Ian Howells 2.3 Duratec Turbo Engine - Pics Inside
#84
Got to 500bhp with ease before the turbo started to surge
New turbo is on its way to do the job
Will resume dyno session with new turbo on Monday
#85
Originally Posted by AustenW
Taken from another board
For those interested in the engine and what I've done, he's the story cut short...
2.3 Ranger 87.5 bore x 95mm stroke
DKE custom crank to reduced to 83.00m stroke
Block liners removed along with most of deck face and replaced with Ductile Iron Items from Darton Sleeves, and bored to 91.00mm.
Custom rods to give a Rod length/stroke ratio of 1.98. Custom pistons for 7.4:1 CR.
Ally main cap ladder remachined to allow fitment of 2" thick ally girdle. Head studs in main stud locations. Head anchorage now by M12 Cummins diesel studs (drilled deeper). Pace dry sump kit.
Top end is a development head by Jim Garrard at CNC heads, valve seats changed for Nibron, custom made Valves, my spec cams and valve train.
Inlet manifold is an early prototype from Cosworth America which I reworked and added the extra 4 injectors into (8x 625cc/m). Custom Fuel rails.
Exh manifold is 321 SS in 1"3/4 bore. Turbo is Turbonetics T72 with P trim turbine and 1.00 A/R housing (spec'd to suit my cams).
It will run on 102 Oct fuel without and help from NoS and should crack 700 without sweating too hard, but if 800 is close by, it may be given one last push
Lookss good. Can't wait for the price/availability of these engines to come down to where zetecs are now.
#88
bigger exhaust housing needed then
#91
DEYTUKURJERBS
Other issues making it surge, surely?
#93
#97
Witch forum was this taken from?
#102
Originally Posted by jacko
what would it cost to build a motor like that compared to a yb of the same sort of power
They are getting 1200bhp out these in the States apperently
