AG Focus Cosworth Project (16/11/12 - Supra Diff)
Old 20-04-2011, 09:41 PM
  #561
whizzisat114
whizzisat114's Avatar
Look at coley's thread Al we've modded our's so that the shafts that the wiper arms bolt to are now 180 degree from there original placing.
Now they are closer to the bulk head instead of being closer to the engine (if that makes any sence )
whizzisat114 is offline
Old 20-04-2011, 09:43 PM
  #562
COCHYN
COCHYN's Avatar
But that won't effect the throw of the arm towards the lead mate, that's solely to stop it fouling the brake fluid reservoir. I figure something
COCHYN is offline
Old 20-04-2011, 09:46 PM
  #563
focus 4x4
focus 4x4's Avatar
Correct!
focus 4x4 is offline
Old 20-04-2011, 09:50 PM
  #564
dingla rs
dingla rs's Avatar
it will sort the problem if you do the mod rite
dingla rs is offline
Old 20-04-2011, 09:51 PM
  #565
whizzisat114
Ah sorry my mistake
Can you raise the wiper motor up any?
If not get Coley to knock you some spacer's up for your cradle
Old 20-04-2011, 09:52 PM
  #566
COCHYN
COCHYN's Avatar
Doubt it, the throw of the arms complete the cycle in the bulkhead as they are now, no room to adjust further back as suggested. I'll work something out, no patience left today after everything else
@ Whizzisat114
No chance unfortunately, can't raise any higher. Not the biggest of issues, will sort it out
COCHYN is offline
Old 20-04-2011, 09:56 PM
  #567
whizzisat114
Got any pic's of it close up?
Old 20-04-2011, 10:00 PM
  #568
COCHYN
COCHYN's Avatar
Nope, the linkage is off the car at the mo. Can't do much else with it, I'll just get a shorter lead. Don't think it was originally designed for my spec, just a bog standard runaround engine
COCHYN is offline
Old 20-04-2011, 10:01 PM
  #569
rs_traynor
stage4 2wd cosworth
rs_traynor's Avatar
same as yours then lol :P
rs_traynor is offline
Old 20-04-2011, 10:02 PM
  #570
whizzisat114
What's different ten ?
The lead's bigger than standard? or have the new mount's lifted the engine up?
could you have a touch machined off them?
Old 20-04-2011, 10:06 PM
  #571
COCHYN
COCHYN's Avatar
No need to do bodge jobs like that Engine is at the height its always been, but the linkage is using all original mounts and cleared shorter leads. What's changed are the motorsport leads that protrude more than what were there previously.
COCHYN is offline
Old 20-04-2011, 10:10 PM
  #572
whizzisat114
Well if the motor's not going any lower and the wiper isnt going any higher then the leads have to go
Old 20-04-2011, 10:12 PM
  #573
COCHYN
COCHYN's Avatar
Lead, singular But I have another idea which might work in conjunction with something else. Have a crack, otherwise I have another option
Cheers boys
COCHYN is offline
Old 20-04-2011, 10:21 PM
  #574
focus 4x4
focus 4x4's Avatar
I think you may find that those engine mounts youve been using are actually taller than standard cosworth ones.... measure them against OE escort cosworth items.
Old 20-04-2011, 10:24 PM
  #575
COCHYN
COCHYN's Avatar
Nope, their the same as are the one's I'm using now. Its a simple case of the lead having at least an extra 10mm height which I had clear with the old crap leads. Ball ache but there we go
COCHYN is offline
Old 21-04-2011, 02:28 PM
  #576
COLEYST200
COLEYST200's Avatar
Time for some weld in spacers or have some ally removed from your new mount pease of cake to a Birmingham lad
COLEYST200 is offline
Old 21-04-2011, 02:58 PM
  #577
COCHYN
COCHYN's Avatar
Told you, no bodge jobs to make them fit, even if it is precise
I'll just sort a different lead, too tight in the bulk head to push the wipers back
Ah fun
COCHYN is offline
Old 21-04-2011, 03:02 PM
  #578
whizzisat114
Its all in the joy of owning a cutom car ay?
Old 21-04-2011, 03:03 PM
  #579
COCHYN
COCHYN's Avatar
Aye, but in all honesty its spot on, only snag really is this
COCHYN is offline
Old 21-04-2011, 03:42 PM
  #580
whizzisat114
they'd be boring if there was'nt something to mess on or change
Old 21-04-2011, 03:58 PM
  #581
COCHYN
COCHYN's Avatar
They never get boring
COCHYN is offline
Old 21-04-2011, 04:43 PM
  #582
Good to see it running
Twins is offline
Old 21-04-2011, 07:22 PM
  #583
COLEYST200
COLEYST200's Avatar
Put a set of KA leads init and rework the rocker cover job sorted
Old 21-04-2011, 07:50 PM
  #584
COCHYN
COCHYN's Avatar
Nice idea But I think the other option for the spec I have is a nice custom lead, which will iliminate the issues I have now.
But then again, I have one other option I want to try with the setup I have and then I'll call it quits and conform with the last option
How's yours coming along Coley?
COCHYN is offline
Old 21-04-2011, 08:09 PM
  #585
COLEYST200
COLEYST200's Avatar
OK thanks
Old 21-04-2011, 09:00 PM
  #586
J1mbo
B1mbo
J1mbo's Avatar
Did I hear ka leads on a 380bhp cosworth engine running big boost?
Cochyn you know my ideas best lol
J1mbo is offline
Old 21-04-2011, 09:29 PM
  #587
whizzisat114
What's wrong with them then jimbo? only good for so much boost? do they limit the power to the sparkplug's? does the spark get blown out ?
David (just learning)
Old 21-04-2011, 09:36 PM
  #588
J1mbo
B1mbo
J1mbo's Avatar
I don't know tbh I've never used ka plugs, but they're made for a 50bhp na engine, I could see them not keeping up and causing misfires!
The motorsport leads we use and always advice to use are brilliant never give any problems
I guess it's a case of sticking to what you know?!
J1mbo is offline
Old 21-04-2011, 09:41 PM
  #589
whizzisat114
Plug's or leads? coley uses ka leads on his car and he run's about 360bhp don't think he's had many prob's with them. just trying to get a bit of info for my build when the time comes
Old 21-04-2011, 09:45 PM
  #590
J1mbo
B1mbo
J1mbo's Avatar
I was talking about leads sorry!
If they work fair enough! Just were going to be giving alans car around 30psi mid range and they're not the easiest to change over on a hot engine lol hence me saying go for motorsport ones!
J1mbo is offline
Old 21-04-2011, 10:08 PM
  #591
COLEYST200
COLEYST200's Avatar
As Dave said i am running FORD KA leads on my 3dr cosworth which is some were round 360/380 BHP and there spot on my foucs cosworth will be running motor sport leads as iv got a set left over from my 3dr which have only done 1,000 miles but as i am bilding my focos iv used they in the moking up prosses so my leads will fit . and just about all the lads i no that have there rocker cover,s done like my 3dr are running KA leads with no problems
Old 21-04-2011, 10:39 PM
  #592
whizzisat114
K i was just trying to learn a little
Old 22-04-2011, 08:29 AM
  #593
COCHYN
COCHYN's Avatar
I have another option, but will keep you posted
COCHYN is offline
Old 22-04-2011, 08:34 AM
  #594
COLEYST200
COLEYST200's Avatar
So wot is it then
Old 22-04-2011, 08:39 AM
  #595
COCHYN
COCHYN's Avatar
We'll see if it works, then I'll post up a pic. If not, then I won't bother
COCHYN is offline
Old 22-04-2011, 09:16 AM
  #596
COLEYST200
COLEYST200's Avatar
I cannot be bothered with KIDS see ya
Old 22-04-2011, 10:05 AM
  #597
COCHYN
COCHYN's Avatar
Eh?! On your period or something, what possible reason did you have to type that? If I don't want to list out every little detail to a moody dick like you, I won't. If you don't like it, TOUGH!!!
COCHYN is offline
Old 22-04-2011, 12:30 PM
  #598
COCHYN
COCHYN's Avatar
Sorted!
COCHYN is offline
Old 22-04-2011, 12:35 PM
  #599
RickDraper
RickDraper's Avatar
Looks good.
So will i have to keep my eyes pealed for this around Macclesfield and Bollington then?
RickDraper is offline
Old 22-04-2011, 12:41 PM
  #600
COCHYN
COCHYN's Avatar
Aye you will pal, where about are you living? Know a couple of people on here now that live in the area, we should all have a meet up and drive to the Cat n' Fiddle
COCHYN is offline
Quick Reply: AG Focus Cosworth Project (16/11/12 - Supra Diff)
