saph sierra cosworth 4wd
hello,
Initialy the car was stripped and painted black.
Then I fitted:
Powerflex full Bush kit
Engine mounts collins.
The engine: new pistons, high pressure oil pump, cometic gaskets, new valves, valve guides etc., double kentcams valve springs, piper vernier pulleys.
Pace Intercooler RS500 style.
Turbo Precision SC5031 with internal wastegate , 31-actuator, dumpvalve
Samco hoses full set
K&N 100mm filter
BOSCH 803 injectors
3 bar map sensor
Gr.A coil & motorsport leads
Bosch 044 fuel pump
Swirl pot spec-r & P/S tank
bailey bretaher
MT75 shortshift
Alcon 6 paddle clutch
Mongoose exhaust with V-band for the turbo
Koni suspension with eibach
Std brakes with new discs and pads
Goodrige high pressure lines
Interior std with refub door cards
Apexi avcr black limited editon
Greddy oil pressure EGT boost
Wheels revolution 8x17 ET33 gr.A fitment with BFgoodrich 215/40/17.
All the rebuild took me 9 months December 07 August 08
Then I fitted:
K&N 100mm filter
BOSCH 803 injectors
3 bar map sensor
Bosch 044 fuel pump
bailey bretaher
MT75 shortshift
the transmission for the moment is std... but not for a long... i found a gear kit with helical cut stronger and with close ratio from a tuner here in italy and i want to buy a damaged MT75 and prepare it. I saw escort cosworth with this kit running 550bhp and there was no problem!! So i hope it will be the same for me!! First of all more urgent is a front brake kit! because std brakes isn't enough!!
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
