Mk6 JWRC fiesta cosworth
#1561
I went and spent a couple of hours in the garage earlier so decided to pull a few bits off the gearbox,
I wanted to see if the chain i had was good to use or stretched, and it seemed pretty loose so i would say it needs replacing.
I also removed the center VC as you can have these pumped back up and it's meant to make a world of difference over an old un touched unit, just need to see who can do this cheaply and wheres the best place to get a chain after deciding if im gonna use 3.6 or 3.9 ratio's
Couple of pics
Parts removed from box
![Name: IMG_1455.jpg
Size: 92.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119689d1501884623-mk6-jwrc-fiesta-cosworth-img_1455.jpg)
Transfer chain
![Name: IMG_1456.jpg
Size: 114.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119690d1501884623-mk6-jwrc-fiesta-cosworth-img_1456.jpg)
![](http://img.photobucket.com/albums/v104/CHICKAROO/MK6%20FIESTA%20JWRC%20COSWORTH%20PROJECT/IMG_1461.jpg)
This shows a worn loose chain
http://www.gears.tv/chain.html
Mine was not quite that loose but not as tight as the new 1 so will replace if i can get 1 at a good price later in the build when the box is fully rebuilt
Reverse switch cleaned up
![Name: IMG_1460.jpg
Size: 277.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119691d1501884623-mk6-jwrc-fiesta-cosworth-img_1460.jpg)
Dohnut thingy of output flange (what is the meant to do? help balance the shaft?)
![](http://img.photobucket.com/albums/v104/CHICKAROO/MK6%20FIESTA%20JWRC%20COSWORTH%20PROJECT/IMG_1459.jpg)
Center diff
![Name: IMG_1457.jpg
Size: 87.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119692d1501884623-mk6-jwrc-fiesta-cosworth-img_1457.jpg)
![Name: IMG_1458.jpg
Size: 100.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119693d1501884623-mk6-jwrc-fiesta-cosworth-img_1458.jpg)
That's about it for today
Couple of pics
Transfer chain
Center diff
#1567
Coming on really well this. I must say, I don't know if I would have gone for such nice paint on a car that is destined for a life of abuse. I would have gone for something simple and easy to match in if (when!) it needed touch ups, but fair play, it should look ace when it's done!
I'd be interested to know what materials Gaz has used though, to bond on the panels and for filling gaps/joins etc, if you could find out Marc?
#1568
http://img.photobucket.com/albums/v1...PICT0008-7.jpg
Isnt that cutted of slam panel in plastic?
Are you shure it will keep the bonnet down if it catches som air?
#1570
I'd be interested to know what materials Gaz has used though, to bond on the panels and for filling gaps/joins etc, if you could find out Marc?![Top](https://passionford.com/forum/images/smilies/smile011.gif)
As far as the build goes the paint is a cheap thing lol
#1576
Here is the latest from Gaz
Passenger side quarter ready for a rub down
![Name: SAM_1657.jpg
Size: 2.61 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119695d1501884623-mk6-jwrc-fiesta-cosworth-sam_1657.jpg)
![Name: SAM_1659.jpg
Size: 2.70 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119696d1501884623-mk6-jwrc-fiesta-cosworth-sam_1659.jpg)
![](http://img.photobucket.com/albums/v104/CHICKAROO/jwrc%20fiesta%20cosworth%20bodywork%20and%20shell%20%20prep/SAM_1660.jpg)
All rubbed down
![Name: SAM_1664.jpg
Size: 2.68 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119697d1501884623-mk6-jwrc-fiesta-cosworth-sam_1664.jpg)
![Name: SAM_1666.jpg
Size: 2.58 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119698d1501884623-mk6-jwrc-fiesta-cosworth-sam_1666.jpg)
![Name: SAM_1667.jpg
Size: 2.68 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119699d1501884623-mk6-jwrc-fiesta-cosworth-sam_1667.jpg)
Repair to pillar ready to be rubbed down from when i dropped the car on it's side off the spit![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
![Name: SAM_1658.jpg
Size: 2.57 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119700d1501884623-mk6-jwrc-fiesta-cosworth-sam_1658.jpg)
Passenger side all lined up (a lot better than i expected so well chuffed)
![Name: SAM_1665.jpg
Size: 2.63 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119701d1501884623-mk6-jwrc-fiesta-cosworth-sam_1665.jpg)
Boot pins fitted and tailgate aligned
![Name: SAM_1662.jpg
Size: 2.65 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119702d1501884623-mk6-jwrc-fiesta-cosworth-sam_1662.jpg)
Drivers door repairs rubbed down
![Name: SAM_1669.jpg
Size: 2.60 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119703d1501884623-mk6-jwrc-fiesta-cosworth-sam_1669.jpg)
Drivers rear quarter with its first rub down
![Name: SAM_1668.jpg
Size: 2.69 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119704d1501884623-mk6-jwrc-fiesta-cosworth-sam_1668.jpg)
It is all coming together spot on so big big thanks to Gaz for a top job so far![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
He is doing a bit over the weekend as well i believe as he wants all repairs etc done and finished so Monday/Tuesday it is ready to be put in primer![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Thanks
Marc
All rubbed down
Thanks
Marc
#1579
Spanner monkey
These for me are the best pics to look at, you start to see the whole thing coming together and looking more and more complete.
Gaz looks like he's doing a real good job on it all, can't wait to see the painted car ( i'm sure you cant either LOL )
#1583
Thanks for the comments guys, will be done in no time i agree, Gaz works fast ![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Yes mate, side moldings are staying as they look pretty good color coded and it's more work to fill the holes, the rear quarter moldings will not be going on though as they are too long as standard to fit as the rear arches are too big for them, front ones on there own look ok though
#1589
Gaz is flying with the shell, should be in primer tomorrow or Tuesday
Yeah another 10k would see it on the road.......JUST!
#1590
Bit more done over the weekend by Gaz as he wants it ready for primer asap, so bar a complete rub down all over and a final check it's ready for that now ![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Drivers quarter skimmed over & smoothed off
![Name: SAM_1670.jpg
Size: 2.61 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119705d1501884623-mk6-jwrc-fiesta-cosworth-sam_1670.jpg)
![Name: SAM_1671.jpg
Size: 2.57 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119706d1501884623-mk6-jwrc-fiesta-cosworth-sam_1671.jpg)
![Name: SAM_1673.jpg
Size: 2.64 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119707d1501884623-mk6-jwrc-fiesta-cosworth-sam_1673.jpg)
roof repair rubbed down
![Name: SAM_1678-1.jpg
Size: 2.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119708d1501884623-mk6-jwrc-fiesta-cosworth-sam_1678-1.jpg)
Small repair to rear bumper section that had broken off
![Name: SAM_1677.jpg
Size: 2.61 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119709d1501884623-mk6-jwrc-fiesta-cosworth-sam_1677.jpg)
Drivers side wing/bonnet gaps done
![Name: SAM_1679.jpg
Size: 2.66 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119710d1501884623-mk6-jwrc-fiesta-cosworth-sam_1679.jpg)
And finally after buying about 5 different front grills i got the correct 1 to fit the gap, a zetec-s/st grill
old grill
![Name: PICT0006-8.jpg
Size: 116.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119711d1501884623-mk6-jwrc-fiesta-cosworth-pict0006-8.jpg)
New grill
![Name: SAM_1672.jpg
Size: 2.64 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119712d1501884623-mk6-jwrc-fiesta-cosworth-sam_1672.jpg)
May just have to remove the side clips so it looks a bit neater but it fills the gap so the rest is easy
old grill
New grill
#1593
It's in primer ![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/smile011.gif)
Gaz has worked over the weekend and flat out on it all day so he could get it in primer today, and he managed to do it![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/ban-split.gif)
So to start with i opened up these photo's and had no idea what the hell this was about lol, but Gaz has enlightened me that it is for dent pulling, so you can use a slide hammer on the dent to get it out as much as poss so less filler can be used, ingenious
![](http://img.photobucket.com/albums/v104/CHICKAROO/jwrc%20fiesta%20cosworth%20bodywork%20and%20shell%20%20prep/SAM_1682.jpg)
![Name: SAM_1683.jpg
Size: 2.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119713d1501884623-mk6-jwrc-fiesta-cosworth-sam_1683.jpg)
![Name: SAM_1684.jpg
Size: 2.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119714d1501884623-mk6-jwrc-fiesta-cosworth-sam_1684.jpg)
Then once all repairs to the body were done the entire car got a light key ready for primer
![Name: SAM_1685.jpg
Size: 2.57 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119715d1501884623-mk6-jwrc-fiesta-cosworth-sam_1685.jpg)
![Name: SAM_1686.jpg
Size: 2.64 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119716d1501884623-mk6-jwrc-fiesta-cosworth-sam_1686.jpg)
![Name: SAM_1687.jpg
Size: 2.59 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119717d1501884623-mk6-jwrc-fiesta-cosworth-sam_1687.jpg)
![Name: SAM_1688.jpg
Size: 2.61 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119718d1501884623-mk6-jwrc-fiesta-cosworth-sam_1688.jpg)
Doors getting primered
![Name: SAM_1697.jpg
Size: 2.65 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119719d1501884623-mk6-jwrc-fiesta-cosworth-sam_1697.jpg)
![Name: SAM_1698.jpg
Size: 2.64 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119720d1501884623-mk6-jwrc-fiesta-cosworth-sam_1698.jpg)
In the booth ready for it's make over
![Name: SAM_1689.jpg
Size: 2.57 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119721d1501884623-mk6-jwrc-fiesta-cosworth-sam_1689.jpg)
![Name: SAM_1690.jpg
Size: 2.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119722d1501884623-mk6-jwrc-fiesta-cosworth-sam_1690.jpg)
![Name: SAM_1691.jpg
Size: 2.62 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119723d1501884623-mk6-jwrc-fiesta-cosworth-sam_1691.jpg)
Then after all this time having its panels bolted and screwed in place and hanging out of line, generally looking pretty sorry for itself and a lot of effort from Gaz, the car is finally in 1 color for the 1st time
Happy F*cking Days![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/ban-split.gif)
![](http://img.photobucket.com/albums/v104/CHICKAROO/jwrc%20fiesta%20cosworth%20bodywork%20and%20shell%20%20prep/SAM_1695.jpg)
![Name: SAM_1694.jpg
Size: 2.51 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119724d1501884623-mk6-jwrc-fiesta-cosworth-sam_1694.jpg)
![Name: SAM_1696.jpg
Size: 2.69 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119725d1501884623-mk6-jwrc-fiesta-cosworth-sam_1696.jpg)
![Name: SAM_1700.jpg
Size: 2.47 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119726d1501884623-mk6-jwrc-fiesta-cosworth-sam_1700.jpg)
![Name: SAM_1701.jpg
Size: 2.53 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119727d1501884623-mk6-jwrc-fiesta-cosworth-sam_1701.jpg)
![Name: SAM_1699.jpg
Size: 2.64 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119728d1501884623-mk6-jwrc-fiesta-cosworth-sam_1699.jpg)
![Name: SAM_1693.jpg
Size: 2.56 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119729d1501884623-mk6-jwrc-fiesta-cosworth-sam_1693.jpg)
![Name: SAM_1692.jpg
Size: 2.63 MB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/119730d1501884623-mk6-jwrc-fiesta-cosworth-sam_1692.jpg)
Blinding job so far Gaz, many thanks mate
Happy F*cking Days
![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/9c-clap.gif)
