ST170 Turbo Engine Rebuild - CGI - thinking of selling up!!
#82
Originally Posted by 205T16
AustenW: What compression do you run or did you run in your old spec even? I'm aiming for 400bhp ish on a 2.1 16v with similar bore size to a zetec and am wondering whether 9:1 is too high.
#83
The cars all stripped
Brand new Genuine Focus WRC water pump fitted
New CP pistons came today, I custom designed them for my spec, the rods are made in Norway and are alot longer than any Zetec rod My rod ratio will be 1.8
New Tial wastegate and dump Valve
New Steel flywheel and uprated clutch
Box full off ARP hardware
Billet Main Caps
Jenvey big bore Throttle body, raceline water rail and HKS filter
Will post updates as ad when.
Billet Main Caps
#86
nice ingredients for a monster engine there mate but wouldnt a group A filter work better than that hks filter or is it becouse of the room under the bonnet?
any way good luck & cant wait to see it finished
#91
I'm limited to space hence the use of the HKS filter, and I think they look cool too.
They have been dyno proven by Abbey Motorsport to well over 750bhp with little loss in power so should be fine for me. I'll just have to clean it regularly
Water pump is straight from Cosworth
Internally its much the same as standard but the inlet and outlet have been cnc machined to increase flow
#93
Originally Posted by maxrs16
excellent project but were do you get such good parts from such as Billet Main Caps
Also for the slightly lamer of us on here. Why do you switch to such components. Weight?
JAmes
#94
JAmes
The silvertop uses much thicker maincaps which will be stronger though
#95
JAmes
Looks good, some nice bits going into that
Will it be used in competition at all?
#100
Been busy match porting the manifold flangeto the head to the mill which has taken me two days solid
rebuilt the inlet system tonight
#102
Originally Posted by teamfatboy
Austin
If it wasn't for Stella I could build one of these!
Dominic.
Dominic.
If it wasn't for Stella I'd have finished it by now
#107
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Awesome work mate - having just read through your parts and engine spec list - you really have done your homework. The stuff you've put into this really is the best on the market
#109
I've decided to change the cam setup now
Although the standard set up is more than adequate I've decided to change them for a different duration and lift package.
Ordered my billet Cams today which should take 2 weeks.
I'm not saying what profile they are but they are far from standard
Going a custom grind route this time too
#110
Got this I'm selling at cost if anyone is interested
With buying it, carrage, duty and Vat it stands me at Ł250
Good for 1200bhp
3" inlet and outlet
Unfortunately it won't fit in the nosecone with a dry sump tank
Good for 1200bhp
3" inlet and outlet
#113
Just a question but you seem to have searched the globe to find all the right bits - how? How do you know who to contact to get the right bits for the job? Is it just endless web trawling?
Do you have to know what bits you need or can you say "i want to do this/i'm looking for something like" and just trust their judgement?
Just asking the q as you really have done your homework to get the best at the best price too.
#114
To ask peoples opinion is just a waste of time IMO as half the so called expert haven't a clue what there on about
I could write a long list but dont want to put any noses out of joint
#115
Some lovely parts raining in now What do you plan to do in terms of charge cooling now, or will you just have a smaller one made up? The oil tank will take up loads of your space there now I daresay
#117
New Chargecooler came this morning
PWR chargecooler from Australia
This size has been used on 900bhp Evo's running 9's
I should just be able to make it fit in the engine bay
#119
Hi from the U.S. , good write up so far. Been watching the thread for awhile.
Focussport has done some bad ass porting to the svt head, and has gotten more flow from it then the ford racing cnc head.
what are you using to run the c.o.p. 's? megasquirt?
#120
The Coil on Plug is fired by my MBE 970 as used in British Touring Car
