ford escort mk6 p-reg rev counter wiring
i have a p-registered 1.4 escort encore. i took the white clocks from an escort si yet cannot get the rev counter to work. i beleive it takes the signal from the ecu, does anybody know which pin on the ecu the signal comes from? any help would be much appreciated
Hi there, i know its been a while but did you ever get ur rev counter working? i have same problem with s reg si mk 6 but not received any help.
Have read on forum blue socket number 8 to number 4 or summin not sure, what do you reckon????????????
cheers.
cheers.
hi there, i got rid of my car before i did the job but i was informed by various people that it was pin 8 on the blue plug and 4 on the ecu. if you do it would you let me know if it works as i have an escort cl estate in my garage with gti clocks and dead rev counter so am planning to do the job myself sometime soon.
WAHAAAAY. Just got out from behind the steering wheel (3 hours). white dials and new white clock fitted and believe it or not the rev counter WORKS ! no extra wires at all. Must have loomed in all necessary wiring to late mk 6 models for the sake of it.
good luck with your estate. Paul.
my clocks are already in my esate but the rev counter is dead . i think i am going to invest in a new set of clocks and try that before i mess with the wiring. good result for you tho mate saved you a lot of messing
vdun01
Ford Fiesta
05-10-2017 09:14 AM
cozzy jeff
14-08-2015 06:46 PM
