rebuild of irish tarmac 3dr! ANTILAG VIDEO !!!
#43
been busy the last few days on it. i have now made and installed a new stronger gearbox mount. made up the exhaust. fitted the tank with new mounts and the pumps. will post pics soon. thanks for all the advice ive been getting of people really helpful!! waiting for switches for the anti lag and other bits and bobs for the engine. will be fitting my gaz golds soon on the front and soon be repainting the inside. ready for the extinguisers and brake and fuel lines etc etc
#44
well am getting there now, new gearbox mount done, exhaust fitted, wiring done. still waiting for new rad,intercooler and fans and i should get it fired up!! . only big job now is the brakes get the pedalbox soon and get them out of the way. then save up for seats and harnesses. still need to buy fibreglass bonnet and tailgate. just small jobs after that..............then the respray of course...all bloody money!!! worth it though
#56
thats me powered up now! my wiring has held up!! still not got her started yet still waiting on a few things got the cam belt to do etc etc, but getting close. got a 3.91 diff to put in rs500 style intercooler in new rad and fans on still need to take them of to figure out the sump guard brackets at the front. oil cooler on, battery box in and extingushers in!
#57
hi i have a 3door rally car shell that i have had for many it was on irish plates when first reg jxi **** and then changed to d** rvu.
was told when i brought it that the engine and running gear had been taken out and put in a escort.has loads of period features -large alloy fuel filler on passenger side rear qtr,full cage,909 topmounts,dash looks the same as works cars fuse box on passenger side dash,navigator alloy foot rest, alloy fabricated fuel tank cover with cut out for spare wheel,gearbox tunnel has removeable section for getting at top of box and it looks like the picture on that logbook but was white with blue stipes at the rear going into full blue, arches where blue and bonnet vents.
had rac scruteneers stickers on windows but are faded i think one had 1991 on.
any help?????
cheer neil
any help?????
cheer neil
#64
ive used various boxes in my rally cosworths and always use close ratios, long ratios are no good in a rally car, ideally you want 1st gear to be mid to high 2.?:1 and direct 5th gear, all the rest spaced between.
the T5 is not a bad box for its cost, espcially if your using a 4.44,
good luck
good luck
#66
nice car mate! how did you get on with it in the forests as ive read that they werent that competitive alot better on the tarmac!!does the 4.4 diff not make 1st gear useless with a standard box. obviously with a high first on a close ratio it would be ok
#68
if your using a t5, the 1st is something like 2,9:1 though not great, far from MT75 territory of 3.5?:1, so still usable, though not the worst.
i would still say 4.44, theres not alot of tar that calls for more than 130ish flat out for very long, but its not the tope speed its about the closeness off the gearchange, and also getting away at chicanes without lag, the 3.9: was really bad for coming out of tight bales etc, you either waited for the boost, or, clutched it, neither was good, the 4.44's sorted that, but on the larger venues was allowed to use ALS as well, but not anymore, pretty much only forests now.
#69
collins car is done by Quickies motorsport. My mate i do some work for has a bodyshop, and he paints all Quickies and Collins cars. Phil Collins has a ascona 2.9 vauxhall atm for forest historic, and a mk2escort red one with a millington.
Quickies motorsport is a great place, ive walked round there a few times perving at all the cars. They also do Ellsmoores tesco 99 suburu and a few others. Also has a nice old carrera 4s int here
#72
Hi there, I think i might have the sister car to yours, looks like yours is the first evolution as it has a bolt in cage, i have the second evo as they removed the bolt in cage and replaced it with a welded in cage as you can check the to chassis rails go all the way from the front to the back, Just trying to find the id of the car but has been confirmed that is is a rare RHD full works boreham group A shell
#73
my chassis legs go all the way from front to back, send me some pics of your car to petermosgrove@aol.co.uk id like to see it cheers
#76
I'm looking for Gen 3 door rally bits & bobs for my ex-works rebuild!
any help?????
cheer neil
any help?????
cheer neil
Are you selling the car, shell, bits & bobs etc? I'm just starting a full rebuild on a 3 door ex-works rally car...it's quite well known with loads of history, do you have anything for sale???
Cheers Rich
#77
IT LIVES!!! had it started today for the first time, sounds good!! evreything running smoothly. oil pressure etc etc.... even in the antilag is working!! plenty of pop pop bang bang!! il take a video tomorrow for you to hear!! what a relief i can tell you !!!
#79
antilag!! video !!
http://s614.photobucket.com/albums/t...t=video001.flv
this link should take you to a video of the car with antilag!! not the best video as it was a bit dark etc..... but hey sounds brill !!!!!
#80
more pics
heres a few more pics got this new hella grill and mdified the front bumper allowing maximum air flow!! just got my 330mm wilwood front brake kit and im putting on focus st170 front discs on the rear with the standard four pots from the front should give good braking. also got my water injection tank to fit not sure where its going yet and pump!
