ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
Hi everyone, i'm new to this computer stuff so please bear with me as i show you a history of my Mk2 Escort.
I've owned it for 22 years from being an Riviera blue 1.1 popular through to the present 4x4 Cosworth creation.
Engine made 500.5 bhp & 408 ft/lb when it was dyno'd at Field Motorsport at 24 psi has hit( 42 psi) at times.
Current spec is : 200 block, cooper rings with six long studs, Carillo h-section rods, Cosworth forged and pocketed pistons, BD16 Inlet, BD14 Exhaust, WRC spec big port head, custom plenum and a good old T4. Running on a L8 with MSD coil pack conversion and closed loop with air to air boost control.it also has ALS&launch control
Will update the thread over the next few days to show the rest of the spec
mk2 ESCORT4x4 cosworth smoothed engine bay
welded all unnecesary holes braced bulk head and cut out strut tops ready 4 bias box and eccentric top mounts.
About time you got on here, (we meet at bristol and swindon day and dorset day, I had the ALS problems in the saff in my sig if you recall)
will it be up and running for next combe?
