ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
Old 16-08-2010 | 07:10 PM
  #1201
andy escos's Avatar
andy escos
transmission tunnel is gone
in the pic is the culprit that does all my cutting
now all i got to do is make a new one
Old 16-08-2010 | 07:12 PM
  #1202
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I stay at home struggling to get that f##king window out , whilst you're having party time with grinder again
Old 16-08-2010 | 07:14 PM
  #1203
andy escos's Avatar
andy escos
ha ha you not got it out yet i told youa hammer would be quicker
Old 16-08-2010 | 07:16 PM
  #1204
Richie.'s Avatar
Richie.
aka Turbosailorboy
Its out now
Are rear screens laminated ? ? ? It won't smash
Old 16-08-2010 | 07:19 PM
  #1205
andy escos's Avatar
andy escos
Its out now
no its toughened they are very tough
Old 16-08-2010 | 07:37 PM
  #1206
graham c's Avatar
graham c
i like the cutting and building better than the thrashing only just tho
Old 16-08-2010 | 07:49 PM
  #1207
mp1's Avatar
mp1
I like him nice!
Wicked car
Old 16-08-2010 | 08:06 PM
  #1208
whizzisat114's Avatar
whizzisat114
Hi Andy long time no speak
What you cutting her up for again ? different gearbox going in?
Old 16-08-2010 | 08:08 PM
  #1209
andy escos's Avatar
andy escos
yes mate i will be fitting a skyline r33 gearbox in the near future so it makes sense to make sure the transmission tunnel is big enough
Old 16-08-2010 | 08:12 PM
  #1210
whizzisat114
Nice whats involved in the conversion? is that the box which is changable from rwd to 4wd?
Old 16-08-2010 | 08:33 PM
  #1211
graham c's Avatar
graham c
should be you just presure the box and it gose to 4x4 am going to go this root too
Old 16-08-2010 | 08:35 PM
  #1212
andy escos's Avatar
andy escos
yes dave it is & so is the r32 box the gearbox needs to be stripped totally so the bell housing can be cut off & milled to make sure it is flat then either weld on a billet adaptor to take a 2wd cossy bellhousing or just weld the bell housing direct to the box then you got to machine the main shaft down so it fits in the cossy spigot bearing in the crank ,also you need to modify the front & rear props to suit ,fit a centre push clutch fit all the hydraulic gubbins that controls it & get a hydraulic controller from martin hadland so you can adjust how much power you want to go to the front wheels . ill do it one day but i want to get it on the road for a year & enjoy
Old 16-08-2010 | 08:43 PM
  #1213
COLEYST200's Avatar
COLEYST200
O no you have cut it up again but if i no you it will be back in by the weekend
Old 16-08-2010 | 09:20 PM
  #1214
Richie.'s Avatar
Richie.
aka Turbosailorboy
Not if i get my welder back
Old 17-08-2010 | 10:48 AM
  #1215
eedwin's Avatar
eedwin
With all the grinding is there not mutch MK2 left i think.
You develop a whole new car this way.
Old 17-08-2010 | 04:44 PM
  #1216
andy escos's Avatar
andy escos
thats the plan ian,as long as i feel better still feel like crap at the moment
oi dont be mean do not forget i havent done your cradle yet
no mate there is not much of the original car left but at least it should not rust
Old 17-08-2010 | 06:28 PM
  #1217
Tev's Avatar
Tev
dude seriously step away from the grinder
hahaha Good work but actually how much of the car have you replace hahah
Old 18-08-2010 | 09:06 PM
  #1218
andy escos's Avatar
andy escos
as said above mate all the floor, chassis ,inner flitches were sierra but now its nearly all hand made except the inner flitches
Old 19-08-2010 | 07:12 PM
  #1219
Paul Cos's Avatar
Paul Cos
Christ !!!! I leave you alone for 2 weeks and you turn the car over and start cutting it up
I take it you were practicing getting the car out the garage as it will be too wide to get it out the door.
Old 19-08-2010 | 10:43 PM
  #1220
andy escos's Avatar
andy escos
ha ha not quiet just humoring richie he thaught it would look good
i have been cutting again & chopped the dash out
im going to cut the front strut tops off tomorrow
Old 20-08-2010 | 12:36 AM
  #1221
Richie.'s Avatar
Richie.
aka Turbosailorboy
I only left him 10 minutes We disscussed it and he had it cut out by the time I'd driven home
Grinder =
Old 20-08-2010 | 08:50 PM
  #1222
whizzisat114
Andy there aint gonna be much car left at this rate
Old 20-08-2010 | 10:41 PM
  #1223
andy escos's Avatar
andy escos
ha ha wait ten minutes & it gets worse just got to upload pics
Old 20-08-2010 | 10:52 PM
  #1224
Richie.'s Avatar
Richie.
aka Turbosailorboy
Oops
I'm innocent in all this
Old 20-08-2010 | 10:54 PM
  #1225
andy escos's Avatar
andy escos
right i cocked up today as i forgot to get the steel for the trans tunnel so i got my trusty old grinder out again & cut the front strut tops out
then me & richie looked at the old brace to the strut tops that were on the old cage& decided the easiest way to cut them off was to cut the side of the inner flitch off
here is one of the old braces
it used to go to the cage that ran down the out side of the A pillar but now it just stops
the old bit cut out
i also got my drive shaft spacers today as well
there will be more cutting tomorrow
Old 20-08-2010 | 11:01 PM
  #1226
Richie.'s Avatar
Richie.
aka Turbosailorboy
Old 20-08-2010 | 11:06 PM
  #1227
markk's Avatar
markk
i bet they dont weigh much surely alluminium would have been a lot nicer on the diff bearings if you really have to do that, or even to the unsprung weight if they are going outboard Andy ?
Old 20-08-2010 | 11:12 PM
  #1228
andy escos's Avatar
andy escos
i never thaught about aluminium they are only a temporary measure until i can afford new wheels to fill the new arches out ,they are going inside the rear hub carriers i made which are quiet light compared to the original swinging arms so over all should not be to bad
ps they weigh 3.2lbs each
Old 20-08-2010 | 11:16 PM
  #1229
andy escos's Avatar
andy escos
i just weighed the bearing assembly that bolts to the spacer & they weigh 3.4lbs each
Old 21-08-2010 | 08:34 AM
  #1230
COLEYST200's Avatar
COLEYST200
I do hope your grinder gose BANG so you will stop cutting it up and have to start bilding it back up
PS very nice work andy
Old 21-08-2010 | 10:29 AM
  #1231
Nice progress mate.I havent had my lap top for a week so i havent been on the net.You are going to town on your car arnt you.
Old 21-08-2010 | 11:23 AM
  #1232
graham c's Avatar
graham c
this car will be nothink sort of awsome when finished, roll on central day next year,it will be the car with the most people round
Old 21-08-2010 | 01:32 PM
  #1233
andy escos's Avatar
andy escos
if im going to do it i might as well do every thing i can think of to make it future proof so i do not need to get the grinder out next year which should make coley happy
i really hope so graham ,it usually pulls some pretty good crowds which ever show i go to but im hoping for more next year
its all right ian there is not much left to cut out now ,i think
glad you like it though .
Old 21-08-2010 | 07:10 PM
  #1234
andy escos's Avatar
andy escos
been busy in the garage again & guess what .........i found more rot starting to look like a swiss cheese again .i guess i will be busy with the welder again ,but i did get one of the top mounts welded back in
i will get some pics up later there not pretty.
Old 21-08-2010 | 07:16 PM
  #1235
Sticky.'s Avatar
Sticky.
Great work Andy.
Old 21-08-2010 | 07:23 PM
  #1236
Richie.'s Avatar
Richie.
aka Turbosailorboy
More rot
More grinding
Old 21-08-2010 | 08:37 PM
  #1237
andy escos's Avatar
andy escos
Great work Andy.
thanks paul do you reckon you could make me some stickers for the car mampe style please
Old 21-08-2010 | 08:38 PM
  #1238
Paul Cos's Avatar
Paul Cos
I'm going to confinscate the grinder if you carry on cutting bits off
Where was the rot can't be much left of the original shell.
Old 21-08-2010 | 08:49 PM
  #1239
andy escos's Avatar
andy escos
i will put the pics up you still on holiday paul
Old 21-08-2010 | 09:00 PM
  #1240
andy escos's Avatar
andy escos
i started by welding one of the top mounts on
then i started to strip all the inner bulk head back to bare metal which started to reveal yet more rust so i cut it all out
i also cut the last of the roll cage out of the A pillar
tomorrow i will start to weld it all back up again
Quick Reply: ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
