Norwegian 2wd mallard escort cosworth.
#161
Also have to make a new tank for the brake fluid because of the mis inlet. And change the angle on the outlet for the cooler
Some goodies. Also going to run a presicion turbo, PT6266
Started the work on the loom.
Parts ready to go on the engine
Oilfilling cap is overrated
Primer and paint. Nice to get that finished!!!
After it had dried i watersanded and polished.
#162
The fun stuff begins. Putting new and shiny parts back on to the car.
But now i cant put anything back that isnt mint, so everything has to be painted and galvanized.
#168
Looks great! Great finish on it.
#173
Today ive been cleaning all the powdercoated parts and polished the inlet inside and put it together.
Im going to run with high boost, so i dont trust the alu threads. So i put time sert inserts in all the threads, same as i did for the rocker cover.
#177
Breather for the drysump tank. Since this will be hidden behind the plastic innerwing, i used the AN connectors i had with colours on. Also had some braided hoses i could use. Other places its only black.
Wondered what to do with the rockercover. Think highgloss polished will be a little too bling, so im trying to make a brushed surface. A lot of sanding, but hopefully i will get the look im after.
#184
That looks amazing. I never thought that those colours would go together. Is it possible you could give me the length of the runners from the plenum to the head please?
#188
Lucifer II - 666
Absolutely stunning.
