metering unit problems rs turbo mfi
can anyone help me ive bought a 1988 escort rs turbo with the MFI fuel injection bought it as a non runner thinking i could sort it easy (1st mistake) as ive owned 4 in the past and im pretty good with the old cvh,its not getting fuel at the injectors the fuel pump is priming ,theres fuel pressure before the metering unit and after it but nothing coming out the top. the flap bobs up and down fine when you turn it over and theres power to the 2 plugs going to the metering unit when you turn the engine also ive tried a second hand unit and its still the same (it could be fucked also) this is turning out to be expensive and my dream of tearing down the 1/4 mile at crail in 14 seconds is becoming more and more faint any help would be greatly appreciated ,cheers matty
i had the same on my old rs turbo. no fuel comeing out was down to the metering unit, try bridgeing the fuel pump relay. or run the pump to the battery and see if you get any fuel out the top of the unit
