REYLAND Escort - Version 2!! - updated P20
Old 24-11-2005, 07:20 PM
  #361
Simon Day
Simon Day's Avatar
- come on Martin, you can give us more pictures than that!
- BTW - Nice 1st run on the dyno!
Old 25-11-2005, 07:08 AM
  #362
Ish
Ish's Avatar
Originally Posted by martin-reyland
it's been a long time coming but my new engine is finished and on tuesday a couple of mates and myself bolted it onto harvey's dyno .
because this engine is not the same as your average cosworth yb (read unique or first yb of this spec anywhere!) and has had some some previously untried radical mods i decided to treat it's first dyno session as a running in and fault finding excercise but things went that well (no engine probs) that mapping was started and it at half ten last night we called it a day and because it was getting late and a mod needs doing to my ecu and also because i have a couple of other small mods i would like to do to the engine also the dyno has a couple of urgent engines that need to be mapped. so the engine will return to the dyno in a week or so to finish the mapping i will then rev the engine a further 1000rpm (or so!) as the power was still climbing at 7500rpm .
it's hard to put it into words but this engine is something else, it sounds unbelievably crisp and smooth... with just a sniff more boost or ignition added here or there and it just makes big clumps of power its hard to know when to stop!
no dyno graphs yet but i will give you the max power reading at 7500rpm... in just a mo don't forget this engine will easily rev past 8500rpm and is going to make more power as the revs rise
734hp and 500ftlb uncorrected
702hp and 490ish torque corrected
oh and it makes full boost by 4000rpm..
HAVE THAT!
ok... for those interested.
from the off i decided i wanted an engine that would rev but still be quite responsive so rather than destroke the engine to get the rod length to stroke ratio right i decided to increase the stroke. now, when you stroke a yb you normally end up with a less than ideal ratio. what you need is a MUCH taller block enabling a longer stroke but also more importantly longer rods...... much longer rods! the millington engine had a 8mm taller block but even that is not ideal for what i wanted so i had to make my block taller. in simple terms i have added a spacer on top of a 200 block and then linered through both parts...ping, tall block! now all that seems simple but believe me it's not, there's a lot to consider!
for the moment here's what i want to reveal about the new donkey....
* it's more than 2200cc
* the rods are just under an inch longer than standard
* the crank has a longer stroke
* the bores are larger than standard and are nicosil coated
* the head has big ports, big valves, solid lifters and spunky cams
* the inlet manifold is made up from an m.i.s. mag plenum, jenvey individual throttle bodies and a jenvey manifold which had to be chopped and welded to get it under the bonnet!
* turbo spec is secret for now as 2 were tried and one was chosen
* the engine misses the bonnet by 5mm
* it has loads more potential for extra power
* the dyno figures are 100% accurate, some might claim more but reyland horses have always been strong!
any questions? (not you phil )
p.s. can be arsed to spell check this so sorry for any mistakes, pictures will be uploaded tonight too!
Old 25-11-2005, 11:50 AM
  #363
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Seen in general discussion but still
Old 25-11-2005, 12:02 PM
  #364
Red16
Red16's Avatar
looks fantastic, and the figures the engines producing are simply wild
whens this expected to be on the road?
Old 25-11-2005, 12:07 PM
  #365
seveneigths
seveneigths's Avatar
that is stunning martin
Old 25-11-2005, 12:19 PM
  #366
Sticky.
Sticky.'s Avatar
Whats teh dog called again martooon
Old 25-11-2005, 12:27 PM
  #367
Old 25-11-2005, 12:31 PM
  #368
adamS2RST
adamS2RST's Avatar
Simply amazing
Old 25-11-2005, 03:29 PM
  #369
M K
M K's Avatar
awesome fella
Old 25-11-2005, 04:44 PM
  #370
cozzymatt
cozzymatt's Avatar
i know what the dogs called! lmfao..
This is gonna be one serious car when finished.. good luck with the rest of the build Martin..
p.s. I personally think it looks so much better with a proper style cossie bumper on the front !!
Matt
Old 25-11-2005, 06:04 PM
  #371
Simon Day
Simon Day's Avatar
- nice rocker! - we still want more pics!
Old 26-11-2005, 04:37 AM
  #372
Alan s1
Alan s1's Avatar
Old 26-11-2005, 11:03 PM
  #373
coolamasta
coolamasta's Avatar
Thats one amazing cossie! Loving that be'atch of a turbo!
Old 27-11-2005, 11:24 AM
  #374
Ish
Ish's Avatar
have been comparing the new engine to the one we used on the gumball, now as i'm sure porkie will testify the gumball engine was a monster which loved to rev and had no problems keeping up with the enzo but the new engine is mucho better. Looking at some figures it mostly makes the old engines power at 1000rpm less and using 4psi less boost. here's some examples of how much more torque and hp extra it makes at how much less boost...
should make for an interesting drive
Old 27-11-2005, 12:17 PM
  #375
andycosworth
andycosworth's Avatar
thats some engine,and very powerful figures how long b 4 its on our open roads martin?
Old 27-11-2005, 03:57 PM
  #376
seveneigths
Originally Posted by Sticker Paul
Whats the dog called again martooon
I don't but i believe its a bit of an animal
Old 27-11-2005, 06:53 PM
  #377
zetec sport
zetec sport's Avatar
Old 27-11-2005, 07:06 PM
  #378
glenis
glenis's Avatar
superb!
simply the best too
Old 27-11-2005, 07:13 PM
  #379
essexrsturbo
essexrsturbo's Avatar
MENTAL!!
Old 28-11-2005, 07:22 PM
  #380
Mr C
Mr C's Avatar
702bhp?wow, should make an unbeatable track tool
Old 02-12-2005, 02:16 AM
  #381
heeman10
heeman10's Avatar
106bhp more at 6,000rpm than the old engine? Go and clean your side windows Martin, I think you may be needing them! Would love to see a video clip of it on the dyno
Old 02-12-2005, 06:19 PM
  #382
marco
marco's Avatar
Old 04-12-2005, 10:14 PM
  #383
lmans123
lmans123's Avatar
that is going to be awsome
Old 05-12-2005, 06:14 PM
  #385
James-W
James-W's Avatar
Martin you are simply a god. I want a ride in it.
Old 05-12-2005, 06:16 PM
  #386
cosmagedon
cosmagedon's Avatar
Simply the bollocks Cant wait for it to be finished
Old 05-12-2005, 08:49 PM
  #387
Dean Saff
Dean Saff's Avatar
Wow... Cant wait to see it finished.
What an Inspiration you are to everyone. Rayland Rules.
Old 05-12-2005, 09:37 PM
  #388
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Fantastic - can't wait to see the finished result
Old 06-12-2005, 09:36 PM
  #389
Dan
Dan's Avatar
Those figures are just mental!
Old 08-12-2005, 12:11 PM
  #390
nor_cossie
nor_cossie's Avatar
Is the engine mapping complete now?
The numbers quoted erlier was from the first dyno session as i recal.
Awsome car
Old 08-12-2005, 09:52 PM
  #391
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Old 09-12-2005, 03:35 AM
  #392
fezzajsy
fezzajsy's Avatar
Reyland rules!!!
Old 09-12-2005, 01:13 PM
  #393
Ad4m RST
Ad4m RST's Avatar
that is SERIOUS power!
Old 09-12-2005, 03:06 PM
  #394
Benni
Ban[B][/B]ned
Benni's Avatar
amazing!
Old 09-12-2005, 09:57 PM
  #395
Ish
Ish's Avatar
Old 10-12-2005, 05:35 AM
  #396
Alan s1
Alan s1's Avatar
Old 10-12-2005, 11:57 AM
  #397
Munch
Mr. Sparkle!
Munch's Avatar
WOW FOOK ME, that has come along nicely, the paint scheme looks mint mate, bags & bags of power over 700bhp of REYLAND power= serious fun time, nice work
LEE
Old 10-12-2005, 12:53 PM
  #398
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
keep up the good work lads! when is the car expected to be finished?
Old 18-12-2005, 06:04 PM
  #399
RSCossieGaz
RSCossieGaz's Avatar
anymore updates i need my fix
Old 18-12-2005, 06:57 PM
  #400
COSSIE CAL
COSSIE CAL's Avatar
iwant it want it want it want it................
Quick Reply: REYLAND Escort - Version 2!! - updated P20
