Other Marques Use this section for any non Ford marques.
mondeo springs
Old 27-11-2007, 10:30 PM
lewis_lisa
lewis_lisa's Avatar
Default mondeo springs
ive got a mondeo zetec-s 2000 model and the steering is pulling to the 1 side real bad ive been told springs are a comon fault and do snap where do they break
the car also seems to sit pretty high at the front its only had the wheels changed to st170 rims so they wont make a big diff will they
cheers lewis
Old 29-11-2007, 08:17 AM
fordcrazy
fordcrazy's Avatar
depends on how big the wheels are..ive owned a mondeo for the last few years and the larger the wheel the more she pulls..ive got a 98 zetec at the mo and shes doing the same as i now have 17s on them..if your springs have busted the break will be more likely on top and may not see em...also if a wishbone is on its way out then it can also cause this problem
hope it helps ya
kev
Old 29-11-2007, 05:07 PM
lewis_lisa
lewis_lisa's Avatar
thanks kev
gonna check it over 2nite and will check all the points you mentioned
the wheels are 17s aswell
Old 30-11-2007, 10:00 AM
lewis_lisa
lewis_lisa's Avatar
had a wee look last night turns out ive bought a shit tyre with a bulge in it gonna find out if it was faulty when i got it or if it aint been fitted correctly
Old 04-12-2007, 09:24 AM
fordcrazy
fordcrazy's Avatar
ouch not good ..unfortunatly you can get a bulge just by slightly hitting a kerb so thats wat they will 9 times out of ten say
Old 04-12-2007, 08:25 PM
tarmac terriost
tarmac terriost's Avatar
check the springs any way find out mine were trashed
both fronts had split off up the top of them so loss a whole coil
and iam running 17" with 215/40 so the gap was even bigger but have dropped the ride hide by 30mm all round on eibach springs
which has made it some what better
also wishbones and tracking will make the car pull to one side also
a dodgey caliper could cause the same problem too
Old 04-12-2007, 08:41 PM
lewis_lisa
lewis_lisa's Avatar
cheers for the help guys will be checking over the full car to make sure its sorted
got the tyre swapped today as the guy that owens the garage stays across the road lucky i reckon
Old 05-12-2007, 06:59 AM
I have yet to own any GOODYEAR F1 GSD3 that did not develop bulges and have never hit a kerb in thier life, they just seem to do it at around 4 years old, on three different cars I know of.
FRont subframe alignment is very important on a mondy as well, although mondies do seem very sensitive to road surface and will pull gently, a different tyre can make it worse or better depending on the tyre as well, so I increase prerssure by around 3psi on the nearside and it stops it.
wowk
30-03-2021 07:49 PM
01-11-2015 06:53 PM
Brickhouse
14
03-10-2015 07:28 PM
The Enigma
29-09-2015 10:31 AM
SMILER258
28-09-2015 09:04 AM
Quick Reply: mondeo springs
