ESC COS REPLICA **RE-BUILD**
Starting to rebuild my Escort Cosworth replica now along with loads of bigger and better parts and after all the inside and outside is done a proper loony engine is going in!
Here are some pics when i got it :
hope you're sorting the billy bodge job engine bay out as well then!!! Look at the water feed for the turbo!!! Plumbers special!! And the intercooler pipes!!
couple of pics of my old mk5 I did!!
Since then i have bought loads of bits to change the looks of the car to give it a more genuine and original look !Including:
Interior-
cosworth dash board
dash banana
centre guages
full cloth Hexagon interior
speedo instruments
clock/temp
cosworth centre console and handbrake console
ford racing water temp, boost, fuel pressure, volt, and oil pressure guages
twin pillar pod
Exterior-
genuine front bumper with splitters and hockey sticks
RS7 diamond cut 17" wheels
330mm brake conversion
red/smoke rear lights
opening rear windows
Interior-
cosworth dash board
dash banana
centre guages
speedo instruments
clock/temp
twin pillar pod
Exterior-
dash
Yeah i know it aint a Esc Cos dash in the picture but im gettin a Cosworth dash as im fittin a sierra floorpan for the looks!
RJ
The cosworth badges stay im afraid
RJ
****3/09/04 UPDATE****
Hi guy's, well a bit more was done yesterday...here are the pics....
RJ's got his new wheels in
Freshly chopped and hand crafted with hammer and chisel from a sierra
New Spacer setup RJ got @ National Day to give the correct offset for the wheels with the esc cos wings
Stripped
Grinding down the calipers to accept the huowoge discs
Freshly angle drinded by moi to fit in the escort
Other side disc on and sorted
Removing the original seat mounts so the tunnel will fit correctly
In place, with a few minor adjustments ready to be tacked in
Once the tunnel is in place, an Escort Cosworth carpet will need to be sourced along with the dash and the interior can be bolted back in....RJ will then work on the underneath to modify the gear linkages for the tunnel etc....another update soon peeps....
Stripped
I am sure Ryan will answer, but he aint on here much. I 'think' it will come down to the factor of, insurance.....and the cost of even a 'repairable' cos, which youreally just dont find! and I must admit with things like this u 'can' end up spending just as much as buying a genuine one outright, but Ryan has had the car a few years now and it came up cheap with all the right bits on it, so he grabbed it whilst he could
P.S I know a esc cos is his ultimate car so sure he will buy the real thing one day
amence so its new gearbox rear exel and engine i take it ??? wat ya fitten in cosworth runnin gear??? and its ok fitten the tunnel but wat about the start of the tunnel (engine end)????
Looks good.
I seriously thought you were taking the piss when you said you were going to fit a tunnel!!!
You might as well rip the whole bottom out and put it on a 4x4 sapph floorpan!
Ryan has been without a PC for a long time now so no update's im afraid...will post one up as soon as, now winter is setting in work will carry on slowly i should think
lookin good, but is there a way you can get the front wheels to sit right without using a seirra floorpan? What engine you putting in? i'm away to look for a new engine for mines but need a few ideas but think it will be a erst but not sue
