Other Marques Use this section for any non Ford marques.
front sway bar question scorpio I
Old 10-09-2010, 07:44 AM
janus
janus's Avatar
Default front sway bar question scorpio I
Hi folks!
i have owned a 92 Scorpio Mk1 for about a year and a half now, bought it with 170kkm now it's a bit over 200kkm on it. ever since i got it it had a tendency to understeer, actually it's very bad once it get's a bit wet. I know that my suspension would need to be replaced (struts, shocks, springs maybe) and i'm sure some of the bushings as well. But i was wondering if i could fit a thicker front sway bar at the same time? If i measured right the one i have now is 28mm.
Any recommendations? It might get a lot better after changing the bushings, but what if not? then i got new 28mm bushings for the ditch..
Thanks!
Greetz from Austria
Andi
Old 10-09-2010, 05:06 PM
I don't think there is a thicker sway bar for these, I'd just replace the bushes and suspension as this should give a massive improvement on it's own, and see where you go from there.
Old 28-09-2010, 08:00 PM
janus
janus's Avatar
okay thanks
just got some new bushings today, the ones for swaybar-to-frame and swaybar-to-a-arm. hopefully that will cure some of the problem
just in case someone is looking for part numbers or torque specifications:
swaybar-to-frame bushing (70-90 Nm): 1630507
swaybar-to-a-arm bushing:
outer disc 1656752
inner retainer disc 6172539
inner pressure disc 6172540
nut (nylon-secured) 6523434 (tighten to 70 to 110 Nm)
I'll post again after installing them and a rainy test drive
btw - this forum has no driving smileys??
Anutternutter
24
31-08-2015 01:24 PM
blackbeautyzetec
29-08-2015 02:11 PM
C2 MAK
20-08-2015 09:46 PM
markk
18
17-08-2015 05:19 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: front sway bar question scorpio I
