***FRIJJ the White Westy - I'm Declaring it finished!***
Old 27-10-2008, 04:13 PM
  #441
Porkie
Porkie's Avatar
Originally Posted by DanCossie
Looks the nuts....Bet you cant wait to get it out on the road
TRACK!
its going to be a bit frustrating/scary on the road!
Old 27-10-2008, 04:21 PM
  #442
DanCossie
Post Whore
DanCossie's Avatar
Originally Posted by Porkie
TRACK!
true true..not much use in the wet and rain in the winter i assume...would make a right mess of marias hair
Old 29-10-2008, 10:25 AM
  #443
Porkie
Porkie's Avatar
Alternator packed up.... so Stu got it reconditioned with new bearings and Bosch regulator and a bufty!
super service and turnaround!!!
Stus also started fitting the boost pipes...
Old 29-10-2008, 10:49 AM
  #444
Ryan
Ryan's Avatar
you chaging the paint scheme lee or you leaving broom (i mean yorik) yellow?
Old 29-10-2008, 11:00 AM
  #445
Porkie
Porkie's Avatar
Yellow!!
If I change... its going mat black!
WAR Westy!
Old 29-10-2008, 11:08 AM
  #446
Chip
*** Sierra RS Custard ***
Chip's Avatar
matt black would look shite IMHO
westy's should be bright colours
Old 29-10-2008, 11:17 AM
  #447
Lee_R21Turbo
Lee_R21Turbo's Avatar
You not tempted to spray the oil cooler black to match teh rest of the cooling system?
Looking excellent though!
Old 29-10-2008, 11:20 AM
  #448
Porkie
Porkie's Avatar
I did think about it Lee....
Old 29-10-2008, 11:24 AM
  #449
Lee_R21Turbo
Looks out of place otherwise I think....not that you're goin to see it much hopefully but you know what I mean - especially as everything else alloy is black!!
Old 29-10-2008, 08:54 PM
  #450
Twellsie
Twellsie's Avatar
back to the thoughts about heat soak, could you not have radiused shoud fabricated on the back of the intercooler, so it vents out the bonnet and if you where really bothered stick some of that thermal reflective stuff on the intake and out take to the i/c to make it a sealed unit?
Old 29-10-2008, 09:02 PM
  #451
polly_x
polly_x's Avatar
You could but doubt that will help with heatsoak.
Old 29-10-2008, 09:51 PM
  #452
Twellsie
Twellsie's Avatar
im confused, where would the heat then come from?
Old 30-10-2008, 12:00 AM
  #453
polly_x
polly_x's Avatar
You have to remember where the intercooler sits on these type cars and that there is pretty much knowhere for the heat to escape when sitting still.
There is a rad, oil cooler and engine all very close and enclosed in a really tight space.
Old 30-10-2008, 12:12 AM
  #454
stevenebm
post whore
stevenebm's Avatar
Originally Posted by dvid
Joking looks great
that is awesome.defo gota be called brum nowcar looks fantastic b.t.w
Old 30-10-2008, 02:46 PM
  #455
wayneclayden
590 BHP/Ton
wayneclayden's Avatar
Stu.. what dash is that in your westy?
been looking at a few recently but not sure what to go for (without re mortguaging the house!)
Have you heard anything about the racepak IQ3?
Old 30-10-2008, 02:52 PM
  #456
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Its a AIM dash Wayne
Like this one i have for my Ka project.
Old 30-10-2008, 03:20 PM
  #457
polly_x
polly_x's Avatar
As below Wayne, its an AIM MXL. Not sure is can talk to an Emerald ECU like I think you run? You may want to call someone like Andy Smith at Dataspares to check though.
Old 30-10-2008, 03:22 PM
  #458
Chip
Chip's Avatar
The Aim works on an XML feed from the ECU, Autronic and the like certainly do this, im not sure if an emerald will though, chat to dave walker is your best bet.
Old 01-11-2008, 11:38 AM
  #459
Dan
Dan's Avatar
Does Luke not use an AIM MXL dash in his Mk3 Fiesta with Emerald K3 Management?
Any more pics of the Westy then guys?
Old 01-11-2008, 01:08 PM
  #460
wayneclayden
590 BHP/Ton
Good point Dan..
i will have a chat with Luke..
Old 01-11-2008, 02:38 PM
  #461
Garage19
Garage19's Avatar
You were right by the way Doug, Intercooler is up with Proalloy at the moment being modified to fit!
New rad and breathers and swirl pot and header tank all being made as well!
Here is how mine turned out in the end. Just so little room in these buggers.
Old 01-11-2008, 09:21 PM
  #462
hog
hog's Avatar
top read , reminds me of the issues i had with space !
Old 02-11-2008, 10:31 AM
  #463
polly_x
polly_x's Avatar
OK, so its nearly finished. Fitted all the new widetrack front suspension yesterday. Just need some correct length shockers as the original were manky and some spares I had are too long.
Today is finish all the shi**y little jobs day. Speedo sensor mounting and wiring, oil temp sensor mount and wiring, get the rev counter working correctly, mount the ecu, bolt the dash in properly, finish the intercooler mounts and bolt it down, boost hoses........
Jesus, I better get out of bed and get cracking!
Old 02-11-2008, 10:43 AM
  #464
MAD EVO 4
MAD EVO 4's Avatar
Only a few hours work today then
get some pics of the difference showing the new wider track suspension please
  #465
Chip
Chip's Avatar
On the home straight now Stu, can you visualise the red one back in your garage yet?
Old 02-11-2008, 02:12 PM
  #466
Porkie
Porkie's Avatar
The what one??!?!?!
Old 02-11-2008, 02:17 PM
  #467
Chip
Chip's Avatar
I doubt Stu remembers either
Old 03-11-2008, 07:23 PM
  #468
SeanB
SeanB's Avatar
I use an AIM MXL dash in my race car and I can bus all of the data from my Emerald K3 ECU to it. Works mint!!!
Old 10-11-2008, 12:09 AM
  #469
polly_x
polly_x's Avatar
Not much to update on. Its pretty much done now. Just awaiting the new shocks and a few little odds and sods to finish.
Been busy doing stuff on my own cars today!
8 new coilpacks, 8 New plugs, A pair of air filters and some new discs and pads was on the menu!
PROPER BRAKES!!!! The calipers on the bus are HUGE! Thats a 350mm x 35mm disc just to put it into perspective!!!
Old 10-11-2008, 08:12 AM
  #470
Ryan
Ryan's Avatar
what you fitted them on stu? not the RS4?
Old 10-11-2008, 08:32 AM
  #471
JHS
JHS's Avatar
Cayenne?
Calipers look the same as the ones on my Escort
Old 10-11-2008, 08:35 AM
  #472
Ryan
Ryan's Avatar
ahh yes of course, but i thought he had them on there anyway?
Old 10-11-2008, 08:45 AM
  #473
JHS
JHS's Avatar
If you open your eyes and read his post properly rather than just lookin at the picture
You will notice that he changed discs and pads on it
Old 10-11-2008, 09:09 AM
  #474
Ryan
Ryan's Avatar
pmsl, true
i'll go home now. TAXI!
Old 10-11-2008, 09:31 AM
  #475
polly_x
polly_x's Avatar
Obvisously too early in the morning for you Ryan! The RS4 has bigger brakes and 8 pots already!
Yesterday was a freshen up on the Cayenne. Its due its big service and was running a bit poorly too. Its fairly common for the original coilpacks to crack on these. When I removed them all 8 were badly cracked! Been gone for a while too which meant the plugs were non too pretty either! Anyways it runs like the day it left the showroom again now!
Can you believe the coilpacks are cheaper then the plugs! Ł12 per coilpack and Ł13 per plug.
Front brakes were tired too although they managed 40,000 miles on the same discs and pads. Thats pretty good in my eyes considering its been tracked quite a few times and weighs 2.5 tonnes!!! Saying that, its had an easy life in the last year ferrying baby and missus too and from the coffee shops.
All in all I reckon yesterdays efforts will reduce my service bill by around Ł1500 and all pretty straight forward to do.
Old 10-11-2008, 10:23 AM
  #476
Porkie
Porkie's Avatar
A BIT POORLY!?!?!?!?
A BIT TIRED!?!??!?!?!
is this like the tyre on the Audi that was ' slightly worn' ???
GOOON!
Old 10-11-2008, 10:25 AM
  #477
Ryan
Ryan's Avatar
yep was far too early.
bit more awake now.
Old 10-11-2008, 10:55 AM
  #478
polly_x
polly_x's Avatar
GOOON!
YES YES! Thankyou!! It was very tired! Missfiring under ANY boost!
Just like the cracked wheel on your Porsche too!!!!!
Time for a Remap now on the Cayenne me thinks!!! 550BHP here we come!!!
Old 10-11-2008, 11:13 AM
  #479
Chip
Chip's Avatar
Any pictures of the 12 quid coilpacks?
Old 10-11-2008, 11:18 AM
  #480
neal666
neal666's Avatar
what do you think of the cayanne i am currently looking at them but dont know anyone who has one to get their opinion? how is it on petrol? what engine size is yours? any problems to look out for? would you buy one again?
everyone i talk to says oh poormans porsche or porsche cant make 4x4`s etc etc
Quick Reply: ***FRIJJ the White Westy - I'm Declaring it finished!***
