ariel removal
Old Dec 30, 2008 | 06:23 PM
cossie330's Avatar
cossie330
Default ariel removal
Hi guys whats the best way to remove an unwanted ariel hole in the roof of a saff as someone has kindly drilled a hole for one and i want it gone as going to have a respray soon ?
Old Dec 30, 2008 | 06:25 PM
jacko's Avatar
jacko
you need to weld the hole up mate fill it and paint the roof
Old Dec 30, 2008 | 07:22 PM
cossie330's Avatar
cossie330
Hows best to fill hole, from the underneath and fill or other
Old Dec 30, 2008 | 07:26 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
take the aerial out, dependant on the size of hole left you could either put a couple of tacks of weld in it or cut out a disc of metal the size of the hole and weld it in Then smooth the weld and fill from above then prime it. keep the moisture away though as primer is porous
Old Dec 30, 2008 | 07:30 PM
cossie330's Avatar
cossie330
Its about 10mm hole
Old Dec 30, 2008 | 07:46 PM
costina's Avatar
costina
Live long and prosper!!
best way is to weld it up which means roof lining out and a roof repaint
Or you could find a rubber blanking grommet but make sure it fits tight and i'd put some black waxoyl around the edge first then push it in wipe excess off
Depends on what u what cheap or expensive
Paul
Old Dec 30, 2008 | 07:56 PM
cossie330's Avatar
cossie330
I have rooflining out and going for a respray do i weld a plate underneath and fill or other?
Old Dec 30, 2008 | 07:59 PM
orionmojo's Avatar
orionmojo
just be careful!!
if you warp it your fucked.
Old Dec 30, 2008 | 08:26 PM
costina's Avatar
costina
easiest way to do it is to cut a little disc just bigger than the hole and place it under hole weld/tack into place little at a time wait to cool between tacks sand/grind flush i'd etch prime first then fill any perfections etch prime again flat and have it painted
Don't forget to etch pime under and and seal it with pait or brush on sealer
Paul
DON'T FORGET TO COVER ALL GLASS AND INTERIOR !!!
Old Dec 31, 2008 | 12:31 PM
jacko's Avatar
jacko
right then easiest way make the hole and the plate oval shoped bit make the plate slightly bigger
then tack weld a nail to the middle of the plait then use the nail to get it inside the hole then pull it upp to cover then weld from the outside i done dicko frome here,s car this way
Old Dec 31, 2008 | 12:38 PM
cossie330's Avatar
cossie330
Cheers for the help guys i will sort that asap
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
