there.
We have lean burn with a D shaped combustion chamber and high swirl chamber with a heart shaped combustion chamber. The lean burns were used on throttle body injected 1.9s and the HSC's were used on carbed 1.9 if I recall correctly.
No thank God, I wouldn't own it if it was. 4 on the floor.
Right now the plan is to do some minor work on the engine for land speed racing, and then after that I want to swap in EFI from a 1989 Escort GT, and then after that a turbo if I can find the stuff. Over here we have to make most of our part since there isn't much aftermarket for Escorts over here. There are not a lot of road tracks over here, so I am mainly focused on straight line performance. It will get drag raced mostly but what I am really building the car for is standing mile speed competion. The class I want to run has a record of 114 mph or 183 kph.
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
