My XR3i+..... New engine and clutch 27/01/16
#242
Fleet Manager
looks good m8 I remember seeing you 4 -5 years ago round chadwell st mary way when I had my white xr3i with rs turbo wheels on and rs body kit I do miss that car bet its in scrap yard heaven now
marky_g (07-03-2016)
#245
#246
Fleet Manager
Fleet Manager
Finally bought a house with a garage so its now right under my nose with all my tools and spares in one place, storage wasnt kind to it having a leaking roof has pretty much killed everything under the bonnet
But none the less its home and back together with the plan being to get it running and mapped before restoring it (again)
turbo m (10-09-2019)
marky_g (10-09-2019)
#249
Fleet Manager
So the final things to bolt on were the battery cables and the starter solenoid broke up in my hands
new solenoid on order, so thought i may as give the rusty steel body a paint
S
S
#250
Fleet Manager
marky_g (14-10-2020)
#253
Fleet Manager
yeah mate on and off took the tank off monday after tracing the lack of prime to the pump and found the in tank connections to be useless, just waiting on some fuel proof heat shrink and probably a new tank as this ones full of rust then i think ill get it booked in for a set up.
#255
Fleet Manager
sender is seized but i have another somewhere in my many parts boxes lol
im thinking of going universal sender but dont think anyones done it on the standard tank.
#256
Woow lol must feel like christmas nearing completion , cracking job though. If you manage the universal keep me in mind for selling your original sender
#257
Fleet Manager
Fleet Manager
Well pumps been rewired
new strainer on pump
tanks been cleared of as much debris and rust as possible even chucked some BuiltHamber DeoxC in didnt do much so a new tanks in order
just have a fuel line issue to sort out im planning on using pneumatic fittings and nylon line to replace the worn out pipe
#260
I used them as Oddchild supplied me them when I was on cossie management. I don't think they are meant to be used with fuel but the caused me no issue.
I use metal connectors now with braided lines where needed.
#261
Fleet Manager
Fleet Manager
turbo m (31-07-2021)
#267
Excellent 👍
#270
Fleet Manager
Pretty big update
front ends freshly painted wing repaired after almost 15 years too
Wing filled and In primer
Cool lourvers bonnet
Cut out front bumper from dan arrowsmith
Cut out fromt bumper from dan arrowsmith
Primed
Painted
Bumper inserts and bottom edge painted
Finally a fresh face!
Primed
Painted
#271
Fleet Manager
Cars currently messing me around with an intermittent ignition loss issue im hoping is down to a few bad earths, ill be having a play in the next few days.
also to hide the horrible archs and sills untill a time i can get everything done in 1 go including a repaint ive bought an S2 body kit, something i never thought id do for this car but needs must.
#272
Fleet Manager
Decided to fit a body kit for a while as its got to have sills and rear arch's anyway
Changed the metal made up boost hose to a proper escort RS hose
#274
I like when people post stuff like this, I dont feel so stupid when I do it. Hopefully an easy repair.
marky_g (03-10-2023)
vibrating_cake
39
14-07-2011 12:54 PM
Minirotty
43
01-03-2010 05:08 PM
