ST170 Turbo Engine Rebuild - CGI - thinking of selling up!!
Old 12-10-2006, 08:53 PM
  #41
AustenW
AustenW's Avatar
I've been busy since my last post.
Ive managed to shotblast an paint a focus block. I may use this if my CGI block doesn't turn up on time or may use it as a spare.
Ive assembled my pistons and rods
I've machined up a collar for my cam to allow me to mount a conventional piper adjustable pulley wheel instead of the variable valve timing wheel.
My plug top coils came today so I had to fit them to see what they look like.
My next task this week is to machine up some cam belt tensioner pulleys out of billet aluminium as the standard plastic ones are weak at high load and RPM, I've already got the bearings, mounts and billet sorted out, will post up pics soon.
Old 13-10-2006, 07:19 PM
  #42
fezzajsy
fezzajsy's Avatar
wicked
Old 13-10-2006, 11:21 PM
  #43
scruffythefirst
scruffythefirst's Avatar
Looking good chap, I'd love a passenger ride when its finished
Old 14-10-2006, 08:12 PM
  #44
kik1.6se
kik1.6se's Avatar
Hi Austin,
This was one of the most impressive Westfields i've seen, with the old engine (and I've seen alot of Westfields), so I'm looking forward to seeing it again with the new engine.
Kirk
Old 15-10-2006, 07:51 AM
  #45
Brian
Brian's Avatar
Brian
Old 16-10-2006, 08:50 AM
  #46
AustenW
AustenW's Avatar
No problem, only if you take me for a blat in your machine too
Originally Posted by kik1.6se
Hi Austin,
Kirk
I'll take you for a blast when its done, you off to Le Mans again this year?
Old 20-10-2006, 10:17 PM
  #47
escrst
escrst's Avatar
where you getting your cgi block from im thinking of gettin one from the states but postage is bout the same as the price of the block. hows the project going. im definatly gona get the coil on plug setup from ya but everything else is getting in the way at the min.
Old 20-10-2006, 10:42 PM
  #48
AustenW
AustenW's Avatar
Burtons will be getting some CGI Blocks in in the next week or two
Ł550 I believe
Old 21-10-2006, 12:28 PM
  #49
kik1.6se
kik1.6se's Avatar
I'll take you for a blast when its done, you off to Le Mans again this year?[/quote]
I'm booked on again - looking forward to it already .
Kirk
Old 28-10-2006, 07:39 PM
  #50
AustenW
AustenW's Avatar
I've managed to make up a new collar for the inlet cam to remove the VVT as the old one didn't work right with the cam seal.
Here are some pics of the metal pulley wheels Ive made up.
The standard plastic ones are a weak point on the zetec at high rpm etc.
Old 28-10-2006, 08:14 PM
  #51
Brian
Brian's Avatar
Looking good mate
Brian
Old 28-10-2006, 08:28 PM
  #52
fezzajsy
fezzajsy's Avatar
GENIUS..LUV UR WORK M8..
Old 28-10-2006, 09:57 PM
  #53
steve7786
steve7786's Avatar
Looking good do you want to make any more sets for the normal zetec head? Be good to see it all built up and mapped.
Steve
Old 29-10-2006, 07:56 PM
  #54
escrst
escrst's Avatar
yeah i rekon you could make a good bit of money from selling these pulley wheels you wanna make me a set go on put some prices up. im gonna have a coil on plug setup off ya definatly but as you know when you do a project there is so much to buy u have to shedule what you need at the present time. so when i get to the loom making ill be in contact.
pulley wheels Ł needed
Coil on plug Ł ive already got
any other trick mods for my st170 zetec conversion Ł needed
Old 29-10-2006, 11:47 PM
  #55
ollie_247
ollie_247's Avatar
wow that looks like a nice build there
Old 02-11-2006, 11:55 PM
  #56
Orionzetec
Orionzetec's Avatar
Im deffo intersted in the pulleys and the inlet cam collar if you start producing em
Old 03-11-2006, 08:09 AM
  #57
AustenW
AustenW's Avatar
As a bit of an update I've sourced some bits for the build
Tial Wastgate and Dump Valve
Pro Gram Billet Main Caps
ARP Main Studs
Focus WRC Waterpump
Focus WRC CGI Block
Will post up pics soon
Old 23-11-2006, 10:57 PM
  #58
Orionzetec
Orionzetec's Avatar
any progress m8?
Old 04-12-2006, 10:01 AM
  #59
AustenW
AustenW's Avatar
Moving ahead slow but sure
I've currently got the entire car stripped and I'm welding up the chasis with extra bracing
I'm also going for an uprated Quaife Sequential box and a new rear diff to take hard launches, Gearbox is all rebuild and I'm half way through the diff. Just getting the ring gear and pinion shot peened and polished.
This week the new big bore Jenvey throttle body has arrived and I've bought a new set of longer H section rods too.
I'll be destroking this engine to increase the rod ratio and make it rev better.
I've also ordered my New crank and pistons this week too
Will post up some pics when I get round to taking them
Old 04-12-2006, 10:46 AM
  #60
CraigoScott
CraigoScott's Avatar
wow, your not messing about here! gonna be even more of an animal i think!
Old 04-12-2006, 12:35 PM
  #61
fezzajsy
fezzajsy's Avatar
yep..this will be a fooking monster!!!
Old 04-12-2006, 02:08 PM
  #62
carlo
carlo's Avatar
This will be awesome mate i seen it at totb with the old engine
Old 04-12-2006, 03:37 PM
  #63
T4KAF
T4KAF's Avatar
this is gonna b so quick,will b fun trying 2 get traction!!!!
Old 05-12-2006, 06:15 PM
  #64
AustenW
AustenW's Avatar
Decided to totally uprate the top end which has ment 31mm exhaust and 35mm inlet valves from the USA.
Gone for a special alloy mix to withstand high temps which is better than inconol, work out at $47 each
Also ordered my double valve spring package from Belgium, at Ł400 its not cheap either
Head will need new guides and seats to suit too new valves.
Its not cheap but it will be the best you can get and will have big potential.
Been informed that these ST170 heads flow more than the Mitsubishi Evo 9's so if I put a silly turbo on there it will be a monster.
Old 05-12-2006, 06:33 PM
  #65
smitsturbo
smitsturbo's Avatar
nice...very nice
what is the overall weight of your westfeild mate
Old 05-12-2006, 11:24 PM
  #66
AustenW
AustenW's Avatar
Originally Posted by smitsturbo
nice...very nice
circa 520kg but will try to get it below 500kg if possible
Old 05-12-2006, 11:27 PM
  #67
AustenW
AustenW's Avatar
Have a set of these currently for sale
Farndon Rods with ARP Bolts and Arias low comp Pistons 86mm bore
Used but in mint condition, done 5k miles
PM me for further details and price
Old 07-12-2006, 10:50 PM
  #68
Mk1-stu
Patronus
Mk1-stu's Avatar
i just read the entire thread - and hafta say i'm really impressed, you really know your shit !!
really looking forwards to reading the next updates
Old 08-12-2006, 09:35 AM
  #69
bassboy
bassboy's Avatar
MASSIVE respect to you Austin
would be amazing seeing this go up with Sunny and Ian Howells new creation...but due to weight...i think you will see them in your rear view mirror...
what is the overall power you are hoping for? seems to be upping spec everytime i read the thread LOL
bassboy
Old 08-12-2006, 06:31 PM
  #70
AustenW
AustenW's Avatar
With the head flow and revs and with a huge turbo and boost 780bhp is achievable.
Jim at CNC head informs me it will flow more than an Evo 8 head
I've bit the bullet and gone for 35mm inlets and 31 Numonic exhaust valves from the states which is costing me a fortune
The head will require all new guides and seats as well
This will be without doubt the most radical Zetec engine in the country.
It will be a bullet proof engine, it will rev well and have loads of potential for big HP.
I'll have to make the car 4WD next
Old 09-12-2006, 10:05 AM
  #71
Mk1-stu
Patronus
Mk1-stu's Avatar
4wd on a car like that would be insane ! but could you justify the extra weight ?
a chap i know on another forum showed us pics of his n/a 292bhp st170.. that's pretty good considering a normal 2.0ltr zetec won't see much passed 250bhp n/a !
Old 09-12-2006, 10:31 AM
  #72
bassboy
bassboy's Avatar
hats off to you mate...will be amazing! would you be able to PM me some websites where to order this stuff from the states from? im not doing the conversion (i have done the silvertop zetec route) but its just something i would like to read up on is possible...would want to take mine to the next step in about a year or 2
bassboy
Old 09-12-2006, 10:42 AM
  #73
AustenW
AustenW's Avatar
Got my valves from here:
http://www.ferrea.com/
Old 09-12-2006, 10:56 AM
  #74
bassboy
bassboy's Avatar
cheers mate...how the hell did u find these companies? im guessing it wasnt just a google search LOL
bassboy
Old 09-12-2006, 11:09 AM
  #75
AustenW
AustenW's Avatar
I get the American Performance Racing Industry Catalogue and Bi-monthly magazine
Alot of these guys are at the Autosport Show in Jan but only in the engineering section which is on Trade days
Old 09-12-2006, 11:53 AM
  #76
bassboy
bassboy's Avatar
ahhh ok!! where can i get a subsription from
bassboy
Old 09-12-2006, 05:56 PM
  #77
jammy86
jammy86's Avatar
Hey there.
I've seen this car at TOTB the last few years and absolutely loved it! Got some nice pics of it. Defo one of my favourite cars that I've ever seen.
Thew new engine looks sick! all the best with it. out of curiosity, what do you do? You seem to have a fair amount of knowlege, expertees and equipment available to you.
Keep it up!
JAmes.
Old 09-12-2006, 06:24 PM
  #78
fezzajsy
fezzajsy's Avatar
cant wait to c this when finished..credit to u man
Old 11-12-2006, 10:39 PM
  #79
AustenW
AustenW's Avatar
Uprated alloy gearbox casing on my Quaife sequential
Old 12-12-2006, 12:35 AM
  #80
fezzajsy
fezzajsy's Avatar
Quick Reply: ST170 Turbo Engine Rebuild - CGI - thinking of selling up!!
