Zzz...Zzz sleeper granada
Old 10-05-2011, 08:04 AM
  #961
stevieturbo
C**t
stevieturbo's Avatar
Originally Posted by prasac
looking gr8 mate. hope u have more luck then what we had with LS coils, we had nothing but problems with them on our 2JZ, the factory Ford coils are much better.
What problems did you have ? People all over the world use them with great success.
Old 11-05-2011, 01:27 AM
  #962
prasac
prasac's Avatar
LS coils are very lazy, they have a 5ms dwell (charge time) with higher rpm it couldn't provide the spark needed as it didn't charge up enough, it kept spluttering as you can hear in the video. went back to the original dual post coil and CDI 2ms dwell it was fine. if he ever decides to run a cold fuel like E85 or methanol it will be worse. since the change has run 8.0@174 best
http://www.youtube.com/watch?v=7xvcs8kcl24
Old 11-05-2011, 06:33 PM
  #963
stevieturbo
C**t
Which model LS coil were you using ?
You're going pretty damn fast there lol
Old 11-05-2011, 08:55 PM
  #964
meanxpress
meanxpress's Avatar
saw your car on monday at elmia and it's a pure joy to look at
//janne
Old 11-05-2011, 09:50 PM
  #965
prasac
prasac's Avatar
i don't remember which ones. we had them recommended to us by a few people who ran them, but they weren't pumping in the same boost 30+psi. our car just didn't seem to like it
Old 11-05-2011, 10:05 PM
  #966
Zzz...Zzz
Zzz...Zzz's Avatar
Nice piece of kit!
In regard to LSx coils - what do you mean is high rpm?
In these thests, 2ms seems to be a decent dwell time for LSx coil
http://forums.hybridz.org/index.php/...g/page__st__20
Old 11-05-2011, 10:12 PM
  #967
Zzz...Zzz
Zzz...Zzz's Avatar
//janne
TAKK!!!
Old 11-05-2011, 10:17 PM
  #968
Zzz...Zzz
Zzz...Zzz's Avatar
"Happy" to report that the cam sensor issue is fixed with the change to a hall sensor!
Not to happy to report we had some cam gear fixing failure resulting in 2 inlet valves giving up....
ATM just focusing on the pure luck of not damaging any other valves, and that a pair of new ones is on a plane to norway about ...now, togethger with all new cam gears, tensioners and chains....dont want to risk this happening again...
Damn i´m tired now!! :/
Old 11-05-2011, 10:44 PM
  #969
prasac
prasac's Avatar
Originally Posted by Zzz...Zzz
Nice piece of kit!
when u add a cold fuel like E85 or methanol, the spark provided won't be enough. we noticed with E85 the power was rolling over and spark starting to break down. soon as we put the M &W CDI setup back in it immediately picked up.
Old 11-05-2011, 11:03 PM
  #970
Zzz...Zzz
Zzz...Zzz's Avatar
Hmmm, i suspect it is your warm Aussie weather that messes up....
We use these coils in norway with 4cyl turbo cossie's , 5 cyl audi's and 6cyl bmw's , some of them doing over 1000bhp on e85 and they work just fine...?!
Old 11-05-2011, 11:46 PM
  #971
prasac
prasac's Avatar
must be an Aussie thing, most people tend to stay away from them. i know a few cars running them, but i also know alot of people that have had problems with them. what fuel are you going to be running?
Old 12-05-2011, 08:01 AM
  #972
SWR
Mad engine scientist
SWR's Avatar
Joel will run E85 for the high horsepower stuff...
Old 12-05-2011, 08:57 AM
  #973
marky_g
Fleet Manager
marky_g's Avatar
amazing mate its a credit to you its the mos insane yet normaly looking car ive ever seen
Old 29-05-2011, 04:49 PM
  #974
RS 5tu
RS 5tu's Avatar
Zzz...Zzz
What kind of power to weight you think it its?
Old 29-05-2011, 05:27 PM
  #975
SWR
SWR's Avatar
Around 2000 bhp and about 1400 kg's..
Old 17-06-2011, 04:05 PM
  #976
andy escos
andy escos's Avatar
any updates Joel
Old 17-06-2011, 04:45 PM
  #977
stevieturbo
C**t
Nice piece of kit!
Interesting. In other tests Ive seen them use up to 5ms and suggest that is what is required of an LS coil.
http://www.megamanual.com/seq/coils.htm
and test video
http://video.google.com/videoplay?do...5754251&hl=en#
Old 18-07-2011, 04:45 PM
  #978
stu21t
stu21t's Avatar
Any progress?
Old 18-07-2011, 07:34 PM
  #979
SWR
SWR's Avatar
Joel got his repaired head back yesterday... I would guess he's wrenching at the moment.
Old 18-07-2011, 08:44 PM
  #980
Spiky
Spiky's Avatar
What happen to the head?
Old 18-07-2011, 10:35 PM
  #981
SWR
SWR's Avatar
The "cam gear issue" that Joel mentioned above was an unfortunate mix of Koenigsegg cam covers and shiny Ford cover bolts... the latter which turned out to be 5mm longer and that made them bottom out in the cam bridges where they made a dent in the cam bearings.. pinching the cam, hence the reason for Joel's starting issues, the engine hardly turned over and the added friction slowly twisted the cam gear out of synch and it hit two valves. And it ripped the better part of the cam bearings out of the left head and bent the intake cam, while at the same time making two HUGE scratches in the middle two intake cambearings, both on the cam and in the head..
Typical bad luck, they bottomed out at the same point that the cam covers hit the head, so the additional torque to twist the coverbolts seemed to come from the cover tightening on the gasket surface.. not so, we learned.
In other words, had they been 2mm shorter it would be no issue, had they been 2 mm longer we would have noticed the cover not hitting the head.
Old 19-07-2011, 01:40 AM
  #982
prasac
prasac's Avatar
it's always a little thing that spoils the fun.
Old 19-07-2011, 06:40 AM
  #983
Spiky
Spiky's Avatar
thats a proper nightmare
shame to have a set back like that
Old 30-07-2011, 05:21 PM
  #984
Zzz...Zzz
Zzz...Zzz's Avatar
At 17.37 today , 4.7 liters of twin turbocharged V8 came to life,with a roar giving the chills to everybody present!! All it's 32valves was working perfectly and the comp turbos was able to bed in as well. Everything is all good with it's creators, whom are having a little rest right now... :P
Search for "Koenigsegg granada start-up" on youtube in about 50 minutes to hear and see the start up
Joel
Old 30-07-2011, 05:49 PM
  #985
COCHYN
COCHYN's Avatar
LINK!!!!
Old 30-07-2011, 05:56 PM
  #986
Maxwell
Irregular Poster
Maxwell's Avatar
The youtube video isnt on Joel
Old 30-07-2011, 06:11 PM
  #987
Zzz...Zzz
Zzz...Zzz's Avatar
I said "in about 50 minutes" !
It is done done uploading, youtube is processing the movie now
/J
Old 30-07-2011, 06:13 PM
  #988
Zzz...Zzz
Zzz...Zzz's Avatar
http://www.youtube.com/watch?v=DjIkknle6Q8
Old 30-07-2011, 06:27 PM
  #989
andy escos
andy escos's Avatar
great news Joel i bet your well happy after all the problems
Old 30-07-2011, 07:03 PM
  #990
H3lsing
ffoc.co.uk
H3lsing's Avatar
Awesome work there, congrats to all her crew .
Old 31-07-2011, 08:12 AM
  #991
Zzz...Zzz
Zzz...Zzz's Avatar
Tnx mate, it reeeeeally was a high yesterday, after the time consuming setbacks we´ve had this was saught for, to bad I leave for florida on saturday(!)
Hope you´re all good and that you´re still cracking on at your escort!!
/J
Old 31-07-2011, 08:13 AM
  #992
Zzz...Zzz
Zzz...Zzz's Avatar
Tnx mate!!
One more vid :
http://www.youtube.com/watch?v=sAnCk...e_gdata_player
Old 31-07-2011, 03:43 PM
  #993
gjh
gjh's Avatar
Awsome stuff!! Its a monster!
Old 31-07-2011, 08:23 PM
  #994
Slik Johnson
Slik Johnson's Avatar
ITS ALIVE!!!!!!!! Awesome stuff guys
Old 31-07-2011, 08:57 PM
  #995
PileOfRust
PileOfRust's Avatar
animal! need some videos in and outside of the car! maybe cruising on a motorway, gunning it and spinning the rears up at 90+ lol
Old 31-07-2011, 10:11 PM
  #996
lanfire
lanfire's Avatar
Fantastic
Old 31-07-2011, 10:23 PM
  #997
Spiky
Spiky's Avatar
awesome guys
Old 31-07-2011, 10:54 PM
  #998
Minirotty
Lucifer II - 666
Minirotty's Avatar
Brillaint, congratulations!
Old 01-08-2011, 10:03 AM
  #999
GINGExR2 T
GINGExR2 T's Avatar
That must be a great feeling after all the hard work thats gone in to it.
Congrat's
Ginger
Old 01-08-2011, 12:37 PM
  #1000
gjh
gjh's Avatar
What he said^
Edit- I'm the 1000th post!!
Quick Reply: Zzz...Zzz sleeper granada
