trusty xr reborn
Old Jul 23, 2008 | 12:34 AM
reborns1's Avatar
reborns1
Default trusty xr reborn
Hi there this is my mate robs (trusty xr) 81 xr3
This is how she looks now but a couple of years ago it was a different story.
she came to me looking quite sorry for herself after having a major vandalism issue.
there were windows smashed deep body scratches all over dents stab marks in she spoiler headlining and interior mutilated not at all pretty
so i set about straightening her out.
It was while i was sorting the cosmetic stufff that i found the history.
Lets start with the doors
The passenger door was so badly damaged that rescue was not an option so a second hand one was sourced which was an appalling fit so i found another.
This came courtesy of a dead mk4 and the paint finish was rubbish the laquer had crazed so although it was solid it still needed four hours of prep to sort that out.
Drivers door was rough.
At some point in its life the corner had rotted out of it (as they usually do) and someone had rivitted a plate behind the rot and just filled over it.
There was no effort put into the frame. It was a floating skin secured by a long bolt,two washers and a grommet for support.
heres how not to do it...
Heres how i did it.
Budget was a big concern so after trying to get a skin which to be honest probably wouldn't have made the door any better it would still have a rotten frame. I decided to make a repair section like this.
first i drew a template of how the door was to be shaped by marking out the lines with masking tape and following them round with a clear pen line.
Note I made marks on another piece of tape to line my "template" to later.
Then I removed the template and cut out the poor repair whilst still leaving the other pieces of tape on the door.
I roughly shaped a piece of plate to fiit the hole and tried to maintain the contour of the door so as to minimise filler and tacked it into place.
Laid my template back on again and cut round it.
Then I turned my attention to the frame. Now a better man than me would have shaped the lower part of the plate with a lp to fold over like a skin, I tried that a couple of times but found that route to create serious ripples to the botton of the door which would be evident against the sill so i went for cosmetic surgery and cut a "lip" out of a piece of plate and tacked it into place then seam welded the edge and shaped with a grinder care was taken not to get the metal too hot as distortion would definitely occur.
Try it on
A couple of spreads to even everything up.
Et voila a properly repaired door.
Old Jul 23, 2008 | 12:38 AM
boothy's Avatar
boothy
looks shit hot that mate,i chucked out a door because of that, couldnt do that though
Old Jul 23, 2008 | 08:42 PM
reborns1's Avatar
reborns1
cheers for that boothy more to follow
Old Jul 23, 2008 | 09:37 PM
reborns1's Avatar
reborns1
Scuttle next.
Again nasty hole plated with ali rivetted on and skimmed over.
I cut out the corroded metal, treated the exposed part of the bulkhead with an inhibitor (kurust i think) and made a plate to fit the majority of the hole. It got a bit complicated around the screen aperture so I tacled that seperately.
I was careful to maintain the original shut line to the back edge of the bonnet.
Then, I made a repair section to the screen apperture.
And welded that in too.
The trickiest bit of that was trying to stretch the metal between the swage lines like a fan to allow the correct contour of the screen apperture to be acheived.
Tidied up and ready for a skim.
Skimmed.
A couple of rubs (about an hour later actually)
And etched. phew another bit done.
Old Jul 23, 2008 | 10:50 PM
NEWTON's Avatar
NEWTON
very good
Old Jul 23, 2008 | 11:14 PM
reborns1's Avatar
reborns1
There were various other bits around the car I repaired like that just the usual really.
Passenger door shut.
Drivers side sill (Front section)
Once apon a time, there was a key operated pony alarm system which had a barrel mounted in the o/s quarter panel.
And then it didn't any more.
Onto the osr wheelarch and inner wheelarch at the end of the sill (you know the bit i'm talking about)
This Bit
I,m afraid I've got no earlier pictures of this as this is where I started and besides which there was nothing to take a picture of.
This too was harder than it looks. Primarily there is two plates. one which makes up the inner sill return and one that becomes inner arch.
I Should have made him buy an inner arch
The lip that has the wheelarch welded to it is rolled two different directions. It twists downward and curves inward the only way I could replicate this shape was to put multiple cuts in a length of L shape metal then do the same again on the other edge.
Once I was happy with the contour of the arch i had to weld up each cut which I think was about 50 welds. This took an age...
Then of course the outer arch had to be fitted.
And the open bit of sill closed up...
More filler
More etch
As you can see dents were plentiful all over this car. Both quarters, roof, bonnet, tailgate, rear panel and wings all recieved a couple of hammer blows and I don't think it was a little hammer.
Bonnet was not nice.
Thats about it for damage except for the remaining key scratches which though extensive were easy enough to sort out before primer.
thats enough for tonight I'm going to bed...
Old Jul 25, 2008 | 05:49 PM
trusty xr's Avatar
trusty xr
thanks phil thats my car alright, you done a cracking job and could not of done it with out ya . at all the shows now and will be on xroc stand at ford fair next week!!!
cheers buddy
Old Jul 25, 2008 | 06:44 PM
reborns1's Avatar
reborns1
Default Paint work
With repairs finally complete and i was happy with the shapes i took the car to the paintshop for a couple of coats of hi-build primer.
While i was at it it made sense to paint the shuts so final paint layers could be applied to the whole car in one go.
And back from the paintshop for more elbow grease flatting, flatting and more flatting.
Old Jul 25, 2008 | 06:50 PM
nickscunny's Avatar
nickscunny
looks great.....
Old Jul 25, 2008 | 07:19 PM
749steve's Avatar
749steve
doing a good job there
Old Jul 25, 2008 | 07:36 PM
reborns1's Avatar
reborns1
And back to the paintshop.
Time was of the essence when it came to topcoat it was an all weekend job but had to be back by monday painted and polished.
There were three guys on this and I couldn't have done it without them.
Big thanks to shaun, carl and jimmy.
All masked ready to go.
It was a toss up what process we were going to use for topcoat.
We opted for clear over base as defects could be polished out easier than a solid colour and we thought a laquer finish would polish to a higher standard.
Here she is in the first coat of base.
And here shaun laying down the final coat of lacquer.
mmmmmmm shiny...
Followed by several hours flatting, flatting and more flatting.
And polishing, polishing and more polishing.
And this is where i left it and rob took over with final fit and clean up.
Check it out in the flesh at ford fair.
Thanks for looking
check out my current project
series one rebuild https://passionford.com/forum/restorations-rebuilds-and-projects/247462-series-one-rebuild.html
And watch this space for a future mk1 track car build
and the resurrection of a ren5 gtt
Feedback appreciated
Old Jul 25, 2008 | 08:03 PM
reborns1's Avatar
reborns1
Default final pics
Old Jul 26, 2008 | 01:08 AM
danny_boy699's Avatar
danny_boy699
chatter 4 life
nice work fella how come some 1 smashed it up
Old Jul 26, 2008 | 11:13 AM
Lee Reynolds's Avatar
Lee Reynolds
God that looks lush mate. I cannot wait till me black RSi shell looks like that
Keep em coming
Old Jul 29, 2008 | 09:12 PM
reborns1's Avatar
reborns1
Dont know mate, jealousy i suppose
Old Jul 29, 2008 | 11:27 PM
paul16v's Avatar
paul16v
Monte 087
Very nice car i was admiring it at classicford this year, i actually took that first pic lol
Old Jul 30, 2008 | 12:58 AM
reborns1's Avatar
reborns1
I,m glad you did cos its the only one i've got of it on clovers there are more on here of it on rs7s.
but definitely clovers for the shows. i think
Old Jul 30, 2008 | 02:22 AM
pano's Avatar
pano
" perfecto" gr8 job !!!!!!!!!
Old Jul 30, 2008 | 06:03 PM
MrCapriScort's Avatar
MrCapriScort
Old Fords Never Die
Top repair job mate, looks well nice now
Old Jul 31, 2008 | 12:16 AM
reborns1's Avatar
reborns1
Thanks for the comments guys
Old Jul 31, 2008 | 04:48 AM
paul16v's Avatar
paul16v
Monte 087
No worries mate, it was one of my cars of the show if im honest just looked so good like ide just stepped back in time 15 year's!! enjoy it bud there isnt many left like it
Old Aug 1, 2008 | 11:33 AM
trusty xr's Avatar
trusty xr
guys theres some great comments on my xr3 & i must say i apreciate them !!
i could not of done this w/out phils help i owe alot to him!!! he really is the man!!
the car is at all the shows on the xr oc stand & will be over at ford fair on sunday so come over & say hello !!
Old Aug 1, 2008 | 11:36 AM
trusty xr's Avatar
trusty xr
by the way it was smashed up coz i was a clown & the mrs found out !!!
she took a slege hammer to it in the garage !!!!!
i was sorry , she was sorry & now im a good boy & she stays out the garage!!!
see full pictures of resto at ford fair 2008 on xroc stand!!
see ya there
Old Aug 14, 2008 | 12:54 AM
reborns1's Avatar
reborns1
series one is out of garage and the reborn ren5 is just around the corner
Old Aug 18, 2008 | 09:17 PM
reborns1's Avatar
reborns1
Default It never rains it pours
I have spoken to rob today
and the reborn xr has suffered a little engine fire.
I stress the word little. no major damage not even scorches to the wings Apparantly.
But I get the feeling that an overdue engine bay revamp awaits me (or someone).
Apparantly it was due to oil leaking onto exhaust manifold from a breather.
It seems more posts may be In our future...
Old Aug 20, 2008 | 03:30 PM
trusty xr's Avatar
trusty xr
yes phil small bieng the word . no paint damage or dmaamge thank god just eerything in the engine is covered in a soot colour but wipes up easily tho!!
got to it just in time tho mate
but a top end rebuild on the way & a engine bay paint for ya !!!
coming your way soon phil
Old Jan 5, 2009 | 06:57 PM
PoloKidger's Avatar
PoloKidger
Capri For The Win!
Love the clover rims, gettin some on my fiesta off my dads escort xr3i that got robbed n then crashed into a bus shelter. Got it back in a right state, been scrapped since but still got the rims.
Old Jan 5, 2009 | 08:29 PM
Wow well done mate top work.It looks so shinny,i love black cars.
Old Jan 31, 2011 | 10:16 PM
trusty xr's Avatar
trusty xr
hi guys
car still looks just as good as the day it was done currently. now due to be in ford titled magazine with a large heritage spread on it.
& still only done 2k since the resto lol
top work philipe !!!!!!
Old Jan 31, 2011 | 10:31 PM
trusty xr's Avatar
trusty xr
with its garage partner
southend cruise last summer
current
Old Feb 1, 2011 | 08:35 AM
Rab's Avatar
Rab
Fucking superstar........
Still looks spotless!! Top work!
Old Feb 2, 2011 | 10:59 PM
reborns1's Avatar
reborns1
Well, well good to see her all bulit up again.. thankfully no return visits eh Rob lol
I reckon we shd be on for the fordfair convoy this yr matey. good to hear from ya..
Old Feb 2, 2011 | 11:10 PM
trusty xr's Avatar
trusty xr
good stuff phil , giss a bell mate ,
ill let you know about the convoy nearer the time
Old Feb 2, 2011 | 11:11 PM
reborns1's Avatar
reborns1
Originally Posted by trusty xr
hi guys
Well Rob when it's published. get me a copy
TrevCos
Escort MK 5 / MK 6
94
Dec 19, 2015 09:50 AM
kitchy
Sep 26, 2007 05:51 PM
biglee
21
Sep 17, 2007 12:16 PM
fatty
24
Mar 20, 2007 03:23 PM
159
Jan 9, 2007 07:47 PM
