Lee's MK1 Cossie Powered Escort Rebuild
nice motor there mate, i plan to get myself a mk2 and stick a load of rally kit under it. not to that level/trackday car tho
can i ask what are those black bits of box section on the 8th pic on front page?
Originally Posted by Phil
Can you give me any more info on the axle (i.e. cost and full spec) as i'm after one exactly the same (PM me if you like)!
Infact our cars should be almost exactly the same apart from colour and you have metal arches!!!
what you want is a baby atlas with a Z.F plated diff........well gartrax do a baby atlas with fully floating shafs for about Ł2.5k
you can buy second hand ones for about 500 or you can use a capri and get it shortened... if you do that ....go for the capri 2.8 special axel
cheers marco
IT RUNS
after 18 months we have got it started today . i must admit i was a
bit nervous when i first turned the key , but apart from the idle speed
control valve being shagged it sounds awsome . when i say we got it started
i realy mean dingy and martin got it going i was just standing around like
an expectant father . i must say a big thanks to you 2 for the time you have
put in to it
thanx for everyone who has helped me with this car.
cheers lee
put in to it
cheers lee
Smashing car lads,a credit to the people involved.
I noticed the turbo has no water cooling pipes attached,is that because u had'nt fitted them yet or are u not using them,how will that effect the turbo in operation from day 2 day??
Mick.
Mick.
What can i say peeps it runs
fair play to Dingy he has done a top job on the loom all i can say it's a credit to you
Fair play to martin H aswell for come over and giving her the once over
Lee
when i am testing it out for you
fair play to Dingy he has done a top job on the loom all i can say it's a credit to you Fair play to martin H aswell for come over and giving her the once over
Lee
Hi mate. I got a MK1 escort and i want to put cosworth power into it but i need some more information, could you help me out either by emailing each other or could i phone you? Thanks PAUL
Originally Posted by Mark_1
What a nica car
Do you have any pics of the radiator/intercooler assy?
And where did you order it and what was the cost?
Hi Mate
all the i/c and rads are made by Radtec .... proper well built rad and i/cooler
Marco
Originally Posted by marco polo
they are not 235 they are 245/35-15 i don't see porches or ferrari's /Bmw's mone about wide the tyres are do you .... at the end of the day there no substitute for grip
don't get me wrong, think it's an awesome car
Steve
big thanks for doing loom,.. he was going to leave the loom you know at one point ..i said to you have to do it no if's or buts ...
i said to him these cossie engine looms are too old , no point building a decent car without a brand new loom
atlast is ready the engine is all run in now he told me today,he recons all the bolts keep coming lose everywhere lol
i said to him what do you expect when you have got metal to metal everywhere ..all it needs is a bit of lock tight here and there and a bit lockwiring also
Bedford will be only a test day just to iron out any probs ....if everything is ok and it's running fine , i will put him in the passanger seat and open it up for him
cheers marco
cheers marco
Originally Posted by Lee Reynolds
only just seen this....what a read
If i was 95% sure i was going mk1...im now 110%....thats THE BEST mk1 ever seen
Plus you want to see the way it went at Bedford. It goes as good as it looks!!!!
Sean..
Sean..
Did you supply any bits for it? I know you mentioned some stuff last year when i was on about getting one???? That car really is an inspiration
