Escort Cabriolet SE MK3 Rare D-plate Full Restore top to bottom small update 5/03/09
#42
RSCRAZZY
Gaz coilovers added to the car also st170 front brake conversion added the front brake line has been made wrong my mistake will make up a new piece and run through the right way also nut for engine mount is on order from ford monday now, as you can also see there are a few little yellow blemisshes under arch this is waxoil where i thought would be best to cover than have problems later also got original white pop rivets for whole car just need to apply kit to car rear arch, arch is there just to see it fitted right as i got it from another series one wanted to make sure, braided brake lines are coming also will match the rest of the car also few other new refurbed bits on the way for under arches to get near perfect
callipers will be refurbed also as trial fitted to see if 12mm drilling to the hub worked ok will have new seals and powdered in red i think????? only reason did not go bigger as i wanted to fit rs`7 spoke alloys to the car soo st170 best choice my opinion
also rear drums maybe getting changed for disc conversion or may just get drums powder coated black as i left these un coated as in 2 minds of what to have drums or discs coilovers all fitted to the rear also
#45
RSCRAZZY
Not alot done but evry update is great have added 2x 10"slimline fans to my alloy rad, sorted more the engine bay out alot more neater, under car has been seen to also still more to do but a few more new nuts bolts washers added amzing how much defference they all make, new flywheel guard fixed on new gear selector and all new braided fuel lines under car
more new nuts bolts washer arriving soon, will hopefully be done and sooner want the car ready noe cant wait to strat it
#51
RSCRAZZY
Hi, I am restoring a SE myself at the moment and have just put the boot interior back together, but I dont have a spare wheel cover and cant seem to source one from anywhere. Could you please send me a pic of yours if you have one, so I may be able to make one to fit.
Thanks
Dave
By the way yours is looking top.
Thanks
Dave
#62
RSCRAZZY
Thanks
Dave
Thanks
Dave
#63
RSCRAZZY
#66
RSCRAZZY
se
nope therz like a thin board that seperates the carpet and wheel all it is 3mm thick plywood round for the wheel with a hole in the middle for wheel lock thatc should be ok
#68
RSCRAZZY
thats it well thats what was in mine but was all broke so made a new one for myself not sure if it come standard like that though will look into that more
#71
RSCRAZZY
been abit busy with a new little fella that joined the world more will be updated soon mate was thinking of getting interior trimmed in leather and alcantra or leave it standard hmm??? hows yours getting on you have you got a restore thresad or any pics you can send will be great to see
#72
hi i also have one the exact same, i live in germany and goin bk home to scotland soon but i want to get mine running first, i bought the car as a non runner and the guy who sold me it said it needed only a fuel metering unit, bought one and was wrong one, eventually found the correct one and fitted it, car still won't start, it backfires and seems like compression comes out of the inlet manifold butterfly, what is possibly wrong with the car, is there any advice you can give me, had its head gasket and alot more work last year all recipted from a genuine ford dealership, could it possibly be due to the fact it aint been running in approx 6-8 months, im getting a spark, fuel and air and timing is perfect also wb and help me please cant find and info on net at all, regards Aaron kyle
#73
i think i retrim in white leather would be nice. although im not sure whether it will have too much white.
mines been on hold for a short while as i bought myself an escort 3 door estate. didnt really have the money for it, but stretched myself so now gona be skint for a short while
#74
RSCRAZZY
#75
RSCRAZZY
would be great to see some pics love seeing restore threads or just pics of progress good luck mate with yours and the estate
84, alternator, cabriolet, escort, escorts, jpg, lanarkshire, mk3, photo, pictures, restore, restoring, sale, se, toptobottom
