mk3 escort,2 litre zt engine rethink time
Old 09-03-2009 | 10:04 PM
  #161
rst in breaking's Avatar
rst in breaking
it should be poss though just more grief and not the preferred way
Old 09-03-2009 | 10:09 PM
  #162
Rick's Avatar
Rick
If your on an MS1 chip, you'll need the high res code for greens, which does need resistors. If you're on an MS2 chip then you can set the PWM current limit to 25% and run without resistors.
Rick.
Old 09-03-2009 | 10:12 PM
  #163
danny_boy699's Avatar
danny_boy699
chatter 4 life
ffs , any more bad news, any 1 know where ican get a base map put on to run me car.
yes paul you know what will come next
Old 09-03-2009 | 10:14 PM
  #164
rst in breaking
you best tell me, theres a few things it needs to start atm lol
Old 09-03-2009 | 10:16 PM
  #165
Rick's Avatar
Rick
I can send you a base map, but i'll need to know how you are triggering (36-1 i guess), what chip you have and how u are firing the coils, EDIS or direct fire.
Rick.
Old 09-03-2009 | 10:21 PM
  #166
danny_boy699
chatter 4 life
engine has 1600cvh efi flywheel, probley runing EDIS though zetec coilpack, my ms is ms1 v3. rick if u tell me what you need to know i can tell u but please spek english not to good with all this ecu spek
paul it will end up in a pill of bits last i was gonna do last week
Old 09-03-2009 | 10:24 PM
  #167
rst in breaking
if you do need ballast resistor i think o have some laying around which came with my emerald, but why not opt for some high inpedance injectors instead? probally more variety?
Old 09-03-2009 | 10:27 PM
  #168
Rick's Avatar
Rick
OK, with MS 1, you need resistors for the Greens. If you have any spare cash, get an MS2 chip -about 40 quid - it is much better.
Old 09-03-2009 | 10:29 PM
  #169
rst in breaking
im not to clued up on this ms stuff either so sorry if im complicating things. is there really any difference between them other than not needing ballast resistors?
Old 09-03-2009 | 10:55 PM
  #170
danny_boy699
chatter 4 life
rick where will i get a ms2 chip from.
same ere paul i not that clued up
Old 10-03-2009 | 08:21 AM
  #171
Rick's Avatar
Rick
This guy will supply you one: http://www.extraefi.co.uk/ms2_products.htm
It's much better, it gives very fine control of big injectors - i ran a totally std 1.6 on greys with this and it idled at 15:1 without the close loop on. Latest codes support fully sequential, individual cylinder trim etc. Code is constantly being updated with new features.
Rick.
Old 10-03-2009 | 02:36 PM
  #172
danny_boy699
chatter 4 life
so i get this chip thing, then i can run 803's using this with out ballast resistors, then just need a base map to install on my ms to run my car till i get it mapped am i right or am i miles away
Old 10-03-2009 | 05:08 PM
  #173
rst in breaking
why are you soo eager to run greens if you havnt bought them?
Old 10-03-2009 | 06:01 PM
  #174
danny_boy699
chatter 4 life
been saying from day 1 car will have a zetec with m/s, greens and other things, gonna get some greens next saveing for your turbo, waiting to be payed for a few thing
Old 10-03-2009 | 06:05 PM
  #175
rst in breaking
go high inpedance and it will rub on what you have, probally cost less to buy + more options
Old 10-03-2009 | 06:28 PM
  #176
danny_boy699
chatter 4 life
been told greens are high inpedance but not sure, gonna get the mk2 chip thing rick was on about then i work it our from there
Old 10-03-2009 | 09:55 PM
  #177
Rick's Avatar
Rick
greens are low impedance.
Old 10-03-2009 | 10:00 PM
  #178
danny_boy699
chatter 4 life
ah right and ms1 runs high impedance. rick if i send u my ms could you put a base map on it and the ms2 chip thing or ballast resistors, for some coin. i tryed to get it loads up on to my pc today to have a look but it all french to me don't under most of it
Old 10-03-2009 | 10:03 PM
  #179
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
no edis on your megasquirt mate its wasted spark set up and i have read through the manual the megasquirt you have can run lom imp injectors NO RESTERS NEEDED mite evon be an ms2 lol
Old 10-03-2009 | 10:07 PM
  #180
danny_boy699
chatter 4 life
ah that sort of helps me out a little, but still don't make much senser as i thick as fuck
Old 13-03-2009 | 08:14 PM
  #181
danny_boy699
chatter 4 life
little update with good pics, fitted my front springs, after cuting 2 coils off but it still to high, and made another addpeter plate for me head and striped it down to be skimed and ported, also fitted a new sticker just for a laugh
Old 13-03-2009 | 08:58 PM
  #182
Rick's Avatar
Rick
Does the rover manifold clear the servo ok? Dropping my engine in over the weekend.
Old 13-03-2009 | 09:10 PM
  #183
danny_boy699
chatter 4 life
it clears but throttle body it about 3 to 4 mm away but thats when the thottle is closed when it open u have loads of room, but if ya gonna drop ya engine i would say remove in let first or the top half
will get u a pic of my ms up asap fella just i at my parents and my ms is at home 25 miles away
Old 13-03-2009 | 09:28 PM
  #184
rst in breaking
getting there, did you get the damaged wheel repaired?
Old 13-03-2009 | 09:36 PM
  #185
danny_boy699
chatter 4 life
nah not yet gonna take it in tomorrow to my mate and leave it with hime to get sorted
thanks for the turbo paul
Old 13-03-2009 | 11:39 PM
  #186
westus1's Avatar
westus1
where'd you get the sticker?
i want 1
Old 13-03-2009 | 11:48 PM
  #187
danny_boy699
chatter 4 life
off ebay mate guy has a site www.slook.com or co.uk
Old 14-03-2009 | 08:29 AM
  #188
jonnyrsturbo's Avatar
jonnyrsturbo
is half man, half amazin'
coming on nicely now mate
Old 14-03-2009 | 12:38 PM
  #189
danny_boy699
chatter 4 life
yeah not far off, it all a case of building it up
Old 15-03-2009 | 08:50 PM
  #190
mad dog younge's Avatar
mad dog younge
2 moro never comes then eh.as for ms danny you are doing it all wrong.803s are far to big mate .your on the dole and wont be able to afford the fuel to start it never mind run it .my fiesta was at 7 mpg and i had a good job
Old 15-03-2009 | 09:01 PM
  #191
rst in breaking
will try my best to get turbo out before saturday mate, mite look up the wieght and try sort a courier, send me over your address fella
Old 15-03-2009 | 11:36 PM
  #192
danny_boy699
chatter 4 life
younge not runing 803's any more, not assed on fuel, it being built to be used and kicked from a2b, will nack it from when i start it to when i turn it off, so will use a nuff fuel any
paul no rush for turbo i still ow u 15 when this dick head pay for these wheels
Old 16-03-2009 | 08:22 AM
  #193
Its getting there mate slowly but surely.
Old 16-03-2009 | 10:18 AM
  #194
clarke5700's Avatar
clarke5700
looking good mate
Old 16-03-2009 | 12:12 PM
  #195
danny_boy699
chatter 4 life
younge forgot all about bring the wheel, went to weight some scrap in and get the alloys for the corsa, and u know i don't get up till about 1
Old 16-03-2009 | 09:52 PM
  #196
mad dog younge
well danny good luck as you will need it mate .i done a ms conversion last week and booked it in for mapping .thats another point get some one to send you a base map ,,,,and fuck your engine .like i said good luck you will need it.youve got no idea .
Old 16-03-2009 | 10:49 PM
  #197
danny_boy699
chatter 4 life
only need a base mate to start it, once it runing i geting towed to motorscoop to get maped.
Old 17-03-2009 | 11:12 AM
  #198
ScoobyMatt's Avatar
ScoobyMatt
Sorry fi this has already been answered..
The MS1 V3 WILL RUN low impedance. You will need to set the injector characsteristics in Megatune.
The PWM time should be 0.1 and the Max current should be around 70%
So to clarify, if you have an MS1 V3 MS ecu it WILL RUN low impedance injectors... we map them every day :P
Cheers, Matt (M-tech)
Old 17-03-2009 | 11:16 AM
  #199
ScoobyMatt's Avatar
ScoobyMatt
Rick, I dont beliebe the MS2 supprot fully sequential or cylinder trim, that will be the sequenceer which uis not yet out.
The MS2 is a good chip, but we use MS1 and have no probs what so ever. The resolution is higher on the MS2 as are the tables, but becuase the MS1 fully interpolates its not really required.
Matt
Old 17-03-2009 | 03:25 PM
  #200
nsdrst's Avatar
nsdrst
look great mate keep up the good work
Quick Reply: mk3 escort,2 litre zt engine rethink time
