MY 205 GTI-6 Supercharged Track car
#363
Originally Posted by Spiky
yeah
i'm running a 309 rear beam
#364
the 306 is a wider beam than the 309, and wont fit mine.
when you see my car, you will notice i have ZERO room for a wider beam..lol, but it does look cool and wide at the rear
i think the 309 at 20 and 21??? though i'd have to check.
#365
I think 309 is 21 torsion Bar and I think 306 is 21mm. will find out soon, Might just rebuild it with standard torsion bar and try it and then uprgade it it feels sloppy on track. not sure!
#366
there are some people that can supply some thicker bars
Phone:
0116 279 205 7 (Unit)
07749 286334 (Paul)
from http://www.205parts.com/common.php?name=contact
though i guess you are able to make your own???
Phone:
07749 286334 (Paul)
#367
cheers for that, Something like this I wouldn't make as its not worth the set up time, easier to buy something proven I want to enjoy this car.
#368
hope you make it light and more powerful
my 205 with the same engine passes a 306 fairly easy
i did this at donny few weeks back, to say i was shocked is an understatment
but, obviouslly i dont know how hard he was trying, i know i was 110%
if ya looking for a 306 track prep or more idea's, check my mates car out
http://talk-torque.com/forum/viewtopic.php?t=1912
funily enough thats where my engine came from
are you keeping the 306 gti6 engine? if so what mods you got planned?
#371
Thats a good link, I see some of the pics before. not so sure about the ERW tubing in the cage though for the extras Shifter is similar to what I got planned
Be fun trying to keep up with yours in the heavy weight! lol
#372
Originally Posted by Danny B
My efforts will be to make it safe and handle well to start with. I do have throttle bodies and cams wil be going in but not until I've done a couple of track days and got the car set up well.
why is the shifter like that? can that mod be done to the 205???
with my limited track experience, i sure you'll be fine
#373
why is the shifter like that? can that mod be done to the 205??? Makes it more positive and you can make the ratio suit the driver but needs solid mounted engine! Failing that I might make my own shifter but uses very good quality push/pull stainless cables so that I can maintain some bushing on the engine.
#375
cheers for the info
lol at reverse
should be fun then
when you planning to track it??
lol at reverse
should be fun then
#376
cool
beds rs day at bedford and rs day at donington, but may to soon for you, i not sur what time or whats around after that though, have castle combe in april and junt i think
#377
Will work towards bedford as its local and try get on last minute if its ready in time.
as of today I got tyres,coilovers(paid and ordered),30mm rear ARB,Compbrake 4 pot kit, 40m CDS tubing, 2 bucket seats, harness's, Steering wheel so the parts collecting has gone well!
#379
finally got back to working on the car after a xmas break, well work on the house
not much, progress but really happy that all the fuel fittings in the car are now finished and it's just the engine bay fuel system that needs doing
both pumps are wired up now with their own fuse and relay's
hopefully more done this weekend
#384
done some more work on the car
car is looking a bit more what it should do
my new reno clio oil filter, means i can do an oil change with the rad in place..lol
fuel lines now secure
fuel rail now all fitted
then , i pressured the fuel system to check for leaks, and had a bloody leak
my fault too, i nipped the ruber seal on the injector so will order some new one's tomorrow
and made a new straight peice for the water pipe, from my old washing line....pmsl
#394
had a busy day today,
first of all i got my new (second hand) 1.6gti gearbox and took the diff cover off
here is the new Quaife diff, with new bearings , and i have put the crown wheel from my std diff on the Quiafe
here is the diff back in the gearbox
and the box with the diff cover back on and with new drive shaft seals
here is the rear suspension, and brand new Peugeot's nut's and bolt's , there are now on the car
here are the hubs all off, ready to make it easier for the box to go back in and for so i can put the new struts in
here is the old gear box in place, waiting to be removed....lol
and here is the new box ready with new diff to go into the car
here is the old box out of the car
and here is the new box in the car
#398
just need to find out what oil i need now.
i guess i can put full throttle earlier now? from exiting the corners
how else will i gain? apart from always putting the power down
#399
Lukesville
The harsh snatching and torque steer, if you had this when acclerating hard out of a apex, dissapeared altogether on mine.
Leaves the car feeling alot more controlable and smoother when power comes in. Good for around 400hp in a fwd application too..
il give that a test this year
#400
sweet
it's the suspension, i'm more excited abou tho
as the old fronts where shocking, yet still did quite well
the new setup should make it a whole new car
and as a package is going to be awesome.........
i hope
i hope
